Low profile sight glasses
Black Bull
Post by Black Bull »
I'm slowly collecting parts for my next build and I want to utilize some sight glasses.
Ideally I'd like them around 4"
BUT
I dont want them sticking out like these
Screenshot 2024-11-04 at 20-00-54 1pcs 25mm-108mm Sanitary Sight Glass Diopter Stainless Steel SS304 Circular Viewing Sight Glass - AliExpress 13.png
Has anybody used something similar to these and welded or soldered the flange in ?
Screenshot 2024-11-04 at 20-02-55 ISO63_80_100 vacuum Viewports SS304 NW63 flanges sight glass ISO-LF flanges viewport ISO inspection glass SS304 vacuum viewport - AliExpress 13.png
Failing that, any other suggestions ?
I'm not fat, I'm in shape....Round is a shape
Getting old has whiskers on it !
Tammuz
Re: Low profile sight glasses
Post by Tammuz »
If you are using them in 6"-7" sections you could cut a hole large enough for those to slide in and solder them from the inside.
But if you add insulation to your column they wouldn't be sticking out at all.
MooseMan
Post by MooseMan »
Have you looked at the low profile sight towers?
Like this?
https://www.steriflowvalve.com/products ... s-windows/
Tammuz
Post by Tammuz »
If you're installing site glasses for viewing plates the above won't help much. If it's just for watching reflux or puking AliExpress would be a cheaper option.
Salt Must Flow
Post by Salt Must Flow »
Where do you intend to install the sight glass/glasses?
Black Bull
Salt Must Flow wrote: ↑Mon Nov 04, 2024 11:03 am Where do you intend to install the sight glass/glasses?
These ones will be for levels on tanks, room is tight and I don't want shit sticking out
Black Bull
MooseMan wrote: ↑Mon Nov 04, 2024 7:58 am Have you looked at the low profile sight towers?
I hadn't seen them, but they wont be of much use in this case.
Cool thing to keep in mind though :thumbup:
Tammuz
Post by Tammuz »
They make small site glasses used to monitor oil levels.
MooseMan
Post by MooseMan »
Black Bull wrote: ↑Tue Nov 05, 2024 2:23 am
Is it a straight sided tank?
Salt Must Flow
I see one of those in 4" on Aliexpress for $50. Based on their schematic, if you precisely cut a 95mm hole in the boiler you should be able to insert the smaller diameter portion of the flange inside the hole and solder or weld it into place. The small part of the flange is 14mm tall (.55") so I don't know how to model it with the curvature of the boiler to determine if it will fit. You would also have to have access for your hand and the rest of the flange to fit into the boiler so you can install the parts after welding/soldering.
EDIT: Actually I do have a simple modeling software. Is your boiler a keg? If not, what is the diameter of your boiler?
Salt Must Flow
Here's a model based on the measurements in the product listing compared to the diameter of a 15.5 gal keg.
The only other variable I cannot model is the bolt holes, their location and whether they would interfere with welding/soldering it through the boiler. BUT based on what I can see in the video, it looks like the the screw heads shouldn't interfere because they're near the top of the flange.
It sure looks like these will work with a keg.
Tammuz
Post by Tammuz »
If it's boiler level your looking for maybe something like this.
montanan_hippie_man
Post by montanan_hippie_man »
Tammuz wrote: ↑Tue Nov 05, 2024 1:42 pm If it's boiler level your looking for maybe something like this.
i actually bought one of these for that purpose and never used it. after doing some research on the gasket type used in that. its not the good kind "we"
want.
Tammuz
Post by Tammuz »
montanan_hippie_man wrote: ↑Wed Nov 06, 2024 8:49 am
want.
I don't know what type of gasket "we" like you are referring to. This is a threaded fitting,NPT. I like it.
SW_Shiner
Post by SW_Shiner »
Tammuz wrote: ↑Wed Nov 06, 2024 3:12 pm
want.
Possibly referring to the gasket that seals the glass to metal. Id also be worried about to little red ball.
Tammuz
Post by Tammuz »
That plastic ball gets removed with a slight pry. Mines on a steam generator though marked for food processing. I guess if it was higher wines getting used I would look into it more. That is one thing about a man's shed and only consuming in a small circle.
montanan_hippie_man
want.
PTFE.
Tammuz
Post by Tammuz »
I checked into it and that's what's used. Since my generator and boiler don't see abv over 30% I wouldn't be upset if it was viton the other gasket that seems popular with these sight glasses. These I only use on my steam gen since water drops much quicker there. On my boiler I use 3" sight glasses from oak stills. Overkill maybe but they were just a few bucks when I bought them.
