Stripping in Pot still and spirit in column?
Levii
Hi there,
I already own a pot still and have set my eyes on a column with 4 perforated plates. My question is: is it ok to do my stripping runs still in the pot still or is it better to go from a 10% wash straight to the finished product? I exclusively do rum and whisky. What is the best proof to go into a boiler for a 4 plates colum?
- NZChris
Re: Stripping in Pot still and spirit in column?
There is no need to strip if you are running a plater.
My preference is to strip three or four washes, then spirit run in the same pot still. That way, I only have to do cuts once for three or four charges of wash. Using a plater, I would have to do cuts for every boiler charge, which would be ok if my boiler was three times the volume or I wasn't in a hurry to fill a barrel for aging.
- NZChris
If you are interested in making high ester rums, a thumper might be a better investment.
There is no right or wrong way to use a plated column, you can strip easily with one by just turning water to the defleglamator off completely.
As for the whas or low wines , again that is your choice.
The is no good reason that I can think of to run 100% low wines unless your trying to remove a lot of flavour.
Making neutral or vodka would be one reason.
A plater will make good spirits for a one and done run, using straight wash.
My personal preference is to run 50/50 wash and low wines or another ratio depending on what I'm making at the time.
When I used my plated still for Rum , I found straight wash was not as good as using a mix like SBB said . My plated still didn’t like an ABV less than 10% …… well I could run it , but the Hearts run was small . When I upped the ABV by either stripping half the wash first and/or adding feints from last Rum run , the still “behaved “ smoother and the hearts run was longer and more consistent .
In the end I would just strip all the wash and run with three plates and feints .
Now I use a Thumper and the plater sits sadly in the corner .
Levii
Thank for all you’re replies!
I’ve looked into thumpers, but I don’t see myself owning one anytime soon. I‘m EU based and can’t find any around here. I live in a city Appartement with no tool on my hands so building one isn’t an option either.
If made an all molasses 100% pot still rum before (muck and everything), and quite frankly didn’t like it at all. I do like commercial examples like smith & cross etc…
My best bet is driving over to Poland and getting one of either of those two. Which one would you choose considering I already own a pot still and mainly dabble in rum (dark and Spanish style white), bourbon and whisky?
Sporacle
Wash and feints (obviously after your first run of a straight wash) on a flute, don't be greedy with your hearts and you'll have plenty of feints for subsequent runs.
Levii
I was shooting for a white pot still overproduces like Wray & Nephews. I Found that the final tasted more like the wash it was made from than actual rum. I tried aging it (without wood) für half a year but the smell didn’t change.
Many ways to getter done.Levii wrote: ↑Sat Dec 14, 2024 10:40 pm
I prefer doing stripping runs so the mash or wash isn't boiled for extended time like it is when doing a one run and done. The most important tails cut happens when the boiler is shut down and emptied at the end of a strip. Get rid of the nastiest tails this way and then redistill.
It took me years to realise I was keeping to much of the tail end in my cut .No amount of aging would help . Commercial Rum is very devoid of tails . Maybe that was your problem too .
If a light Rum is what you want , I can recommend running an all Molasses Rum through that packed reflux still .It will come out like a Bacardi without the need for barrel aging and charcoal filtering that Bacardi do to it .
I think it helps to let a rum wash settle so less of the trub gets distilled.
There's less tails to deal with if spent yeast doesn't get into the boiler.
As to using plates, I've got a collection of them gathering dust. It was fun and a learning experience building them, but now I mostly use a potstill for rum instead of reflux.
Levii
I read that Jamaicans do extended ferments so I gave mine a full month. It was cristal clear at that point. I’ll definitely give the pot still another chance with rum but for now it’s destined to make my AG whisky’s.
If i send an all molasses wash through that still, do i use the lm or the vm takeoff?
Does a 96% molasses wash retain any rum flavors or is it just plain neutral at this point?
Again: stripping run or not?
Could I use the LM takeoff for my bourbon needs?
I see that the still can be operated with an E-ARC controller that only collects product at or above 96% that sounds fun to experiment with …
Regarding that packed column …Yummyrum wrote: ↑Sun Dec 15, 2024 6:58 pm It took me years to realise I was keeping to much of the tail end in my cut .No amount of aging would help . Commercial Rum is very devoid of tails . Maybe that was your problem too .
When you run a Molasses wash or stripped through a packed reflux still it still retains a very characteristic Rum flavour . It is very hard to beat the Molasses out even though we associate a still like this making a Neutral , this is not the case with a Molasses base .
It should make little difference if you use either LM or VM ….however , taking a closer look at that still , it rings a bell . I believe it has the VM take off lower down the packing rather than above it like a “normal” VM still and uses the LM as a slow heads trap .
EDIT : found it viewtopic.php?p=7756841&sid=4352b020ece ... 5#p7756841
