Botanical basket - T500 saddles - bit confused . . . . .
Fincheeei1
Post by Fincheeei1 »
I just bought a Botanical basket for my T500 and I'm a bit confused about the saddles.
Ive removed the Stainless steel saddle and placed the Botanical Basket in its place.
It's just the wording saddles , implying there are more then one ? !!
Anyone ? !!!!
I can only see the one that needs removing , πŸ™
Re: Botanical basket - T500 saddles - bit confused . . . . .
The saddles I have seen in a t500 are small and the column is full of them.
For the record you don't need a gin basket to make good gin.
Learn to make a quality neutral first, then just add the neutral along with desired botanicals back to the boiler.
You can make or buy a small pot still head to run on the t500 boiler for that part of the process.
Your other post identical to this has been removed. No need to ask twice.
Fincheeei1
Thanks for clarifying that.
After carefully reading the instructions I found that the alembic dome just has the one saddle unless I'm mistaken.
Ive started by making a half decent neutral and I'm attempting a type of absinthe which I'll post at a later stage.
Apologies for the double post . . . . . .
Fincheeei1 wrote: ↑Tue Dec 31, 2024 10:21 pm
Ummm T500 used to always be a reflux still …. With saddles in the column as packing .
Then in the last few years , they bought out a fancy copper lid for the T500 boiler and called it the Alambic dome . It was a Pot still
not a reflux still . It can cause a bit of confusion .
I am curious where in that alembic still , where are you ment yo insert a single saddle :wink:
Fincheeei1 wrote: ↑Tue Dec 31, 2024 10:21 pm Ive started by making a half decent neutral
Making a half decent neutral won't be easy using a pot still.
An Alembic is only a type of pot, it just sounds fancier.
Saltbush Bill wrote: ↑Wed Jan 01, 2025 2:41 am
That was my thinking too Salty . Alembic Pot stills a great for stripping a wash . but then , if you want to make a neutral , you need to run the stripped wash through the old school T500 reflux still or the likes .
Can’t make a Neutral with a Pot still .
Reefer1
Post by Reefer1 »
Fincheeei1
I started out with aT500, when i figured it out done some runs and got comfotable ballacing the temperature and so on, got a good neutral wash recipe and got a half decent neutral spirit, that's when i thought about making gin, i ended up buying a airstill basically because you can make a bottle at a time if it turns out unpalattable not so much to drink or redistill they are a great experimenting tool, your dome will work good with the gin basket, just be aware you may need to get a power controller for the boiler otherwise it will run a bit too fast.
Have a great NY
Fincheeei1
Okay , so my next purchase will be a voltage controller and then I'll buy a reflux column by the end of this month.
Ive really taken a shine to this hobby , it's really good fun. I'm enjoying it a lot.
Thanks , everyone , for all of the pointers and advice , it is much appreciated πŸ‘ πŸ™‚
Reefer1
Post by Reefer1 »
Fincheeei1 wrote: ↑Fri Jan 03, 2025 8:26 pm Okay , so my next purchase will be a voltage controller and then I'll buy a reflux column by the end of this month.
Fincheeei1
Just out of interest, if you bought a t500 you should have a reflux column that comes with it out of the box.
SW_Shiner
Post by SW_Shiner »
Going by whats been said in this thread, he didn't buy a t500. he got the alembic done on the t500 boiler. I purchased the boiler separately (no column or dome) and it still says t500 on the box. I think that may be where the confusion has stemmed from.
Edited to add pic
Reefer1
Post by Reefer1 »
Ye, understood, SW. Not clear on the post.
SW_Shiner
Post by SW_Shiner »
Yeah, still not clear on what the "saddle" they removed actually is.
Reefer1
Post by Reefer1 »
I think it may be the big nut that holds the column / dome condenser onto the lid.
Fincheeei1
Reefer1 wrote: ↑Sun Jan 05, 2025 3:23 pm I think it may be the big nut that holds the column / dome condenser onto the lid.
Yeah , that's correct - I'm just getting used to the terminology . . . . .
Fincheeei1
Reefer1 wrote: ↑Sun Jan 05, 2025 2:15 pm
Fincheeei1
I did , in fact , buy the kit with the alembic dome. I didn't realise there was another still with the same name or I would have made the distinction.
I think I'm going to buy their reflux column for neutrals 😎
The rules keep changing with these things, once upon a time the boiler came complete with reflux column only.
The entire kit was sold as a "T500" from my experience.
My son bought one of these about 13 years ago, and that is what lead me to being here today.
Boilers , reflux columns and Alembic / pot sill heads all seem to be sold separately theseday which is what leads to the confusion.
When us older distillers read T500 we automatically assume reflux still T500.
MarkChap
Post by MarkChap »
Not just you older blokes Salty, I am very new to this and I always think of the Reflux column when someone says T500,
Makes it hard when Still Spirits label all parts of the system now as T500
I'm just here to make mistakes and feed the ego's of the haters,
50mm CCVM, 1.0mt Column,
Gas fired Keg
Reefer1
Post by Reefer1 »
Ye, when i bought mine the T500 still kit was a boiler and reflux column, and the copper dome and condenser where a seperate part. As was the gin basket.
It's good you can get all the components seperately now, i use the T500 boiler as my main boiler but with my own columns if it goes pop i can get a new one.
Fincheeei1
I bought the voltage controller so I'm ready to try a spirit run this week πŸ™‚
I ran Teds Fast Fermenting vodka and even though it won't be a true neutral I enjoyed the taste of another similar recipe in my pot still.
I'm buying the reflux column in just under two weeks and I'm fairly set on the T500 , it looks very good πŸ‘
Thanks again for the advice , it's helped me moving forward ☺️
Think hard before you buy the T500 reflux head, ,,,,I'd be looking at a similar reflux head based on the slant plate design and marketed as the " alcoengine".
It could be marketed under more than one name , but it's easier to use and produces a high abv spirit of equivalent quality or better.
It runs a very similar boiler which can also be adapted to fit a pot still.
Saltbush Bill wrote: ↑Tue Jan 14, 2025 3:31 am Think hard before you buy the T500 reflux head, ,,,,I'd be looking at a similar reflux head based on the slant plate design and marketed as the " alcoengine".
Agree Salty . Would be so much easier to run . No stuffing around with coolant flow management .
And the alcoengine can pull 95% whereas the T500 is closer to 93%
https://www.ebay.com.au/itm/16470795880 ... 1LEALw_wcB
Also sold as Pure distilling .
https://www.ebay.com.au/itm/23547010103 ... kvEALw_wcB
These are also 2”
Columns whereas the T500 is only 1.5” IIRC .
