Fixed Valve Plate
Tammuz
Re: Fixed Valve Plate
Post by Tammuz »
What about making a sieve plate with 8-9% opening. Then take a thin sieve plate with 6-7% opening and just place that on top so that it floats on top of the bottom plate.
Tammuz
Post by Tammuz »
Duplicate post
subbrew
Post by subbrew »
For the valves I think copper rivets would work. You could slightly bell the bottom so they did not pop clear out. I don't know what sort of weight they would need to operate efficiently.
Tammuz
Post by Tammuz »
Maybe stainless steel rivets would work better. We tried copper with different amount of slack by using different hole sizes. Running rum on spirit runs by the third run they were sticking. Maybe a different designed rivet with a larger head would have worked.
acfixer69
Post by acfixer69 »
I made these 10 or so years ago
They worked fine, I only used them for spirit run and they had a great turn down rate.
They are not a fixed valve plate,but I'm not sure what a fixed valve is.
Have multiple long slits in the plate and have soldered on Z strips to direct the vapor blowing into the reflux.
Since the post has drifted a little from fixed plates. Here's a valved plate I did awhile back.
It needed several more valves and more open area to work faster or have lots of extra small perf holes between the valves.
It would start and load just like a well designed bubble cap plate.
Turn on the power and reflux water and the plates would load top to bottom as you watched with no drama.
DSCF0003 (350x263).jpg (24.47 KiB) Viewed 1226 times
LWTCS wrote: Tue Feb 11, 2025 1:22 pm
Well so far its about plates that have more operating range than the basic perf plate without the added complexity of a bubble cap plate.
So would I be right in assuming that the turndown of a fixed valve plate can only be as good as a perf plate assuming both have the same open area . (IE with the same open area , both need the same minimum power to hold liquid )
Therefore , increasing operating range can only be done at the turn up end . And this is the idea of shooting the vapour sideways into the liquid rather than straight up .
shadylane wrote: Fri Feb 14, 2025 6:25 pm Have multiple long slits in the plate and have soldered on Z strips to direct the vapor blowing into the reflux.
That would be fairly easy to do Shady . Cut slots with a cutoff disk . Z strips easy to bend . Wouldn’t need to be thick copper .
Yummyrum wrote: Fri Feb 14, 2025 6:52 pm
Entrainment would be less of a problem.
I think due to the vapor being blown sideways, the reflux can't drain down the sieve holes as easily.
Therefor a wider range of operation would be possible.
Long story short it would be somewhere in between a bubble cap and sieve plate.
Yummyrum wrote: Fri Feb 14, 2025 6:56 pm
I haven't tried it yet but it looks good in theory. :lol:
Swedish Pride
Post by Swedish Pride »
shadylane wrote: Fri Feb 14, 2025 7:07 pm
Sure does, can't beat a visual representation.
Looks less hassle than drilling a godscillion holes in a plate.
Cheaper too, the way I snapped drill bits anyway
Don't be a dick
googe
Post by googe »
Cool subject LWTCS, I like zacks pic. No moving parts. So, are you after a plate that has the action of perfs and bubble and valve? I see no issues with no downcomer if you have flow right, would only take a bit of Science which is abundant here. I did it easy with the flap plate and I'm dumb as shit lol
"Homer J Simpson"
