Maybe its just me then. I could never get it right. Got told i was getting the joints too hot. Moved to using just LPG and had better luck. Now gas is removed completely and it all gets TIG welded.Saltbush Bill wrote: ↑Sun Mar 16, 2025 12:01 pmThe only gas I've ever used when building is MAPP, I've never had a problem with it.
I need a nudge in the right direction
Re: I need a nudge in the right direction
I've always used Silver Solder / hard solder on Copper to stainless joints.
The higher the silver content of the rod the easier to use.
I'm gonna try lower heat. I think glowing might be too much
Buck Owens
Buck Owens
- Tummydoc
Silver solder and liquid acid flux. Doesn’t need to glow red
I need to go ahead spend that 90 bucks on the silver solder but, that will have to wait a couple of weeks if I don't figure out something else by then. I can get some solid copper ground line and make some ferrules and bypass the whole silver solder or brazing
Buck Owens
Buck Owens
The brazing rods we use for brazing our copper med gas systems (which is what I'm using) has too high of a melting point. By the time the rod wants to melt it's starting to glow. It didn't work joining the nut to the keg like i thought it did either (ss to ss).
Buck Owens
Buck Owens
I got my braze worked out, I used the powder flux and my brazing rods, just played with the flame placement. I would get the nut just starting to glow and move the flame to heat the powdered tip of the rod then put both to the the nut and "tinned" it, then built up on top of it . I had done the same to the keg around the hole prior to setting the nut on it, then started tinning the nut. It held with no leakes. I currently have it almost full of water heating up
Buck Owens
Buck Owens
I let it run an hour with the line arm on while I was eating and went checked it, it was blowing steam, 213°f. I put the liebig on and let it go another 15 minutes. Something in the box popped when I turned it down to shut it all off though. I noticed the readout was still reading as I turned the breaker off.
I'll open it up and see what's happening after work tomorrow. It might have gotten too hot running at max for a little over an hour.
Buck Owens
Buck Owens
Corn Cracker never leave you still while it is running. Also I wouldn’t run at full power for that long.
It was only water and unattended for less than 30 minutes, I wouldn't walk away from product distillation or a propane burner
Buck Owens
Buck Owens
- Swedish Pride
Do you strip at less than full power?
Takes me a about 3 hrs so do a strip run, including heat up, I run at full whack the whole time.
Big gauge cable and an extraction fan helps to keep the controller cool.
Don't be a dick
I'm thinking the fan that came with the regulator was not adequate to keep it cool. I'll know more when I get home from work and open it up. I may have to get a new regulator, I know this but, I don't think it should have popped from turning the power knob down.
Buck Owens
Buck Owens
I guess I didn’t read far enough back I run a reflux so don’t do a stripping run.Swedish Pride wrote: ↑Sat Mar 22, 2025 1:42 amDo you strip at less than full power?
- PalCabral
+1Swedish Pride wrote: ↑Sat Mar 22, 2025 1:42 am Do you strip at less than full power?
This is my set up and run time too.
I've got the replacement regulator ordered, it'll be here tomorrow along with an extra fan.
3 hours for a strip, that's awesome!
Buck Owens
Buck Owens
I found that there are arc welding sticks for stainless. I will be getting a box of those. I've been wanting to use my new welderSW_Shiner wrote: ↑Sun Mar 16, 2025 12:34 pmMaybe its just me then. I could never get it right. Got told i was getting the joints too hot. Moved to using just LPG and had better luck. Now gas is removed completely and it all gets TIG welded.Saltbush Bill wrote: ↑Sun Mar 16, 2025 12:01 pmThe only gas I've ever used when building is MAPP, I've never had a problem with it.
Buck Owens
Buck Owens
I picked up some some soft silver solder, figured out of the 3 different fluxes I have one should work..... nope, I'll get some of that flux later.Corn Cracker wrote: ↑Sat Mar 22, 2025 3:46 pmI found that there are arc welding sticks for stainless. I will be getting a box of those. I've been wanting to use my new welderSW_Shiner wrote: ↑Sun Mar 16, 2025 12:34 pmMaybe its just me then. I could never get it right. Got told i was getting the joints too hot. Moved to using just LPG and had better luck. Now gas is removed completely and it all gets TIG welded.Saltbush Bill wrote: ↑Sun Mar 16, 2025 12:01 pmThe only gas I've ever used when building is MAPP, I've never had a problem with it.
Buck Owens
Buck Owens
- Swedish Pride
Corn Cracker wrote: ↑Sat Mar 22, 2025 3:05 pm Screenshot_20250322_180227_Gallery.jpg
Thats the little capacitor or whatnot that popped, it's sitting between the plug for the fan and what i think is the switch for the fan.
What rating is your controller and what wattage is your element?
Controller looks like a big standard one from AliExpress or the likes.
Good practice when getting these are to double the controller wattage compared to the element you are running.
I've I have a 10,000 w controller that i bought for a 5,500 w element. Also go a cable size bigger than what's required, add heat sink and fan to the box as well
Don't be a dick
S.P, It is a 10,000w controler for a 5500w element. 10 awg is the cable size. I had a new fan delivered yesterday, I will try to get it installed today, ive got to figure out how to wire it up, also, I have to replace the breaker that runs it today. It went bad too. I got the new controller installed and flipped the breaker, plugged it in and nothing. Double checked my wiring and determined it was a bad breaker. I'm getting one on the way home today
Buck Owens
Buck Owens
Yesterday was just one of those
-if it can go wrong it will- days. I left that alone and tried a couple of other tasks that needed to be done, I ended up giving in and took a long nap instead
Buck Owens
Buck Owens
Today was better
I got the breaker, 35A double pole, I'm supposed to be drawing 22 so, I'm good there. I left the cover off the box and ran it at full bore for 20 minutes it got warm but not hot. I believe, at max it reads at just under 4500 watts, going by memory, I turned it down to read 4200 and went to the ferrule soldering project i finally got the right flux to go with the silver bearing soft solder and IT WORKED. The wife called me in just as the water was starting to make small bubbles at the 50 minute mark.
I shut it all down for the evening.
It's ready for the vinegar run and then I finally get to make use of that overcharred French oak hbb.
I'll get a thumper made and put it all together this week and post some pics.
Thanks again
Thanks again
Buck Owens
Buck Owens
That’s a resistor and it appears to have had too much current run through it. Hope the new one lasts longer.Corn Cracker wrote: ↑Sat Mar 22, 2025 3:05 pm Screenshot_20250322_180227_Gallery.jpg
I've got the replacement regulator ordered…..
I was able to get the vinegar run done today. I modified the top of it, I'll make another one if I want to go with neutrals, I have plenty of extra 2 inch when I'm ready
Working on the thumper still"To ease the pressures of this world here's the way i got it figured, the thing to do for me and you is to drink lots of good corn liquor"
Buck Owens
Buck Owens
Also made a kettle out of another keg i had
Buck Owens
Buck Owens
Off and Racing Corncracker
- Stonecutter
Congratulations Corn Cracker! Looking good
-Thomas Paine
-Thomas Paine
Thanks, I'll be mashing in this weekend
Buck Owens
Buck Owens
- Rusty Ole Bucket
Nice work! Now it's time for a recipe rabbit hole!
Rusty
Rusty
The Horny Goat Build
Electric Boozaloo II Build
I'm going back to the basics, just doing corn for now, it's first bourbon will be a twist on hbb that I made for my daughters wedding a few years ago.
My son in law has introduced me to Dalmore scotch. I really like that, went to buy some
that stuff is EXPENSIVE
Buck Owens
Buck Owens
