Daddy yeast
Corn Cracker
Daddy yeast
Post by Corn Cracker »
I stopped and grabbed a new pouch since it has been so long since I've used what I have in the fridge. I checked it last night and it was 2021 when I got it. I put a little sugar and water in a glass with a little yeast, i checked this morning and it smelled like alcohol. I cant believe its still good after 4 years, now I have a big pouch and ½ a little pouch of it. Im pretty sure my amylase should still be good. Time to get busy.
bilgriss
Re: Daddy yeast
Post by bilgriss »
Yeast will stay dormant for a VERY long time and still be viable, especially if it stays cool and dry. Over time, there will be an increasing number of cells which are no longer good to go, and it may be useful to increase your pitching quantity a bit to compensate. I currently need to buy some yeast, but the small amount of bulk I purchased probably five years ago is still making good bread and drink.
Re: Daddy yeast
Yeast is bull frog tough and daddy has enzymes to convert some of the complex sugar made during mashing into alcohol.
It's a win-win for alcohol production but I think there's better options for taste and whiskey character.
Tammuz
Re: Daddy yeast
Post by Tammuz »
shadylane wrote: ↑Tue Apr 01, 2025 4:01 am Yeast is bull frog tough and daddy has enzymes to convert some of the complex sugar made during mashing into alcohol.
What's your go to yeast for a whiskey?
Re: Daddy yeast
Mostly I use bakers yeast because it's cheap and I can pitch it as is
My 2nd pick is Safale US-05. When using the US-05 I make a starter.
Homebrewer11777
Re: Daddy yeast
Post by Homebrewer11777 »
Can you point at a source that indicates DADY yeast has enzymes? Spec sheet I was able to find only mentions ingredients are Yeast and sorbitan monostearate.
Not doubting there may be better choices for whiskey character but don't believe it is due to enzymes packaged with this yeast.
Re: Daddy yeast
Not additional enzymes but the ability to create natural enzymes to better ferment maltotriose into alcohol.
https://distilling.com/distillermagazin ... ation-101/
"Choosing the right yeast starts with having an understanding of the fermentable substrate you’re working with. For instance, whiskey worts have high levels of maltotriose (~15% of the fermentable sugars). Many standard brewer’s yeasts will not ferment maltotriose, instead leaving it and other higher-weight sugars behind. This is important for beer because these sugars provide valuable residual sweetness (to balance hop bitterness) and mouthfeel properties. However, as distillers, we don’t care about residual sweetness in the beer since it is going to be distilled. Leaving those sugars behind means we’re not getting as much alcohol out of our fermentation as we possibly can. So, whiskey distillers should opt to use yeast that can ferment maltotriose.
Corn Cracker
Re: Daddy yeast
That's a good read with a lot to consider.
contrahead
Re: Daddy yeast
Post by contrahead »
I bought a package of this the other day and am anxious to give it a try. Both for distilling and to prefect my pretzel making endeavors. The package says it's a product of Mexico but the fine print says that it is manufactured for the Lesaffre Corp. of Milwaukee, WI. One pound cost a little over $4.00.
https://lesaffrebaking.com/product/saf- ... igh-power/
Advertising claims for this SAF-Instant - Premium_ High Power yeast include:
- 15 – 30% faster fermentation
- provides larger volume for finished products
- more active than other yeast
- more resistant to cold water
- more resistant to preservatives
We will see...
Omnia mea mecum porto
The Booze Pipe
Re: Daddy yeast
Post by The Booze Pipe »
I've used Redstar DADY for years with good results. It does produce decent esters and congners. I'm sure other yeasts will produce a lot more. But DADY is very tolorent , easy to work with, and ferments dry (as long as the conversion was sufficient).
A couple good take aways from the above article, "higher pitch rates produce lower levels of esters and reduced fruitiness. Lower pitch rates generally increase ester levels in the final wash (and subsequently the final distilled spirit)" I would be curious to see something to back this up.
Something I have been aware of is the fermentation temperature, "is another variable that distillers would do well to pay more attention to,significant impact on distillate character in that higher fermentation temps tend to bring out higher ester levels from the yeast. In some instances, higher temperatures will also reduce diacetyl, one of the compounds responsible for buttery aromas in spirits." Just doing consecutive ferments at different temps has proven this to me. The pitch rate statement I'm not as sure about.
13.5g/50L keg
12,000watts of fury
subbrew
Re: Daddy yeast
Post by subbrew »
The Booze Pipe wrote: ↑Fri Apr 04, 2025 8:28 am
This is common knowledge among beer brewers. The book "yeast" goes into detail. https://www.thriftbooks.com/w/yeast-the ... q=18411987
Corn Cracker
Re: Daddy yeast
Yeah, I didn't know about using the pitching amounts to gain flavor. I've heard too much gives a bad taste. I ferment inside so it's always under 75
Homebrewer11777
Re: Daddy yeast
Corn Cracker wrote: ↑Fri Apr 04, 2025 6:18 pm I ferment inside so it's always under 75
Have you measured the temperature of the fermenting beer? Once it really gets going you could easily be at 85-90F sitting in a 75F room. This might be ok for DADY or bread yeast but would be really hot for most ale yeasts.
Corn Cracker
Re: Daddy yeast
I checked it on the first ferment i ever did, it was within the proper range and i never worried about checking it again. Same house, same room, same menopausal wifey that likes it 72..... max.
That lil room it's in does not have a ac vent so it runs a couple of degrees warmer/colder than the rest of the house
