Clearing Sugar Wash - Are Conical Tanks Effective?
Rusty Ole Bucket
Re: Clearing Sugar Wash - Are Conical Tanks Effective?
Post by Rusty Ole Bucket »
Great idea on the thread fix Salt! That stand is coming along nicely.
Rusty
The Horny Goat Build
Electric Boozaloo II Build
Stags
Post by Stags »
Nice job salty. I look forward to reading your results. I once upon a time looked into this for my whiskies and decided against because while you’re removing flavor I want more 🤣
I know this thread is focused on sugar washes but I feel the need to make a safety call out. For those younger in the hobby who may be reading this- most conical tanks like this have a low temp tolerance. Like 120-140° temp tolerance. So as a safety consideration I’d say please don’t try and mash a grain spirit in a tank like this using boiling water. I like to do almost everything in flip flops and even a slight splash of boiling mash on the toes is unpleasant.
Salt Must Flow
Post by Salt Must Flow »
While waiting for some fittings to arrive, I've been trimming off some fat, filling in all the screw holes with wood filler and sanding.
I intend to spray paint the stand flat black then give everything a coat of a clear Polyaspartic. Just for fun, I plan to coat the top, broadcast these color flakes until rejection, scrape the flakes smooth and seal over top with the Polyaspartic again.
More work to do, but it's coming along. I was worried most about getting the angled supports beneath the conical right, but it went a lot easier than I expected.
Salt Must Flow
Almost all of the fittings arrived so I was able to determine the final height of the legs, complete the woodwork and paint it all flat black.
Now I just need to apply the clear Polyaspartic coating, install the pump, plumbing and the electric.
Salt Must Flow
The clear Polyaspartic went on a bit ripply, but I was glad to get it done.
I applied a coat on the top & the bottom shelf and broadcasted the Color Flakes. Just need to let it cure, remove excess flakes, scrape & sand it relatively smooth and apply 1 or 2 seal coats over top.
Salt Must Flow
Finally finished the coating process. I need to allow the Polyaspartic to cure for a few days otherwise the tank may stick to it.
Nice work. :thumbup:
I don't know how well a conical fermenter is at removing trub but I'm convinced a clear wash is worth the effort.
Salt Must Flow
shadylane wrote: ↑Sat Apr 05, 2025 3:04 pm Nice work. :thumbup:
The trub settles within hours, though I leave it overnight. It doesn't appear to 'stick' so a conical should work just like a Separatory Funnel.
Salt Must Flow
FINALLY FINISHED. I decided not to wait for the coating to fully cure and just finish it up. It rolls around very nicely even when full.
The 2" spigot centers directly over top of a 5 gallon bucket. The 3/4" ball valve leads to the pump.
The switch is wired to the receptacle that the pump is plugged into so I can switch the pump on & off.
Rusty Ole Bucket
That came out cool! Nice job Salty!
Rusty
Salt Must Flow
Rusty Ole Bucket wrote: ↑Sun Apr 06, 2025 4:26 pm That came out cool! Nice job Salty!
Rusty
Thanks! It took some time to complete, but I think I'll appreciate using it. Racking out of 55 gal drums really suck.
Thats going to be a nice time and energy saver long term.
Salt Must Flow
Saltbush Bill wrote: ↑Sun Apr 06, 2025 6:17 pm Thats going to be a nice time and energy saver long term.
I really hope so! I got a decent deal on the tank, but the cost of the casters, fittings and valves started adding up quick. I've had the pump for many years. I was given the Polyaspartic & color flakes a few years ago. I already had the 2x10s and the screws.
I can't wait to start putting it to use.
Salt Must Flow
I heated 1.5 gal of water to 150F, mixed in 210g of Bentonite Clay, mixed it well using a whisk then an immersion blender. Left it sit for at least 30 minutes. Meanwhile I dropped a submersible pond pump inside the 55 gal fermenter and let it run to degas the wash. I dumped the Bentonite Clay slurry into the fermenter and let the pump mix it thoroughly for about 5-10 min. I then used the pond pump connected to a hose to transfer the wash into the Conical Tank.
Here I am transferring the wash into the Conical Tank.
This is what it looked like 25 minutes later.
This is what it looked like 13 hours later.
I think I'm going to let it sit for 4-5 more hours to see if it settles any lower before I drain the trub. So far so good :thumbup:
Last edited by Salt Must Flow on Tue May 06, 2025 6:29 pm, edited 1 time in total.
NorthWoodsAb
Post by NorthWoodsAb »
That turned out very nice. Great job.
Uisge beatha
Salt Must Flow
NorthWoodsAb wrote: ↑Tue May 06, 2025 5:01 pm That turned out very nice. Great job.
Thanks! I drained the trub an hour ago and it worked great. Only the very last little bit appeared to 'stick' and broke off in blobs to drain. I'm hoping that was due to leaving it sit several hours longer than necessary. I'll be filling it up again tonight and will drain it first thing tomorrow to see if the last bit doesn't stick a little or stick less.
Regardless of what happens, I call it a success because the trub was so easy to separate and what transferred to the boiler was much clearer than I've been able to do in the past.
Salt Must Flow
This is the 2nd 50 gal fermentation. I left it to clear for 12 hrs then drained the trub. Sorry for the blurry pic, but if you look close you can see some of the trub wanted to clink to the very bottom of the cone. It's so very little that it's insignificant.
I think the very last bit is getting hung up due to the change of angle as shown in the tank's official diagram:
It started as a 50 gal fermentation and after draining the trub, I lost approx 5 gallons.
In the future I'm going to start testing using less Bentonite Clay to see if that reduces the overall amount of Trub. I may even try using a different flocculant and see if it lessens waste too.
Last edited by Salt Must Flow on Thu May 08, 2025 11:39 am, edited 2 times in total.
Thanks for this topic SMF and I love the back light so we can clearly see the levels .
But my initial thought was why is he loosing so much ? 5 gal from a 50 gal sugar wash is insane to me . I see that the Bentonite is quickly clearing the wash but the losses are so much compared to if I just let mine sit for a week or two . I’d be luck to have an inch or two at the most of caked trub at the bottom of my 200litre barrel .
I’d be interested to see if you fermented in the conical and let it settle without Bentonite if you can do much better .
I tried using Bentonite a couple of times when making wines and found a similar thing . Quick clearing , but a layer of flocked crap ar the bottom which wasted a lot of wine .
Salt Must Flow
Yummyrum wrote: ↑Wed May 07, 2025 1:11 pm Thanks for this topic SMF and I love the back light so we can clearly see the levels .
Yeah it is a trade-off. Everywhere I've read also says that the #1 drawback to using Bentonite Clay is the amount of loss with the Trub. Most people I've communicated with that own conical fermenters say that if they let it clear by itself over time, the yeast cakes quite densely and 'STICKS' to the walls of the conical. I guess that's might not be such a bad thing as long as it stays put while the tank is pumped dry and can be hosed out relatively easily.
I know of a big company that buys a lot of some type of flocculant, but they use it to separate particulates from water after grinding concrete floors. I'll have to see if it would be hazardous for our use.
It's been fun to use and has made the chore MUCH easier.
Salt Must Flow wrote: ↑Wed May 07, 2025 1:50 pm the yeast cakes quite densely and 'STICKS' to the walls of the conical
I find that even with my 200L flat bottom stainless fermenter drum that this happens. I can then pour all but a couple of liters off through the tap without getting unwanted trub/yeast mixing into the clean wash.
