Build up in column, concerning?
realestwhiteboy
Post by realestwhiteboy »
I have had this column for over 2 years, previously using on the top of a 8-gal pot. However, this was my first stripping run on a new 15.5-gal half barrel keg still with a 7.75-gal quarter barrel keg as a thumper. The thumper was not hooked up for this first run, but it was for my 2 cycles of cleaning runs.
It's a 2" by 2.5' copper column that is attached to the top of the keg with a tri-clamp using a PTFE gasket. The column is made of a 2" copper pipe that is silver soldered to a copper fitting that matches the top of the keg. When using it with the pot still, we never saw this. 2 squirts of the water hose and it was cleaned (what is seen at the end of the pipe in that image is the reflection from the flash on my camera).
This was a stripping run, doing the spirit run tomorrow (with thumper charged). Wanted to make sure this wasn't something concerning?
Re: Build up in column, concerning?
It's not a column, columns are tall and are packed with something and are not what you have.
Run it and do a good job of the cuts.
realestwhiteboy
NZChris wrote: ↑Fri Apr 04, 2025 9:27 pm It's not a column, columns are tall and are packed with something and are not what you have.
Ahh, I thought a "column" was any copper cylinder coming off the main boiler, so a column requires packing/plates? A new wrinkle in my brain. :ebiggrin:
NZChris wrote: ↑Fri Apr 04, 2025 9:27 pm Run it and do a good job of the cuts.
Sounds like the silver colored build up isn't a concern. Was new to me, so I figured better safe than sorry. Glad I asked. Thanks, will have a peace of mind during the run tomorrow.
The silver, oily, color is often just an oil and water refraction of light effect, easily wiped off. Taste it, it might be nasty and line your lungs with fusel tastes for a while.
realestwhiteboy wrote: ↑Fri Apr 04, 2025 9:52 pm
I don't know what the silver stuff was in the riser.
I don’t understand what this twisty stuff is ?
Most of the stinky fusels get refluxed back down into the boiler with each stripping run before the foreshot is taken. If you are trying to cheat by skipping the stripping run or the foreshot, or by not cleaning your condenser after the stripping runs, you might get caught out.
realestwhiteboy
NZChris wrote: ↑Fri Apr 04, 2025 10:48 pm Most of the stinky fusels get refluxed back down into the boiler with each stripping run before the foreshot is taken. If you are trying to cheat by skipping the stripping run or the foreshot, or by not cleaning your condenser after the stripping runs, you might get caught out.
This was the first stripping run, and I spray the copper and clean the pots between each run. I also cut 50ml of foreshots per gallon on each run.
However, this is also my first flaked corn run, I normally run a lot of sugar washes. So I was in less familiar territory to begin with.
realestwhiteboy
Yummyrum wrote: ↑Fri Apr 04, 2025 10:41 pm I don’t understand what this twisty stuff is ?
My question as well. Never seen that before. The sips from the stripping run tasted great, so i was surprised to see that during cleanup.
I don't clean anything between strips unless I really need to. Dump, refill and turn the heat on. If there is trub in the boiler, I hose it out before recharging.
realestwhiteboy
NZChris wrote: ↑Fri Apr 04, 2025 11:04 pm I don't clean anything between strips unless I really need to. Dump, refill and turn the heat on. If there is trub in the boiler, I hose it out before recharging.
My hose is outside the door of the room I distill in, so i normally spray the copper out before and after each run (city water), so maybe overkill? I also dump a few gallons in the pot and toss in the tub before each run. Try to make sure the ball valve is draining clear liquid before I charge it.
Overkill compared to mine, a Charentais preheater setup that I built as a newbie. Dump, refill, run, repeat, until I run out of wash. I don't take the still head off for cleaning between strips.
greggn
Post by greggn »
realestwhiteboy wrote: ↑Fri Apr 04, 2025 11:08 pm
Do I understand correctly that you add the trub from your fermenter into your still boiler and then begin a distilling run ?
If the above is correct then I think the "twisty stuff" is essentially "bread." The trub, yeast and grain bits, have been baked into the riser.
________________
greggn wrote: ↑Tue Apr 08, 2025 9:29 am
:shock:
Lord :shock:
Imagine that happening in a Vevor still with a 1/4” gasket hole .
realestwhiteboy
Nah, I don't toss in any trub. Filtering that out is the hardest part of my day. LOL I was talking about before charging the boiler and assembling everything, I always rinse all the equipment in the tub to begin.
realestwhiteboy
Yummyrum wrote: ↑Tue Apr 08, 2025 5:23 pm
:shock:
Lord :shock:
You're going to trigger my PTSD just mentioning Vevor. :lol: That is where I started, until I got on here and found what a mistake I had made. I still have all of it in my distilling room, just to remind me things could be worse when something goes wrong. 16 hour distilling days trying to get something out of that microscopic copper with a cooler and who knows how much ice trying to keep the condenser halfway cool.
Didn't take long for my to learn how to silver solder and move on from that thing ... 3 builds later, I think I'm finally at the one I'll keep around for awhile. :thumbup:
greggn
Post by greggn »
realestwhiteboy wrote: ↑Mon Apr 28, 2025 6:14 pm
What is the purpose of that process ?
________________
