Soldering copper to stainless steel
Post your builds here.
Corn Cracker
Post by Corn Cracker »
I finally got the right flux(thanks for the suggestions), it says it works with any solder to make a solid joint, it was 6 bucks at the a/c supply for a small bottle. I used the sterling solder which is a typical solder for copper. It held strong
Harris stay clean liquid flux and any plumbing solder
Pic turned, 🤷‍♂️
MOD EDIT : I had to , it was hurting my neck
Corn Cracker
Re: Soldering copper to stainless steel
I made this post so that other folks can search it and get straight to the info, I dug around for a while looking
acfixer69
Post by acfixer69 »
That solder is not a mgf recommended soldering for dissimilar metals SS /copper. I would advise you to do a leak check after a few boiler runs. After the different rate of expansion due to heat the metals and lack of proper wetting, it is likely to crack at the SS seam. I've seen this many times. A silver bearing solder is required per reliable mgfs.
Corn Cracker
Global mod, damn!
point taken.
I've been doing industrial plumbing for over 20 years, I've never heard that before although, it has been mentioned here at least twice since ive been trying to do this, that some folks here use that flux with regular plumbing solder with good results.
Sorry for the confusion, delete the post if you would
acfixer69
Post by acfixer69 »
No need to delete that flux works with all solder I have used as you mentioned. However the solder is for typical plumbing joints, copper to copper or copper to brass. For copper to SS or carbon steel it needs some silver to wet proper. Been that way all my 50+years in the trade even the 10 years in Texas.
Posted as a member. Mod is for back room, out here all equal
Corn Cracker
I understand your point of the thermal expansion of different metals, thanks.
As far as structural strength of that butt joint, it's really strong, I tried to break it, it wouldnt.
acfixer69 wrote: ↑Thu Apr 10, 2025 3:05 pm For copper to SS or carbon steel it needs some silver to wet proper.
Based on my limited experience, the higher the silver content the easier it is.
https://weldingproperty.com/brazing-cop ... ss%20steel.
acfixer69
Post by acfixer69 »
shadylane wrote: ↑Thu Apr 10, 2025 5:32 pm
That's true for brazing but for soldering some 6%,7% is fine
Corn Cracker
I'm stopping back at the ac supply house today to get a roll of silver solder and some medium temp brazing rods. I can get stuff on a cash ticket through the company account and that drastically reduces pricing.
Steve Broady
Post by Steve Broady »
That joint looks good to me. I’ve made several things using lead free plumbing solder and that flux, and so far the only joint that I’ve had fail was a butt joint between a stainless ferrule and a very thin stainless pot lid, where I’d hung way too much weight off the end and loaded the joint sideways. It finally cracked and broke on me, so I resoldered it with a copper flange to connect the two and it’s still going strong today. A thin layer of solder that’s in tension, has the absolute minimum surface area possible between parts, and subject to regular flexing is pretty much the worst case scenario and I’m not at all surprised that it failed. I find that flagged or overlapped joints where the solder is in sheer to be a lot more reliable - which is just good practice in general, to be honest.
Not trying to argue with an expert, but in my somewhat limited experience that solder will make a serviceable joint between copper and stainless as long as it’s done well in the first place, the joint has at least a little mechanical integrity of its own (I always flange thin parts now, or use copper rivets), and you don’t severely strain the joint while it’s in use. It’s not the strongest possible way to join two pieces of metal, but it seems more than strong enough for our purposes on 99% of the things we’d need it to do in this hobby. Maybe time will change that opinion.
And yeah, it can be a pain to get that stuff to wet out on stainless steel. Careful heat control, immaculate preparation, and brushing with flux while its molten all seem to help a lot.
Rusty Ole Bucket
Post by Rusty Ole Bucket »
Corn Cracker wrote: ↑Fri Apr 11, 2025 12:45 am I'm stopping back at the ac supply house today to get a roll of silver solder and some medium temp brazing rods. I can get stuff on a cash ticket through the company account and that drastically reduces pricing.
I just did a bunch of stainless ferrules to 2" copper and a 6" stainless ferrule to a stainless keg top. I used Harris Stay Clean flux and Harris #8 solder and it worked great. Not to mention the copper to copper stuff was effortless with a little heat management using Harris products. I did a bunch of research here and talking with some of the long time members and that's the magic combo, after doing it, I would have to agree. I used Oatey plumbing stuff for my initial build, but the Harris stuff is worth the extra bucks in my opinion.
Rusty
The Horny Goat Build
Electric Boozaloo II Build
Corn Cracker
I'm finding whether soldering or brazing copper to stainless, the flame really doesn't need to be put directly on the stainless too much at all, start heating a couole of inches up on the copper and work it down to the stainless, it gets hot as the copper heats up and if brazing with higher temp rods, introduce the rod to the flame to heat it up before brazing
shadylane wrote: ↑Thu Apr 10, 2025 5:32 pm Based on my limited experience, the higher the silver content the easier it is.
Based on my experience that is 100% correct Shady, i think what is referred to in America as brazing is what us Aussies call hard solder.
It comes in sticks with varying percentages of silver in its make-up.
The higer the silver content the higher the purchase price.
Once youve used the higher silver content stuff and seen how easy it is to use you dont quibble of the few extra bucks spent.
Corn Cracker
Correct we call it brazing rods, comes in sticks, takes high heat and soft solder is in a roll and pools at low temps
Corn Cracker wrote: ↑Sat Jun 21, 2025 6:41 am Correct we call it brazing rods, comes in sticks, takes high heat and soft solder is in a roll and pools at low temps
Sounds correct to me.
Also each has a different flux requirement, so the flux doesn't over heat, burn and get in the way of the melted rod or solder bonding to the base metal. There's differences on the protocol between higher temp brazing and lower temp soldering.
Swedish Pride
Post by Swedish Pride »
Good job CC, feels good making it yourself doesn't it.
I've built all my stills with plain old lead free solder, it's plenty strong for our applications.
Don't be a dick
MooseMan
Post by MooseMan »
I struggled with stainless soldering for ages and drove myself crazy, then got some cheap Chinese flux for the job, and it's suddenly just as easy as soldering copper!
Now you've got the confidence doing it Corn Cracker, you'll be "Looking" for stuff to join together! 😀
Corn Cracker
It's amazing how a little difference in the flux formula makes or breaks a solder joint and the silver content making a difference in the structural integrity. Ive been plumbing for over 20 years and never knew that brazing or soldering other metals than copper or brass were so tricky
For the Kiwis and Aussies
I find it amusing that the bottle of flux I bought when I was a teenager in New Zealand ( Duzzall…. Because it literally Does all) is still working today almost 45 years later .
This the stuff
Bakers flux from Bunnings does the same job . I really don’t know why folk have such a problem soldering stainless .Mostly I put it down to too much heat .
https://www.bunnings.com.au/cagroup-250 ... bRzzxOLQ1W
This Solder works for the folk down under .
https://www.bunnings.com.au/consolidate ... r_p5060362?
And you might think …… heck thats expensive for a reel of solder ….. but then , a decade later when you are on your third reel , then you realise …. It is what it is …….
Corn Cracker
I paid $97US for this roll
And another 5 for this
Thers is still enough of each left for at least 2 more builds
Corn Cracker
Not sure why it posted the solder twice
Corn Cracker wrote: ↑Mon Jun 23, 2025 6:40 am Not sure why it posted the solder twice
You clicked “place inline” twice on the solder , the flux pic just displayed at the end because you didn’t specify a place inline for it .
I also rotated your pics while I was at it Corny
Corn Cracker
Thanks buddy
No worries .
Yeah those prices are pretty much inline with what we pay here .
But as you said, they go a long way . I found if I soldered in bare feet , I used less Solder .
Corn Cracker
Yummyrum wrote: ↑Mon Jun 23, 2025 1:29 pm No worries .
I'll have to try that 😆 🤣
