Barrel Thief Leaking
Bee
Post by Bee »
I think the tip of this barrel thief is too big. Any ideas how to squeeze it down?
It leaks a lot when I pull it out of a barrel.
acfixer69
Re: Barrel Thief LeakingAre you
Post by acfixer69 »
Are you sure it's not leaking air in from the connections? To reduce the fitting put a nail the diameter you want and just pinch it down with pliers, solder the seam or not.
Steve Broady
Post by Steve Broady »
I’m sorry to be no help, but this does bring up an interesting question. Is there an ideal size for the tip of a thief?
subbrew
Post by subbrew »
Is the tip a size you can get a copper cap for it? If so you could put a cap on it, drill a hole in the cap and test until you get the hole too large. Then put on a new cap and drill in the last size hole that worked.
OtisT
Post by OtisT »
You could solder a smaller copper tube, about 1/2’ long, inside the opening of the last reducer. Like a sleeve lining. This will create a longer hole than just drilling a hole in a new cap, which I think would help with the surface tension issue. If that new tubing hole is to small, it can be drilled out to something inbetween the original and new size.
MooseMan
Post by MooseMan »
Dumb question Bee, but are you sure you're getting a good seal with your thumb as you lift it out of the product?
greggn
Post by greggn »
Put a nail in the tip and gently hammer the tip around the nail to form a smaller diameter. Then remove nail.
________________
