Brew Belt ?
sadie33
Brew Belt ?
Post by sadie33 »
I am planning on running my UJSSM all summer long (I have never fermented in the summer). It is only in the 40's right now and I am going crazy wanting to run my UJSSM that has been sitting for bit, but want to start the next ferment. I was looking into the brew belts and thought I would get a couple of those. I did a bunch of reading on how many people keep their ferments warm and this is the route I think I want to take.
Before I actually buy a couple on line (I have no local supply stores) I was wondering if there are some better than others?
thanks
Northsouth
Re: Brew Belt ?
Post by Northsouth »
I have experienced that most suppliers of that, and alot of other things like tools, etc. Is shi.. This has made me adopt the following strategy: If it is all shi.. better cheap shi.. than expensive shi... Have a cheap silicone one from Aliexpress, it is shi.., temperature "sensor" and actual performance is way off, but you can learn what is the correct setting, and it will do it for you eventually.
SW_Shiner
Re: Brew Belt ?
Post by SW_Shiner »
I like brew belts for their ease of use. I just got another one to add to my setup.
I first had a little cheap brew belt which worked fine, but i just recently got a ULWD one for a little more piece of mind. Paired with a controller and digital hydrometer and my ferments are now happy as ever, and i dont have to disturb the ferment to check if its done or not.
IAmPistolPete
Re: Brew Belt ?
Post by IAmPistolPete »
Yes I understand New England winters... :)
I started out with a couple of these when I ferm'd in my basement. Short money & fairly efficient when I just needed a boost. Just covered with a sweatshirt over it.
https://www.amazon.com/BN-LINK-Durable- ... 9hdGY&th=1
For more control I upgraded to these... [also insulated with random clothing] a few bucks more but better for my rum washes.
https://www.amazon.com/Kenley-Fermentat ... hdGY&psc=1
If you ever find yourself being chased by a pack of wild taxidermists, do not play dead.
subbrew
Re: Brew Belt ?
Post by subbrew »
might not save money, but for beer brewing I have used a temp controller, tub of water and a fish tank heater for years. I probably have $25 in the temp controller for the controller, outlet and box. And $8 or so in a laundry tub. I like the extra thermal mass supplied by the tub of water, it helps keep a steady temp. And if you have shifting temps, i.e. warm days a cool nights you can just drop in a frozen water bottle on during the heat of the day to keep temps from increasing much.
Reefer1
Re: Brew Belt ?
Post by Reefer1 »
Ye +1 on the fishtank heater, I use a couple connected to a controller and I made some insulation jackets for my 2 fermenters from that bubble wrap stuff that has the foil coating, sort of thing you put behind the household radiators, that stuff works well, sometimes too well.
howie
Re: Brew Belt ?
Post by howie »
i have 4 x 25L brews on as we speak.
they are in 2 x old fridges connected to 2 x Inkbird wifi controllers, both with a 30w belt hanging in both fridges.
i monitor & control both fridges via a mobile app.
TBH it's a set and forget system.
potstill-distiller
Re: Brew Belt ?
Post by potstill-distiller »
I couldn't agree with you more
Re: Brew Belt ?
Controlling the temp really helps yeast get the job done consistently.
The only failures I've had was due to forgetting to put the temp probe back in after removing the fermenter lid to have a look.
Big time over heat and it was my fault. :oops:
howie
Re: Brew Belt ?
Post by howie »
shadylane wrote: ↑Mon May 26, 2025 6:28 pm Controlling the temp really helps yeast get the job done consistently.
i don't know if it's any help, but i've duct taped a 3" square piece of insulation to my fermenters.
only taped the sides and bottom, leaving a pocket to put the probe in.
Re: Brew Belt ?
Heat rises. Check that the bottom of the fermenter isn't in a cold layer below the heat belt or aquarium heater. I have only ever heated from underneath fermenters.
I always have a thermometer in addition to the controller. Doing that has saved me from 'cooking' a wash when a controller thermocouple got knocked out of a fermenter.
My heating elements are always only slightly more Watts than needed, which means that controller failures or my mistakes are unlikely to turn into disasters before the next check.
Some controllers can control both heating and cooling. I often connect a fan pointed at the fermenter, especially for rum ferments in summer.
PalCabral
Re: Brew Belt ?
Post by PalCabral »
I use heat belts. In this arctic country it's the best way for me to ensure temps at 30C or thereabouts. The drawback is that you can't exactly control the heat, as they are 100% or nothing, but you can control the energy going into them and thus adjust how hard they go. I use them all the time as 30C temps here are not that common.
Pure Old Possum Piss
Re: Brew Belt ?
Post by Pure Old Possum Piss »
Last edited by Pure Old Possum Piss on Fri May 30, 2025 2:25 pm, edited 1 time in total.
Re: Brew Belt ?
sadie33 wrote: ↑Sun May 25, 2025 8:02 am I am planning on running my UJSSM all summer long (I have never fermented in the summer). It is only in the 40's right now and I am going crazy wanting to run my UJSSM that has been sitting for bit, but want to start the next ferment. I was looking into the brew belts and thought I would get a couple of those. I did a bunch of reading on how many people keep their ferments warm and this is the route I think I want to take.
thanks
They make these to fit from 55gal drums down to 5gal buckets. I'd test it with water and a second thermometer to make sure it's accurate. If you've got steel barrels with use it to mash with. Dial in the temp for 30C/85F to 350c/600f.
I just turn mine low as it'll go and it usually keeps it from about 80'85F.
Edit: I can't get it to post a link either.
sadie33
Re: Brew Belt ?
Post by sadie33 »
Thanks for all the input!! I did think about the fish tank heater as I have some kicking around, but I hate to say it, I like the look of the heat belt better. It's gonna be in my living room and I want it to look nice (I know sounds stupid, but it matters to me). Once the summer hits I won't need it. I ordered 2 so I can keep my UJSSM going, but I also need to get a HBB going so I can top off my keg.
Thanks again for the help, I'll let you know how it works.
sadie33
Re: Brew Belt ?
Post by sadie33 »
I got my brew belts :D When I had this idea of stillin' all summer long it was in the 40s. Today is 90* and I don't know what part of me thought l could boil water and mash in this kind of heat. :roll: It will get cooler at night, but I don't know about this...I hate getting a new toy and not being able to play with it!! I'm going away this weekend so I won't start anything till I get home. Temps are gonna drop the next couple days (I think). I'll let you know how it goes.
andystanton74
Re: Brew Belt ?
Post by andystanton74 »
I use seedling mat duct tape to the side of the fermenter. Probably cheaper than a brew belt and works well. Use an ink bird controller and wrap the fermenter with bubble double reflective insulation
subbrew
Re: Brew Belt ?
Post by subbrew »
Although I know some people do I would never use an aquarium controller directly in the mash. It is too thick and will not get good heat dispersion. When I mentioned an aquarium heater it was to heat the hot water bath the fermenter was sitting in.
SW_Shiner
Re: Brew Belt ?
Post by SW_Shiner »
sadie33 wrote: ↑Sat May 31, 2025 5:29 pm I did think about the fish tank heater as I have some kicking around,
I used to use an aquarium heater until i read this. Now i use brew belts, or just insulation.
