Advice sought on AliExpress CM column / Keg boiler build
Weka
Post by Weka »
I am looking at getting back into distilling, I intend to make a neutral spirit which I will mostly be ageing. I was hoping on some advice and criticism before pulling the trigger. This post will cover some stuff outside of columns but I figured since that is mostly what this thread is about this was the right spot for it.
So I think I have my plans for a still all set, I intend on buying the following column from the Ali Express store Yohoyama. It is a 2" SS column with shotgun condensors for the product condensor and the dephlegmator.
The product condensor:
Now I know CM has a little bit of a bad rep here but it would be easy to convert this to a CCVM with the addition of a 'T' shaped fitting and I think it would still work out near the cheapest way of making such a CCVM still for me. It also gives me the option of using both condensors inline as product condensors in a future 3"-4" CCVM build.
I will of course replace all gaskets with ptfe. Does anyone have experience with or opinions about Ali Express ptfe? Best price I have found them in NZ from a more reputable supplier is $20 USD each.
Thinking about buying a sight glass which will be useful both to monitor puking on stripping runs and to increase the height of the refluxing portion of the column during reflux runs to something closer to 20:1. How are they sealed, bare metal to the borosillicate? Are they OK to pack, it won't cause too much temperature variation in the glass having copper touching it in places?
https://vi.aliexpress.com/item/4000195764404.html
For packing I plan on buying 15m of 127mm copper mesh.
This is a summation of the article "The Impact of Copper in Different Parts of Malt Whisky Pot Stills on New Make Spirit Composition and Aroma" which I found in "Whisky Science: A Condensed Distillation" by Gregory H Miller.
So what I am getting from this is that I should leave my packing in for stripping runs?
For cooling water I have a 5000 litre tank of water that is pumped to a holding tank in the roof of my house, which feeds out via gravity. I figure this will provide both a constant temperature (if I purge the holding tank first) and constant pressure.
Water to the reflux condensor will be controlled by one of these flow meter valves.
I think I will control the flow of water to the PC with this little push connect valve. There are cheaper versions but this is the only one I could find that says it is good for water.
https://vi.aliexpress.com/item/1005007943540182.html
I plan on measuring coolant water temperature going in and out of each condensor with some cheap electric probe thermometers that read to a tenth of a degree celsius. I thought anything more sensitive would be pointless. Just another data point.
I plan on clamping the whole thing to a keg. For now the only hole I want to put in the keg is for an element, as I plan on distilling only neutral and figure a water blaster (power washer) will suit my cleaning requirements. I am looking at one of these kegland elements because while they are significantly more expensive than comparable offerings the screw threads face the opposite way so they are easier to install. They are 300mm long and run at 2200 watts, so a little under 10 amps on standard NZ 230v power. I am thinking that one of these will be adequate.
https://vi.aliexpress.com/item/4001084195651.html
The other option is to have a 4" tri clover ferule welded to the keg and use a generic element at half the price. If I do go this route I see it as I have two options. One is to place the 4" ferule on the bottom of the keg in the middle, flip the keg over and use the original port as a drain, attaching the column with a reducer. Two is to place it off centre on the top, using it as a fill and cleaning port.
My plan is to use one of these generic 4000W SCRs to moderate power levels. Initially I will just use a multimeter to do some testing then run it largely unmonitored, but eventually I will slap it into a box with a voltmeter and ammeter. I will keep a spare on hand. Not sure if I should ground the chassis.
https://vi.aliexpress.com/item/1005009056986325.html
Thoughts? Any criticisms of this plan will be welcomed.
My specific questions were:
How are sight glasses sealed? Are they OK to pack?
To convert stinky sulphur compounds, am I best to make my stripping runs with the copper mesh packing in place?
Re: Advice sought on AliExpress CM column / Keg boiler build
The still and components look well build and usable.
As to copper it's probably going to take lots more than 15m of 127mm copper mesh to pack the column.
Since the best place for copper is in the pot, I'd also throw a handful of wadded up copper in the SS boiler.
Weka wrote: ↑Wed Jun 04, 2025 1:27 pm
The site glass is sealed with silicon gaskets, wrap a thin layer of PTFE tape around them.
If you turn off the reflux and leave the packing in while stripping, be careful that about the mash foaming up and puking.
Without any reflux raining down to rinse off the packing, a puke makes a mess. :lol:
As to packing the site glass, that would get you another plates worth of distillation.
For stripping I'd have the glass on top of the boiler so any foam would be visible and the power could be turned down.
For running reflux, I'd have the glass between the column and defleg to keep an eye out for flooding.
If flooding begins, turn down the power and/or increase the takeoff rate.
Weka
Post by Weka »
That's a good idea regarding copper in the pot.
As to how much mesh, I've struggled to find anything clear but what I have seen suggests maybe a little over a meter of mesh will make 2" roll. Any clues as to how much more I will need?
I know others here have had success wrapping gaskets in ptfe tape but I am uncomfortable with even that much silicone. It looks like ptfe replacements are available.
https://vi.aliexpress.com/item/1005003592010091.html
As far as stripping with packing in goes, my intention is to remove the packing from the sight glass for stripping, so that will give me a little leeway to monitor puking.
Thank you Shady, very helpful stuff
SW_Shiner
Post by SW_Shiner »
Looks like a good option.
I've had good luck with PTFE gaskets off ali, well with everything from there. One thing to watch for though, is dimensions. Hopefully the listing has a pic of how they measure. Some seem to list them by actual OD, not by the size of ferrule they fit. I ordered a few 54mm gaskets only to find out after receiving them that they had listed the OD dimension and the 2"OD gasket i got is for a 1.5" ferrule.
Weka wrote: ↑Wed Jun 04, 2025 3:04 pm
Hopefully someone who runs a 2" column will chime in about how much mesh will be needed.
Just guessing I'd say 3X as much as your planning on.
Turbo6ta
Post by Turbo6ta »
That diagram you posted is basically the same as to what I just put together except I don't have anywhere near as long of a 2" pipe in the column as you have.
The valves on my setup is so I can run it either as a simple pot still by closing the coolant water valves going to the dephlegmator in the column or if I open the valves, I can run it in reflux whereas coolant water goes to both the dephlegmator in the column and the shotgun (product) condenser.
This is just a small 5 gallon pot setup.
Not wanting to highjack but, I'd plumb the cooling water different.
Turbo6ta
Post by Turbo6ta »
shadylane ... Yup, that's a good idea you have.
howie
Post by howie »
Weka wrote: ↑Wed Jun 04, 2025 3:04 pm That's a good idea regarding copper in the pot.
those gaskets are flat, not triclover.
these look ok (i got mine from Ali)
https://www.aliexpress.com/item/1005004 ... ry_from%3A
as for copper mesh....
the 500gm rolls i get are 9m long x 100mm wide.
9m will get you 4 x 2.25m long pieces which will wrap perfectly for a 2" column.
so that will fill 400mm of the column.
the rest of my column is stuffed with about 15 x mr clean SS scrubs
https://www.bunnings.com.au/mr-clean-tu ... s_p4465903
for stripping, i only have 2 x 100mm copper mesh in the column.
this greatly improves the sulphur removal.
insulation is from clark rubber, their 51mm pulls over the 2" column for easy install and removal.
https://www.clarkrubber.com.au/products ... FtbStJRA==
Weka
Post by Weka »
shady hijack away by all means
howie wrote: ↑Wed Jun 04, 2025 8:15 pm those gaskets are flat, not triclover.
I am specifically talking about the internal gaskets of the sight glass, not the gaskets used to join it to the rest of the column. I don't know obviously having just found out these exist today but I think they are flat, still dragon carries flat ones, although I found a local place with shaped ones with a second gasket that looks like viton or something. I am guessing it sits behind the ptfe to provide a little more give.
As for copper mesh...
That is very helpful thank you. Where do you get your mesh so I can try compare?
Tammuz
Post by Tammuz »
I don't believe you mentioned the size of your keg. Your element might be a bit low for fast stripping runs.
Salt Must Flow
Post by Salt Must Flow »
I've always used a 240V 5500W Wavy, Fold-Back, Ultra Low Watt Density elements and with a controller, you can operate at any level of power. I use Dernord elements from Amazon. These are the ones I've been using.
I second what SMF said.
A cartridge element has less surface area than a Fold-Back, Ultra Low Watt Density element.
Long story short when running a mash the cartridge is more likely to scorch.
I use the 4500w version of the heaters.
SW_Shiner
Post by SW_Shiner »
If you have a sparky mate, or are comfortable with electrical stuff yourself, its possible that the outlet you're planning on using is actually wired to handle more than the 10 amps the plug is rated for. This was the case with me and he was able to swap out the double 10A outlet for a single 15A one. This lets me go up to 3600w, but i currently only use 3000w. The element i have is a 9kw, but it has three 3kw 'loops' that can be separated and run individually. At the moment i have just one loop wired but the plan is to get another 15A socket and put another tail on element to have one loop on controller and one that can be turned on for heatup and stripping.
Swedish Pride
Post by Swedish Pride »
Get a 10 kw SCR thy cost like a tenner more and will suit your next build as well.
Upgrade the flow valve to be at least 2.5 l per hour, 1l is not enough
Don't be a dick
SW_Shiner wrote: ↑Wed Jun 04, 2025 3:06 pm. I ordered a few 54mm gaskets only to find out after receiving them that they had listed the OD dimension and the 2"OD gasket i got is for a 1.5" ferrule.
Same here SW_Shiner . Fell or that . I ended up with a 1.5” sightglass instead of 2”
For now the only hole I want to put in the keg is for an element, as I plan on distilling only neutral..... I am looking at one of these kegland elements because while they are significantly more expensive than comparable offerings the screw threads face the opposite way so they are easier to install. They are 300mm long and run at 2200 watts, so a little under 10 amps on standard NZ 230v power.
I missed the standard NZ 230v power when I suggested a heater that draws more amps than you have available. :oops:
The 2200w heater in your pic would work fine for what you need.
If your making neutral from a sugar wash there shouldn't be any stinky sulfur, only stinky dirty socks tails.
Weka
Post by Weka »
Tammuz wrote: ↑Thu Jun 05, 2025 6:53 am I don't believe you mentioned the size of your keg. Your element might be a bit low for fast stripping runs.
Sorry, 50L.
I had wondered if it would have enough juice. My thinking was I could always install another but if I think I will need more power I think I will lean towards two 2200w elements and run them from seperate power points and plug the SCR into one and switch the other manually. This pushes the economics in favour of having a 4" tri clover welded so I can use the cheaper elements where the nut sits inside the keg. Which is a win for getting what I want triumphing over my tight purse strings so thanks mate.
Salt Must Flow wrote: ↑Thu Jun 05, 2025 9:30 am I've always used a 240V 5500W Wavy, Fold-Back, Ultra Low Watt Density elements and with a controller, you can operate at any level of power. I use Dernord elements from Amazon. These are the ones I've been using.
It's hard to say but I think the element I posted has a lower watt density. This looks to be about 500mm (20") long following the wave, if you get what I am saying. I did a little maths, with a figure of 600mm x 4 for the total length of the element for a bit of leeway.
Watts per square meter = W / (length x circumference) = W / (m x (2πr))
Your dernod element
5500/(2.4*(2*pi*.004))
= 91183 w/m^2
kegland's element
2200/(.3*(2*pi*.0125))
= 93371 w/m^2
So the dernod would have a slightly lower watt density if it was a total of 2.4m long, but I doubt it is.
It's unintuitive but there you go.
I also prefer cartridge elements because they are easier to clean and multiple smaller elements because it makes it cheaper to buy a controller, which seems to be the part more likely to fail.
Swedish Pride wrote: ↑Thu Jun 05, 2025 1:10 pm Upgrade the flow valve to be at least 2.5 l per hour, 1l is not enough
Noted, cheers.
SW_Shiner
Post by SW_Shiner »
2200w should be fine for running 2". I ran a 2200w element in my keg for years. Just a normal hot water cylinder one as they are easy to replace if need be by screwing in from the outside, and they're like $20-$30. I highly recommend insulation if you can. Heating up a full charge can take 2-3 hours depending on time of day/year and multiple other factors.
howie
Post by howie »
[/quote]
[/quote]
shady
when stripping FFVs, i started to place a couple of rolls of copper in the vapour path.
it made a noticeable difference to the smell of the low wines, especially the 'heads' and the overall smell of the low wines.
i presumed it was sulphur being removed.
Salt Must Flow
Weka wrote: ↑Thu Jun 05, 2025 6:48 pm
Your dernod element
= 91183 w/m^2
kegland's element
= 93371 w/m^2
Since you broke out the math, just for fun I measured the length of the Dernord element. It's actually 762mm long and the element is 8mm in diameter.
MooseMan
Post by MooseMan »
Whichever way you go based on your available power Weka, I'd highly recommend you get either a second element at ~2Kw so that you can run both on full for heating up and stripping, or get a multi loop element as SW_Shiner mentioned, which is basically the same.
A 10kw Chinese voltage controller on one element/loop and you're sorted.
Long slow strips, and boiler charges taking hours to even get to boil temps, will get really old, really quick, with 2kw.
Insulating the hell out of the boiler, and everything up to just before the condenser will help speed things up a little.
MooseMan
Post by MooseMan »
SW_Shiner wrote: ↑Thu Jun 05, 2025 12:15 pm If you have a sparky mate, or are comfortable with electrical stuff yourself, its possible that the outlet you're planning on using is actually wired to handle more than the 10 amps the plug is rated for. This was the case with me and he was able to swap out the double 10A outlet for a single 15A one. This lets me go up to 3600w, but i currently only use 3000w. The element i have is a 9kw, but it has three 3kw 'loops' that can be separated and run individually. At the moment i have just one loop wired but the plan is to get another 15A socket and put another tail on element to have one loop on controller and one that can be turned on for heatup and stripping.
SW_Shiner, still on topic as it may help the OP but directed to you and the type of element you have.
I actually have the same type, but with 3x2kw loops.
As I'm not a sparky, I put out a plea for help here and got some amazing input that might be of interest to you.
Search for 9kw element and you should find my thread. (I was told by the guy who gave them to me, that they were 9kw but found out they were 6)
SW_Shiner
Post by SW_Shiner »
MooseMan wrote: ↑Thu Jun 05, 2025 10:09 pm
That thread is the reason why i got this element in the first place. :D
MooseMan
Post by MooseMan »
SW_Shiner wrote: ↑Fri Jun 06, 2025 1:33 pm
Hahaha!
In that case, you're welcome! :clap:
Mine has turned out to be perfect for my setup, I have 2x loops running directly from my consumer unit on 16A trips, and one on a standard wall plug that I run through a controller.
Weka
Post by Weka »
Salt Must Flow wrote: ↑Thu Jun 05, 2025 10:02 pm Since you broke out the math, just for fun I measured the length of the Dernord element. It's actually 762mm long and the element is 8mm in diameter.
lol I better do the maths again then
5500/(4*.762*(2*pi*.004))
= 71797 watts / m^2
so significantly lower than the kegland element but not massively
howie wrote: ↑Thu Jun 05, 2025 8:55 pm shady
Are you using Ted's recipe or something else with bran or other grain products? Might be the source of the sulphur
SW_Shiner wrote: ↑Thu Jun 05, 2025 7:23 pm 2200w should be fine for running 2". I ran a 2200w element in my keg for years. Just a normal hot water cylinder one as they are easy to replace if need be by screwing in from the outside, and they're like $20-$30. I highly recommend insulation if you can. Heating up a full charge can take 2-3 hours depending on time of day/year and multiple other factors.
Insulation sounds like a good idea. What do people like for boiler insulation, the bubble foil stuff?
I have a couple of woollen blankets I wrap around when I’ve filled it and stopped splashing liquid around .
MooseMan
Post by MooseMan »
Weka wrote: ↑Sat Jun 07, 2025 2:23 pm Insulation sounds like a good idea. What do people like for boiler insulation, the bubble foil stuff?
Reflectix (Bubble foil) is cheap and easy to get Weka, and if you layer it up it can hold in most of the waste heat, so that's probably your best option for permanent insulation around the boiler.
Don't forget the top and bottom of the boiler, I use wall cavity insulation battens and cut them to fit then tape in or tidy up the edges with Ali foil tape.
Dedicated loft insulation blanket materials are more efficient but can be pricier.
As you are intending on a CM column, don't forget to insulate that too, either with more of the same from the boiler, or if you can get it, the black neoprene stuff intended for industrial pipework. That's really good stuff.
