The function of vinegar in the cleaning run
00Buck
Post by 00Buck »
Hey yall. Been distilling a long while but only knew what I learned from the older folks before me. I never knew a thing about a vinegar run for cleaning a new rig or new parts until recently. So the question is what does the vinegar run itself do? Does the alcohol run itself not do the bulk of the cleaning and sanitizing?
Say for example you have a still youve been running already and you solder a new part to it, say a new elbow. Why cant you just run alcohol through it to clean? What does the vinegar do to help?
Re: The function of vinegar in the cleaning run
Drop a piece of copper into a container of vinegar, leave it a day and rinse......how does it look?
Do the same with some 95% alcohol and see what you see.
Corn Cracker
Post by Corn Cracker »
The vinegar is acidic, it helps strip the copper/SS of contaminants, the alcohol is a degreaser of sorts that gets the oily, greasy stuff that might have been left behind from the water and vinegar runs
Personally , I think it depends on the flux that you used .
If you used a liquid based flux that is mostly Zinc Chloride and Hydrochloric acid , a good rinse out with water will sort it out .
If you use the petroleum based flux pastes , then you need to go through all the Vinegar bollocks followed by alcohol clean .
Personally I just use liquid flux and a quick rinse and scrub after soldering if I can , and call it done . Over a dozen years of doing that way and not noticed any issues .
Brazing copper to copper needs no flux . Hell , it’s good enough for domestic plumbing installations . No cleaning run needed there either IMO .
But say you but some still from an unknown manufacturer , that thing could be covered in all sorts of cutting oils and welding fluxes . Vinegar and alcohol sac run is the best you can do .
Corn Cracker
Brazing copper to copper does leave a heavy black residue inside.... unless it's purged with oil free nitrogen
Edit:
Not going against what Yummy said, just what I've noticed doing it at work
Turbo6ta
Post by Turbo6ta »
So, if your still is made completely of stainless steel (no copper), I guess initial cleaning with vinegar would not be needed ?
00Buck
Post by 00Buck »
Yummyrum wrote: ↑Thu Jun 19, 2025 1:55 am Personally , I think it depends on the flux that you used .
I mean I never thought of that but now that I do...Plumbers flux and solder copper pipe all the time for drinking water and its ready to go. I get alcohol vapor is hot steam but wouldnt all that flux crap also be in your drinking water?
Corn Cracker
Plumbers are supposed to flush all the water lines when done, in Texas, we have to use a water soluble flux so that unlike a grease type it washes out with cool water
00Buck
Post by 00Buck »
Corn Cracker wrote: ↑Thu Jun 19, 2025 8:05 am Plumbers are supposed to flush all the water lines when done, in Texas, we have to use a water soluble flux so that unlike a grease type it washes out with cool water
I should have clarified. So in a scenario where say you modify a rig and use a good lead free plumbing solder and water soluble flux why wouldnt a good rinse with water be sufficient? I get the brand new rig cleaning run idea from not knowing what they used but if you do it with materials like I just mentioned Id imagibe a water flush would be fine, hell its fine for drinking water
I am not saying any of this to bypass the process Im just curious about WHY things are done if you know the material that you yourself have used. I believe in safety and I wont hand anybody something to drink I wouldnt drink myself
MooseMan
Post by MooseMan »
00Buck wrote: ↑Thu Jun 19, 2025 8:22 am
I see what your saying Buck, and I agree, if you've just added a fitting to an existing still for example, you could just give it a good wipe in and out with a rag soaked in vinegar or backset (I use backset for this) then another wipe with some Feints and you'd be fine.
The general rules are too keep people safe who may not think through what they are doing very well.
If I had bought a brand new still for example, whatever the materials, and from whatever supplier, it would have the full gamut of cleans just the same as if I'd made it from a filthy keg I found by the road and welded, soldered etc.
00Buck
Post by 00Buck »
MooseMan wrote: ↑Thu Jun 19, 2025 8:53 am
I guess at the end of the day its up to the individual how safe they wanna be. I just got mind blown finding this site and reading all this information about the cleaning runs. My pawpaw would build a rig and run it lol. Hed catch all that nasty gunk that came out with the fores and he'd jar up after that. Theres alot the old timers did that I see was wrong. Fir example I always thought the heads were that "kick ass" alcohol and from reading here I started actually making tight cuts. Now "moonshine" dont have that god awful burn anymore cause I learned to leave that crap out. Point is theres always something to learn
Corn Cracker
Corn Cracker wrote: ↑Thu Jun 19, 2025 1:10 am The vinegar is acidic, it helps strip the copper/SS of contaminants, the alcohol is a degreaser of sorts that gets the oily, greasy stuff that might have been left behind from the water and vinegar runs
Alcohol is a solvent, couldn't think of the right word earlier
00Buck
Post by 00Buck »
Corn Cracker wrote: ↑Thu Jun 19, 2025 9:23 am
Sometimes it takes a minute. I dont blame you. I just hope I dont cause a shitstorm asking these things like Im trying to bypass important steps. Its not the case, I am just genuinely curious
Salt Must Flow
Post by Salt Must Flow »
If I solder just a single part to be added to my still, I thoroughly clean it inside and out using hot soapy water. I may then clean it using a solvent like Acetone or my foreshots. Wash it again and I put the part to use.
