Summer means cleaning the still
PalCabral
Post by PalCabral »
Hiya distillers.
Next week I have planned for a full cleaning of all still components, copper, steal and gaskets. I will replace any gaskets that show signs of wear or, in my case, have scorch smells, which is quite a few of them :( I will also break in two new 2,5kw low density elements.
I was hoping for your thoughts and feedback on the following questions or steps I was planning to do, as a sanity check from you experienced guys.
Gaskets:
How do you clean PTFE gaskets? I was planning on soaking in mild dish washing detergent, then rinsing with hot water and air dry.
How do you treat new PTFE gaskets? Soak them in alcohol, boil them, any initiation rites you follow.
Copper:
I was planning on giving the two copper components I have a bath in PBW followed by a good clean on the inside with a soft brush.
Then I was planning on giving them a citric acid clean to give the copper back some of it's former shiny glory. Especially the copper spool looks dingy on the outside. I was also planning to give the copper mesh a citric bath once I'm done with the dome and the spool.
Steel:
All the steel components are going to share the PBW bath with the copper and then get the same scrub with a brush. Nothing more planned here.
Vinegar run:
I do have a few new components that I haven't used yet, rather they are fittings, like valves and a manometer. It's probably overkill to do a vinegar run just for a few valves, however, given the scorching issues I've had, I'm thinking a vinegar run with a full build can't really hurt. I'm not worried about removing patina (or whatever the coating of sulfites is called), in fact I want to kick off the next distilling season with a clean rig. 1-2 hours.
Sac run:
Having scores of fores, heads and foul scorched liquor, I was thinking of giving the two new elements their first taste of blood in a sacrificial run, using the same config of the still as I used in the vinegar run. 1 hour.
Steam run:
By now I think you can tell I have some OCD when it comes to cleaning my equipment. As an old brewer, I take these things a bit too serious. But there's just something about giving a still that's been cleaned and sanitized a final complete steam run-through that appeals to me. Water is the source of life, even if it is vapors.
Comments and suggestions are more than welcome.
Re: Summer means cleaning the still
PTFE, replace only when needed.
All the rest, never unless there has been something particularity stinky in the still or if newly soldered or welded.
PalCabral wrote: ↑Sat Jul 05, 2025 12:36 am How do you clean PTFE gaskets? I was planning on soaking in mild dish washing detergent, then rinsing with hot water and air dry.
Never have needed to.
PalCabral wrote: ↑Sat Jul 05, 2025 12:36 am Copper:
Backset or Dunder does just as good a job as citric acid and costs zero $
MooseMan
Post by MooseMan »
PalCabral wrote: ↑Sat Jul 05, 2025 12:36 am Hiya distillers.
Gaskets:
No need to clean them at all really. They are pretty much impervious. Just wipe clean with a wet rash if they get sticky or whatever.
Copper:
Unless heavily soiled, no need to clean at all. You should avoid removing the patina that's built up.
Steel:
Vinegar run:
If you think there's still a remnant of that scorch hiding out in your still, by all means give it a full round of cleans again, I'd forgotten you had those issues.
Sac run:
Steam run:
Some OCD!? :lol:
My input above in bold Pal.
I'd forgotten you had the scorching issues, so I can see why you want to give everything a good old clean.
The new elements will hopefully help.
PalCabral
Post by PalCabral »
MooseMan wrote: ↑Sat Jul 05, 2025 3:55 am Some OCD!? :lol:
:thumbup: Thanks, Moose.
The gaskets had a smell to them but to be fair it's more "distillation" smell rather than burnt. One of them needs to be replaced, had a rip in it.
Pure Old Possum Piss
Post by Pure Old Possum Piss »
I haven't had any problems with scorching since I've been using these. But I also never run above 75% power.
amazon.com/Camco-02963-Screw-Ripple-Element/dp/B000BPG4LI
SW_Shiner
Post by SW_Shiner »
Id leave a big reset like that till right before I'm about to start distilling again. Especially the citric bath. Storing fresh, clean, exposed copper long term is a bad idea and can lead to nasty corrosion.
PalCabral
Post by PalCabral »
SW_Shiner wrote: ↑Sat Jul 05, 2025 1:03 pm Id leave a big reset like that till right before I'm about to start distilling again. Especially the citric bath. Storing fresh, clean, exposed copper long term is a bad idea and can lead to nasty corrosion.
I see your point, SW Shiner, and I agree, probably better for a hardcore clean just before the start of the season than at the end of it. However, I will be on the horse again already next week, breaking in my two new elements. Then I've got a spirit run of Rum and three stripping runs of Whiskey waiting. So the shiny looks on my copper dome and spool will be short lived.
I always deactivate the copper with something alkaline after a citric bath. Not sure if that would make the clean copper last better if I was to store it though?
PalCabral
Post by PalCabral »
Pure Old Possum Piss wrote: ↑Sat Jul 05, 2025 8:37 am I haven't had any problems with scorching since I've been using these. But I also never run above 75% power.
That's exactly the type I got, POP, but 2500W each. I really hope they do the trick for me, I am so fed up the reoccurring scorch smells I'm getting, even when I run at lower power. Having two also means that I actually go up in total watt capacity, if I dare to go full throttle.
Homebrewer11777
Post by Homebrewer11777 »
I've always aimed to protect my stainless brewing equipment (at least 304 and 316) with citric acid passivation once a year or so. This is every year for my fermentor but less religiously on my kettles. Process is to clean with hot PBW or similar to remove any oils. Rinse with hot water. Make hot 4-10% citric acid solution (by weight) and soak in that for 30-60 minutes. I do it at 130F for 60 minutes if I could do it at 160F I would be happy with 30 minutes. Rinse with warm clean water. Drip dry and put away. Allowing to drip dry is important and needs to be exposed to oxygen during the process.
Makes sense to me this process would also be good for still where it is difficult to inspect the inside of pipes and boiler.
I only clean my copper bits (I use bits of copper pipe in vapor path) after a puke. They get soaked in hot PBW and rinsed in hot water and allowed to air dry. If no puke they just get a warm water rinse once in a while.
PalCabral wrote: ↑Sat Jul 05, 2025 10:50 pm
You could run both at half power, spread the watts over a greater surface area. I used to use both at full power during heat up and then just use one during the run, but I ran into not scorching, but just an over cooked smell/flavor. I'd look in there and nothing was scorched and stuck. But since using both to spread out 6000W I haven't noticed that problem.
What would you call that where is not really scorched but the taste changes into some simular? Like the difference between white sugar, caramel, and burnt scorched sugar.
PalCabral
Post by PalCabral »
Pure Old Possum Piss wrote: ↑Sun Jul 06, 2025 8:10 am What would you call that where is not really scorched but the taste changes into some simular? Like the difference between white sugar, caramel, and burnt scorched sugar.
I think this is what I've been having lately. When I look at the element after the run, it looks OK, no crust to be seen. But during the run, halfways through, this acrid burnt flavor starts appearing. In my case it's not caramel or sugar, it acrid, bitter, foul. Once it's in the distillate, it's over. Can't use it for other things than cleaning shit.
PalCabral wrote: ↑Sun Jul 06, 2025 9:25 am
Mine isn't really acrid, and it's still drinkable but the taste and smell has changed. Like a Maillard Reaction?
MooseMan
Post by MooseMan »
[quote="Pure Old Possum Piss" post_id=7809861 ?
Ps. How do I start a new thread? I can't find the button.
[/quote]
Top of the page, board index.
Find the forum you want to post in, then go new topic.
