new keg build, pictures
planohog
New keg build with some pictures.
I wanted to use the original 2" and add a 6" . It just wasnt in the cards, even with my bad eyes I could see it was not going to work . I went inside and ordered a 3" ferrel and cap. This will be a fill port if needed. It will be a few days before I get the parts.
1137 show new keg with 6" ring sitting on top. It sits great there. If you move it off to the side , your going to have a huge time with solder as it will not sit tight against the surface. 1140 I was mearsuring 1.75 and I taped it down for marking. 1141 the amazon cutting disk I used, I started with one I had it was terrible, this , I only used one. Went around about 5 times slowly
cutting away. ( USE FULL FACE AND EAR PROTECTION ), I only had gogles and now my face is burning from the cuttings. DONT DO IT. 1142 fresh cut 1143 cleaned it up with various tools and sand paper.
did not want to cut my arm open on the very nasty edge more as I work this through.
Re: new keg build, pictures
Looking at the pic it looks like there was already a bottom drain?
SW_Shiner
I didn't think about that, your probably right.
planohog
weird colored spot on the bottom, no drain yet, waiting on parts.
today I will probably try the heater port 2inch on lower side
Good stuff Plano
Don’t be afraid to go as low as you can with the element .
The lower you mount it , the smaller batches you can run without fear .
- Salt Must Flow
That was some good grinder work there planohog
Take your time and you'll appreciate your handiwork every time you use that boiler
I LOVE seeing people here building their own.
planohog
Todays work, cut the top rim back. Made ugly mistake, I started the wrong way, probably saved it I did not grind all the way through.
Might be able to solder some in that crack for extra hold.
Also made a copy of the 6" jig found here on HD. picture 1152 1153,1154,1155. the two inch ferrel, 1.6 inch hole. ( used hole punch on this one ).The heater fits nice. soon as I can this will be my first solder joint,
waiting on flux. I have parts to make a jig to fix 2 & 3 . The location of the hole allows about 2-3 inches clearance from the floor. I oriented the zigzag element sideways. 1157 a look in the 2" ferrell, the heater element fits here nice. No need to trim that up at all. i have parts to start working on the heater box, might do that for awhile, as you can see , its super hot out side
someone sweated all over my new keg, then soaked it in wd40 drilling holes.
The main thing, im having fun, many thanks to SailMan, Yummy, SMF, Shady for ideas and great support.
more items to show as they are built.
- Salt Must Flow
I agree, builds/projects are really fun! When the project is finished, all the fun is over
Gotta figure out something else to do now
- Corn Cracker
Nice work, its looking good
MooseMan
Great work so far Plano!
Gotta love a good boiler build.
Keep the pics coming man.
planohog
ok stayed inside, raining most of the day.
worked on the electric controller box.
mounted CGELE Solid State Relay SSR-40VA 500K ohm 2W to 24-480VAC 40A Single Phase Solid State Relay Resistance Voltage Regulator Authorized+Heat Sink+Potentiometer+A knob…
a AC Volt/Amp meter,
on off switch for the SSR.
added a fan, made bunch of air flow holes in box.
I hope that gorilla glue I used on the fan for the custom bracket work.
Im wrestling with ten gauge wire some tonight.
From the heater element I will have a short length of wire to male twist plug L6-30P
L6-30R some length of wire to the box. Basically X and Y and ground from the heater element.
Today messing around with volt meter and switch and variable resister layout , good 4 hours.
maybe tomorrow, ill get the 3" hole completed.
NormandieStill
Nice work so far. Gonna be a good boiler when you're done.
One little tip, while the element fits through the hole, the lip will hold liquid which can turn funky after a stripping run. Use a file to open up a notch at the lowest point and it'll drain better.
Sailman
Plano, I'm glad that you found inspiration from the way I've done things. I'm sure there are better ways to do it than what I did but this is what worked for me. That's what makes this community so great.We all are willing the help and we learn from each other.
planohog
very important picture about the SSR. Mostly on electronics from A. there are no instructions .
this shows the orientation of the variable resistor and the connections. The ground confirmed, only attached to the body and knob stud of variable resistor.
I question the full clockwise for full power. I plan on using the switch to interrup or short that circuit
to keep power off the heater. I plan on using the ac voltmeter on the heater side to give a
indication of voltage and over all heath of the system. I will connect the amperage detector but have
zero faith in it. It may turn out to be something that is a general idea, hey there is current moving here.
At 240 vac. Im not going to touch it and find out.
I am hanging my fedora on the fact that earth ground is the keg, all the way to that rod sticking in the ground below my external power box.
I am not using a GFI, I have a love hate relationship with them.
The lighted switch, held with the space at the bottom and the terminal at the top looking at the terminals.
a. b.
c. d.
a and c are for the lamp, in my case 120-240ac .
b and d are for the resistor circuit on the SSR. ( not sure this will work untested ). ( off should present infinite resistance to SSR. )
lets pretend that solution is bad. Then ill add a 40 amp relay in there somewhere so I can kill power.
Disclaimer, test everything yourself, never trust anyone. your mileage may vary. according to this picture , more resistance is less power out, since its from the manuacture, im going with
open that up, and the power is zero. https://lorentzzi.com/products/solid-st ... regulator/
simple test: in not ready to test yet but here it is for you:
Quick bench check (safe order)
Power OFF, wire a 500 kΩ, ≥1–2 W pot across pins 3–4.
Put a small resistive load (e.g., incandescent lamp/heater) on the AC output.
Power ON; rotate the pot. If clockwise yields less power, swap which pot end goes to pin 3 vs 4 to make “clockwise = more”. (Direction simply depends on which pot end you used.)
watch out ac voltage can bite hard.
a. b.
c. d.
If viewed from the front, I'm thinking the pot is wired backwards in the pic.
planohog
If it’s backwards , quick Change to the other pole will fix .
Or it will be max power CCW
Putting this power box together taking more time than I planned. Hopefully I can save others some time with this one
I've had to do that a time or two.
joschi
How many Watts has your element? I would consider a second element, cuts heat up time in halve
no need for power control for the second element, just a power outlet on a separat circuit.
check the max possible watts before buying elements! If not sure, ask "your" electrician!
planohog
that element is a 5500 watt. DERNORD 2 Inch (OD64) Tri-clamp Ripple Heating Element Electric Water Heater 5500W 240V . Am i an electrician ?, no, but electrons flow from the negative pole to the positive pole. This was exactly opposite of what my room mate at that time was being taught in the same school but different program.
More progress, used water for cooling, wife sprayed while i drilled using a Tungsten Carbide Tipped Hole Saw Drill Bit for Hard Metal, 2-11/16 Inch T.C.T Hole Saw Cutter for the 3 inch ferrell ontop. That thing nearly broke my wrist, I had my large electric drill. Cut was exactly what I wanted. I also wired in the other large male plug into the box, need to get that all wrapped up today I hope and start learning how to solder.
planohog
static smoke test - [PASS], I cant hook up anything to check the operation.
note" All the LED work, taking a picture of them , weird, they might have a 60cycle blink."
the real test under load will be the kicker, will the butt joints I used to crimp with hold ?
will that SSR hold up. with the variable resistor work right or will it be backwards.
so back to the keg.
so back to the keg.
planohog
well thats what I get for trying some other flux.
that solder melted and would not stick to anything.
I may have ruined this thing all together. when it cools
ill get the wirebrush going and see if it comes off.
I have not been able to get Harris SCLF4 Stay Clean Soldering Flux, My first try,never showed up
today should get another try.
so did I do unrepairable damage.
- acfixer69
It should clean up fine with wire brush on a angle grinder. Wait until you have the right stuff, even if you managed to get it to stick it would leak when heated or crack when cooled. Good luck and hope you get the stay clean soon.
- Salt Must Flow
I would NOT use a wire brush on a drill & grinder unless it is stainless steel and has NEVER been used on carbon steel.
For cleanup, I use a Die Grinder and polishing disks like shown below. I only use the abrasive disks for more aggressive uses.
planohog
got it all cleaned up, and just got my stainless flux. Ill try again this afternoon. Results , not to bad,
if it sealed ill be pretty stoked, when it was not acting right the acid brush moved it around nicely.
had a build up, but if it sealed and its pretty safe , ill take it . maybe one day rework it if I do not have to already.
I've made that mistake. A couple days later and everywhere I brushed started growing rust.Salt Must Flow wrote: ↑Mon Aug 18, 2025 11:06 am I would NOT use a wire brush on a drill & grinder unless it is stainless steel and has NEVER been used on carbon steel.
planohog
lucky I have new stainless brushes, no one of them has crappy flux all over it so ill start with a new.
MooseMan
Even if you did use a new brush, it's best to passivate any areas that you've done hot work on in any case, just to prevent any future corrosion.
Citric acid made into a paste will do a good job.
Edit to say, nice job by the way, the right flux turns headache work into a pleasure, I've made that mistake!
- Salt Must Flow
I picked up a bottle of Barkeepers Friend at the local grocery store or Walmart. That stuff does a GREAT job of passivizing and cleaning up stainless. I put some on, left it sit for a good while and gave it a scrub. If there are areas that need more cleaning I just left it sit on longer or added some more and left it sit a while longer. The stuff truly is amazing and convenient to have on the shelf.
planohog
Water boil test=[PASS]
the solder joints look like me, terrible but they will work for now.
looks like I get 23 amps out of it. Perfect for a 30 amp service.
waiting on drain parts now, then, I can wait for fall and cooler water temps.
Till then ill keep shining on it. and a vinigar run and a sacrificial sugar run.
I have always had a special place for strippers , this one can stay in the house.
Many thanks to the little lady for allowing me to take over the laundry area and kitchen table for a few days.
