SCD's Crow Bourbon
PalCabral
Re: SCD's Crow Bourbon
Post by PalCabral »
stardtek wrote: ↑Mon Jan 13, 2025 11:03 am I got a question. I have a hard time getting red wheat malt. Can i do a substitution to add a bit more regular wheat malt and a bit of malted barley that is meant for red ale's or would that have too big of an impact on the flavour?
Not sure where you are located but in Europe neither the american white or red wheat are available to us. The european wheat, which is sometimes called white wheat, is a different breed from the two american wheats, but from what I have heard it is actually more similar to the american red wheat than to the dito white wheat. I don't know if this info helps?
Photoguy-70
Post by Photoguy-70 »
Ok then! I made it to the end and would like to make a comment. Have done 5 batches, strip to low vines then spirit run. All with pot still. When running strip the hearts tasted great(to my taste buds). After the spirit run and making pretty severe cuts its - blah to me. Smooth yes but also short on the grain flavor. Did a mix of 1/2 strip hearts and 1/2 of spirit run and bingo! Got my flavor back. Any one else have the same experience? Am I missing something? Please share your thoughts.
Twisted Brick
Post by Twisted Brick »
Photoguy-70 wrote: ↑Fri Sep 12, 2025 1:09 pm
Yes. Making cuts is a developed skill that is learned over time via successive distillations. Knowing the properties (flavor profiles) of each of the constituents in a newmake spirit will help you to understand how to portion them when making cuts. For instance, while hearts are the target of every distiller, they are easy to identify and essentially neutral and very low on the grain flavor scale. From your summary, it appears you have already learned this.
The primary goal of making cuts is exclude the 'ends' of each distillation that results in a balance of flavors that complements the hearts. Knowing that (grain whiskey) heads contain sweet, fruity flavors and that a portion of tails contains rich, grainy flavors means that it is entirely up to you to determine what percentage of each you need to retain in your final cut to produce a spirit that you like. Some like a rich, complex spirit while others prefer a sweeter narrow-cut dram.
The challenge to accomplishing this is that as careful as you are making that initial cut, the spirit changes over time and conditions. Say you make your cuts and load your newmake into a barrel to age. Over time the spirit will start to taste worse than when it first entered the barrel, and go through multiple phases of objectionable profiles. It typically takes a year for a barrel-aged spirit (depending on the size of the barrel) to evolve into a flavorful dram, and every month thereafter it continues to improve until it doesn't, depending on a long list of factors. Many a member laments that he never finds out just how yummy his spirit 'could have gotten' because he drank it all before it got there.
My advice is to follow the Novice Guide to Making Cuts and over time keep detailed notes on your perceptions of the spirit. After a year you may find that you need to adjust your cuts on your next distillation, but that's the way it goes. Also know that cuts vary to how soon after distillation the distiller intends to drink the spirit. Like this thread, virtually all of the variables associated in making cuts have been questioned and discussed in threads dealing with 'making cuts', 'barrel aging', 'keeping one's spirit white' etc. Lastly, exercise patience, make lots of distillations (practice) and read more threads. While the answers to your questions are all there, but there's no substitute for hands-on experience.
Photoguy-70
Thank you for your advice. I feel I'm not a novice but also don't consider myself a pro by any means. I find myself learning something new every time and am grateful to do so and feel I'm getting better,especially my patience with it all.i understand everyone's tastes are different and I suspect your point about the aging process-time is on point. I have learned that with my previous project. After 1 year in the barrel its unrecognizable from the beginning. I guess I have not learned enough lol. Thanks all.
ShineonCrazyDiamond
Post by ShineonCrazyDiamond »
Such a great response Twisted. Thank you for all you contribute to HD.
Shine on you crazy diamond."
Photoguy-70
Thank you T.B. for taking time to reply to my "rant". I agree with everything you say.It was not meant that way only frustration over not gaining my goal I wanted to achieve. Over the past couple of years I've learned few things. I no longer try to save every drop, far from it now. Little by little I have learned making cuts and am happy with it most times. I love to experiment. I make small 6 gallon batches. Pick a grain bill and do half a dozen batches and see what I get. Sometimes it's great sometimes not so.(taste wise) .that's ok too. I don't drink much anyway but I just enjoy the process. Thanks for letting me be part of this great community.
Twisted Brick
Photoguy-70 wrote: ↑Sat Sep 13, 2025 12:39 pm Over the past couple of years I've learned few things. I no longer try to save every drop, far from it now. Little by little I have learned making cuts and am happy with it most times. I love to experiment.
I think the key to learning cuts is what you said: "little by little". The reality is it takes a long time to age our spirits to our liking. If it only took a week or two we'd all be experts.
ShineonCrazyDiamond
Funny. At first I had to learn what I needed to remove from my final blend. Then I had to learn to put it back in.
Photoguy-70
Very true. We never stop learning and I have a heap to learn. Thank goodness this Forum is here to fall back on and get answers. Thank you all for putting up with the likes of me.
Alzahra888
Post by Alzahra888 »
ShineonCrazyDiamond wrote: ↑Mon Sep 15, 2025 10:02 am Funny. At first I had to learn what I needed to remove from my final blend. Then I had to learn to put it back in.
I am just now realizing how much this problem needs my attention. Sometimes i try everything. Others I have sufficed the find limits between cuts and then grab everything in the middle or simply put aside what went before or after. Only once i believe did i do the keep remove keep sequence.
Somewhere between hurry up and time is irrelevant.
Knowledge might be expensive or cheap, but information is always costly.
liquid_chris
Post by liquid_chris »
What happened? I can't believe it's been 9 months since anybody has posted to this thread. This is one of my top three favorite recipes. I didn't get to it last year, my quest to fill a 5 gallon barrel with this is moving along. I think I finally I have nailed down my procedure. I have a 10 gallon still that works best when filled to the 10 gallon mark. So stepping up to a batch that yields 20 gallons of mash took a while given my limited resources. The biggest pot I have is 15 gallons. The biggest fermentor is 30 gallons (one of the white one with the screw on red tops.) I cook outside on propane.
I put 10 gallons of water in the pot and bring to a rolling boil, turn off the flame and add the corn and oats. 17 lbs of flaked corn from the feedstore that I grind to a very coarse cornmeal, and 1.25 lbs of oats toasted according to instructions (I never get tired of that smell when you add the toasted oats), mix well, insulate with blankets and immediately start boiling another two gallons of water in a separate pot and add it when at a rolling boil.
Aiming for 155 to 150 F I add enzymes (sorry to the purist haters, but allows more flexibility on hitting the temp mark, which sometimes I miss if I'm busy working on other stuff) and add the 2.5 lbs each of red, white and rye. When cool enough I transfer to my fermentor and start it all over again (sometimes next day) which together will barely leave enough head space in my fermentor. Next day (sometime two days) till it's cool enough to pitch the yeast. Been getting dead-on 1.06 with this method.
A week to 10 days later it'll hit about 1.01 and looks done, I'll transfer it to another fermentor to clarify. I was having trouble getting my liquid out of the grain, but then started squeezing the stuff I already squeezed in my grape/fruit press and bingo there's the the stuff I was missing out on the first couple years of making this. A lot of extra liquid! Couple days and the custard is at the bottom and it's finished fermenting.
Couple more batches and I'll have enough for the new Gibbs Bros barrel. Then the wait begins.
Peace and love, Chris
Copperhead road
Post by Copperhead road »
liquid_chris that sounds like an easy step by step recipe. after 10 years i have decided to start dipping my toe into the world of
"all grain"
may i ask what type of enzymes you are using????
liquid_chris
I use "Liquid High Temperature Alpha Amylase" From North Georgia Still Co. I got it off Amazon. I think it was $19 for 8oz. Works great for me. Works between 190-150* F. A good safety net.
All grain can be kinda a pain to learn the little tricks that make it easier. It really makes the smoothest best tasting hooch. I'm just now dipping my toe into barrel aging. Patience is not my virtue. So I learned I have to make extra to drink the white dog while waiting for this stuff to mature...........
Chris
Deplorable
Post by Deplorable »
liquid_chris wrote: ↑Tue Jul 28, 2026 10:16 am What happened? I can't believe it's been 9 months since anybody has posted to this thread. This is one of my top three favorite recipes. I didn't get to it last year, my quest to fill a 5 gallon barrel with this is moving along. I think I finally I have nailed down my procedure. I have a 10 gallon still that works best when filled to the 10 gallon mark. So stepping up to a batch that yields 20 gallons of mash took a while given my limited resources. The biggest pot I have is 15 gallons. The biggest fermentor is 30 gallons (one of the white one with the screw on red tops.) I cook outside on propane.
I actually just checked in on my Badmo barrel of this from November of 2023, only the 2nd sampling since I filled the barrel. It's a pretty fine sipper, so I'll probably draw off enough to make a pint of 80 proof this winter, then see if I can let the rest sit until it turns 4. I've got lots of stuff aging to keep me out of it.
liquid_chris
Very jealous Deplorable. Hey?? At what proof did you put that fine liquor into your Badmo? I was aiming for 120. Sound good?
Deplorable
liquid_chris wrote: ↑Tue Jul 28, 2026 2:51 pm Very jealous Deplorable. Hey?? At what proof did you put that fine liquor into your Badmo? I was aiming for 120. Sound good?
It went it at 112 proof, or 56%ABV.
What proof I put it in at depends on the toast and char level, and the flavors I'm looking to pull out of the barrel.
This went into a Garryana Oak M4 Badmo Barrel, so I intentionally lowered my entry proof to capture caramel and vanilla while trying not to pull as much spice as I would with a higher entry proof.
Quercus garryana Oak has a tendency to contribute more spice than Quercus alba, so the lower the BEP, the less likely it is to pull in the higher lignin-derived phenols such as clove and baking spice.
A lower BEP pulls more of the hemicellulos-derived sugars and tannins, where a higher BEP tends to pull lignin-derived phenols and aggressive tannins.
FCRacing
Post by FCRacing »
well first thanks SCD for the recipe made my run about a month ago just so good straight of the still it's aging in oak now going put another mash down and was wondering for those who make this regularly does anyone make it with backset keep some from the first run
PalCabral
Post by PalCabral »
FCRacing wrote: ↑Sat Oct 10, 2026 4:28 pm well first thanks SCD for the recipe made my run about a month ago just so good straight of the still it's aging in oak now going put another mash down and was wondering for those who make this regularly does anyone make it with backset keep some from the first run
With a nick like that, you must be from Uccle? I used to walk down the hill in Duden park to see my local team Union St. Gilloise when I lived in Uccle. They played in second division in those days. Allez les jaunes.
FCRacing
Post by FCRacing »
Hi Palcabral
I'm From Australia
Copperhead road
FCRacing wrote: ↑Sun Oct 11, 2026 6:42 pm Hi Palcabral
I'm From Australia
plenty of Aussies, Brisbane here.
FCRacing
Post by FCRacing »
Hi Copperhead Road
Rockhampton
Copperhead road
FCRacing wrote: ↑Sun Oct 11, 2026 11:00 pm Hi Copperhead Road
Rockhampton
lol i was born there at the base hospital.
PalCabral
Post by PalCabral »
I'm From Australia
Lol. I must have been looking at the globe upsidedown :lol: And now I know there's an FC Racing in Aussieland too. :thumbup:
FCRacing
Post by FCRacing »
Copperhead Road
Small world
Copperhead road
FCRacing wrote: ↑Mon Oct 12, 2026 4:11 am Copperhead Road
Small world
:thumbup: :wink:
