Adding a sight glass/diopter - cleaning protocol?
- PalCabral
I have just recieved a sight glass for the still. I want to see how much passive reflux I make. But before I use it it must be clean and safe. Vinegar? Sac run too?
- Salt Must Flow
Re: Adding a sight glass/diopter - cleaning protocol?
Just thoroughly clean it before using it. Soap & water will do.
The proper cleaning runs are basically for a new still or for parts with lots of residual flux that is not easily removed. If you just have a part or two, you can just clean it well.
- Copperhead road
If it’s made of copper I like to soak in citric acid bath overnight then rinse clean with boiling water.
Soap and water and a rinse .
amh71
Take it apart, give all the bits a good wash and then ptfe wrap the gaskets, which are likely silicone.
Or bin them and wrap the ends of the glass really well.
ismbardbrunel123
Whilst on this subject, i have a borosiliscope....? glass tube with a tri ...? 2 inch fitting..., could i use this to fit to the top of my 50 litre stainless still without fear of it shattering because of the heat...?... just read conflicting info... thanks
amh71
Borosilicate glass is what Pyrex used to be made from, it's essentially heat proof.ismbardbrunel123 wrote: ↑Mon Sep 15, 2025 11:30 am Whilst on this subject, i have a borosiliscope....? glass tube with a tri ...? 2 inch fitting..., could i use this to fit to the top of my 50 litre stainless still without fear of it shattering because of the heat...?... just read conflicting info... thanks
- Salt Must Flow
Yes, as amh71 said, the Borosilicate glass tube is perfectly fine. They're designed to be used with a still as well as other similar purposes.ismbardbrunel123 wrote: ↑Mon Sep 15, 2025 11:30 am Whilst on this subject, i have a borosiliscope....? glass tube with a tri ...? 2 inch fitting..., could i use this to fit to the top of my 50 litre stainless still without fear of it shattering because of the heat...?... just read conflicting info... thanks
The "conflicting info" is probably due to people discussing using canning jars with a still. Canning jars are NOT recommended. There are a lot of topics explaining why.
ismbardbrunel123
Brilliant, was a a bit cautious as the son in law is very interested in what i am doing...i would like to show him it's pretty safe... thanks....
