6 inch bubble cap glasser
I need borosilicate Glass tubing 12" long and 6-8" dia.
I've found glass chimneys on amazon that's the size and height I need but the wall thickness is only .090" 2.3mm.
Anybody know of a place to get something thicker?
Re: 6 inch bubble cap glasser
Mash Rookie was a glass blower by trade and made my condensor out of borosilicate glass. I have another friend that is a professional glass blower, I will check with him tomorrow.
Thanks bushman.
I'm thinking about using 2 bubble plates on a tree with a dimroth dephleg.
The fun part will be making the end caps that sandwich the tubing.
I've got a 1/2" thick chunk of copper that's big enough for the end caps and a lathe.
Dangit, what I thought was 1/2" is only 1/4"
How to make the end caps isn't decided yet.
There are a couple options.
1. Use the lathe to cut rings out of the copper plate.
2. Cut a long strip out of the copper, bend it into a ring and weld it.
3. Make a pattern and try to cast the end caps out of scrap copper.
- Copperhead road
Don’t think I have ever seen a build thread where they have cast copper before,
That would be pretty cool.
Would that be neater than the lathe option Shady?
- Salt Must Flow
What's the budget for this part of the project? Oakstills has a 6" x 12" Tri-Clamp sight glass for $228. Might find a better deal on AliExpress or elsewhere for all I know.
NormandieStill
My guess is that castings will still need finishing on the lathe. But they could be much chunkier than from plate.
That'd be some pretty copper porn right there.
That would be almost cheating. I attempted to order the 6" x 18" sight glass but the order was rejected.Salt Must Flow wrote: ↑Fri Sep 19, 2025 10:14 pm What's the budget for this part of the project? Oakstills has a 6" x 12" Tri-Clamp sight glass for $228. Might find a better deal on AliExpress or elsewhere for all I know.
I'll take that as a sign and build it.
- Copperhead road
That is exactly why I thought casting would be awesome to do if possible…NormandieStill wrote: ↑Fri Sep 19, 2025 10:32 pm But they could be much chunkier than from plate.
Kinda what I was thinking.NormandieStill wrote: ↑Fri Sep 19, 2025 10:32 pm My guess is that castings will still need finishing on the lathe. But they could be much chunkier than from plate.
Now I need to see if my forge can be used to melt copper.
- Salt Must Flow
I've purchased from Oakstills and from AliExpress without issue and so has many others. As long as you use a major credit card, there's really no risk.shadylane wrote: ↑Fri Sep 19, 2025 10:44 pmThat would be almost cheating. I attempted to order the 6" x 18" sight glass but the order was rejected.Salt Must Flow wrote: ↑Fri Sep 19, 2025 10:14 pm What's the budget for this part of the project? Oakstills has a 6" x 12" Tri-Clamp sight glass for $228. Might find a better deal on AliExpress or elsewhere for all I know.
I'll take that as a sign and build it.![]()
I totally get the whole build it yourself thing and the challenge to not purchase a major part. I agree, it would be cool as hell to be able to smelt some copper, pour, cast and machine it. Then comes sourcing the proper diameter and thickness of the proper glass. It's a ballsy endeavor and that's a fact. These Tri-Clamp sight glasses are truly reliable and built like a tank. Either way you go, I'm sure it will work out and it will be an interesting build.
Ordering a readymade sight glass from Oakstills would be the logical option and I still might go that way.
First, I'll try building the bottom end cap so there isn't a need of an adapter to the smaller tri--clamp on the boiler.
The top end cap will be interesting since it goes from 6" to 1" and has a dephleg inside it.
I'll be calling oakstill to see if they sell only the glass.
I've done many things successfully but trying to blow glass is beyond my pay grade.
MooseMan
Oh Shady Pleeeeeeeease make some copper castings!
They can be as rough as you like, then you can spin up a lovely shiny finish on the lathe and get an almost perfect groove fit to the glass.
What an absolutely awesome project that would be, I wish we had a "We are not worthy" emoji on the board.
Edit: Do a search on AliExpress for "Borosilicate glass cylinder" and thank me later!
Casting copper fittings is a rabbit hole I haven't dug in yet, I'll keep folks posted on what I find while trying.
30xs
I machined a few pieces for my flute on a lathe. Keep some lube handy. I machined the pieces dry and it’s amazing how loud copper can scream.
The imagined image of a copper sight glass is sexy. Since you don’t have the thickness you wanted would a laminated piece work. You could use a 1/4 copper disc on the bottom with a 2 1/8” hole to register a copper stub, a 1/4” stainless disc with an opening the size of the inside of the pipe, then a ring to register your glass on top of it. You could even register your holes through the copper so that the nuts tightened down on stainless only. Not sure how much pressure the thermal expansion from the copper would add to the glass.
Looks like my forge doesn't get hot enough.
- Copperhead road
Shady do you have a “plan B” for the casting?
I hope the does not mean you are aborting the mission…
Roo
Plan B is I just ordered a new forge.Copperhead road wrote: ↑Sat Sep 20, 2025 4:31 pm
That's it.Roo wrote: ↑Sat Sep 20, 2025 5:20 pm
Is this what you are looking for?
https://oakstills.com/en-au/products/re ... ight-glass
I thought about making DIY green sand but instead ordered petrobond casting sand.
It chafes my ass to spend $3 a pound for a mixture of 70% sand and 30% clay.
Tomorrow I'll make the bottom pattern and boxes "cope and drag" out of wood.
Now I’m excited Shadyshadylane wrote: ↑Sat Sep 20, 2025 5:49 pmPlan B is I just ordered a new forge.Copperhead road wrote: ↑Sat Sep 20, 2025 4:31 pm
- Copperhead road
Shady what kind of forge did you end up ordering ?
"VEVOR Propane Melting Furnace Kit 8KG"
I wanted bang for the buck, Amazone $109 plus tax looked like a good fast option.
MooseMan
Me too!
There's no rules that say you can't do a build thread, on a bit of kit that is going to make a still part, right Yummy?
Damn right
I stacked and glued several pieces of plywood to make the form out of.
A 1/2" bolt is being used to hold the layers together until the glue dries.
See the round end piece on the right, there's supposed to be a matching piece on the left.
I haven't a clue where it ran off to, so I clamped the pieces together and maybe I'll find it tomorrow, If not I'll make another.
Tomorrow should be easier, today I had to battle red wasps over who owned the lathe.
I used a spray bottle with soapy water to suffocate them and called Bubba.
There was a big nest, and he thinks wasp larva is the secret ingredient for fishing.
MooseMan
Off to a good start!
Are you going to try casting a section to turn a Tri clamp flange on one of the end plates?
Or just cast them both the same and add that later?
Bubba is right about the larva, but it's not usually worth the pain! Haha
- PalCabral
Bubba should get an account in HD and join us. It feels like he's here all the time anyway.
