Using nylon mesh bags in vapor path
- PalCabral
Hiya distillers.
For my upcoming spirit run of apple pomace wash I was thinking of chopping up apples to hang in a brew bag at the top of the boiler. I have nylon mesh brew bags meant to be used for fermentation that I can tie to the mouth of the boiler.
However, I am uncertain if nylon is a safe material to have in the vapor path. Thoughts and suggestions much appreciated.
Edit: I am pretty cerain nylon is not appropriate. What would be, is a better question? Cotton?
- NZChris
Re: Using nylon mesh bags in vapor path
I believe this is covered in The Rules By Which We Live at the bottom of this page. You can do whatever you want in your shed, you are drinking it.
- PalCabral
My health is important to me and so are the ones of those I offer my homemade to. The rules will be followed, no doubt about that.
No to nylon . Yes to Cotton
- Steve Broady
You can also buy stainless steel mesh in various sizes, which might work to do the job you’re considering.
I’m using a mix of 1.5” and 2” triclamp, and recently found a great deal on a used 3” sight glass and plate with holes in it. I’ll be using them to add an infusion chamber to the top of a still, packing the sight glass with whatever I want to use and the filter plate as support. You might want to look into something similar, if your still design allows it.
Homebrewer11777
I use a PTFE gasket with a stainless screen that I got from Amazon (Dernord) in my site glass to hold copper pipe cuts.
DERNORD 3" PTFE (Teflon) Sanitary Gasket w/Stainless Screen - Tri Clamp Clover (10 Mesh)
- jonnys_spirit
This along with some 20 mesh stainless cloth is what I’m shooting to use for a false bottom to cook/infuse some pomace here soon.
It’ll be a little fiddly to get through a number of strips but expect it to work well and keep the fruit well away from the heating element.
Jonny
Jonny
- Tammuz
Look for stainless steel canister they use to smoke nuts in. They fit a 3 inch column just right. I bought a 4" tea bob off Ali to hang copper filing as it leaves the boiler.
zach
I have one of these stainless baskets for mashing - brew in a basket . This might work if it fits in your boiler.
- PalCabral
Thanks guys for all the tips.
