Alcoengine Reflux Column
contrahead
Re: Alcoengine Reflux Column
Post by contrahead »
Go to 6:45 minutes in the KegLand video. Where are the "bits of wire" the the speaker mentions ?
Omnia mea mecum porto
Salt Must Flow
Post by Salt Must Flow »
contrahead wrote: ↑Tue Oct 21, 2025 3:05 pm Go to 6:45 minutes in the KegLand video. Where are the "bits of wire" the the speaker mentions ?
Nikolav showed clear pics of the wire previously.
decoy
Post by decoy »
you don't need to run a full boiler, if you have a local Chinese grocery store and buy a few bottles of Chinese cooking wine.
this link is from Coles supermarket, mainstream grocery store.
640ml bottle, 16%abv $2.55
https://www.coles.com.au/product/double ... E8QAvD_BwE
Salt Must Flow
It's just a really bad design. The still operates on the presumption that 'enough' reflux will drop straight into that little hole in order to exit the still. Evidently not enough is.
I imagine you could bend the copper wire to direct the trickle of reflux into that hole, but it will be trial & error unless you could use that scope to see which direction it needs bent. Even then, it may still not work as well as you hope.
decoy
Post by decoy »
Try running the still with no condensor, see how much vapour comes out the top.
I would work on twist wiring a 32-12mm conical reducer to the condenser, maybe drilling a few holes through the reducer to let mor vapour pass, but objective is to concentrate all condensed spirit over collection port, maybe even put a smaller 25-6mm reducer in the collection port.
SW_Shiner
Post by SW_Shiner »
decoy wrote: ↑Tue Oct 21, 2025 5:14 pm Try running the still with no condenser, see how much vapour comes out the top.
I'd be careful recommending people run without a condenser.
Throw a litre or two of water in the boiler and see how much steam makes it through.
Another thing would be to 'tease' some of the SS mesh that is in the coil. Pull it down a little so it makes contact with the pointy bit, if you get what i mean. Kinda fill up that empty space and it might help direct more reflux down the collector.
Salt Must Flow
In the instructions PDF it shows the take-off valve, but it also shows a tiny little orifice in the take-off line. This orifice loos so small, it probably wouldn't matter how far open the valve is open, you would probably not alter the take-off rate. It looks like all the valve is good for is so you can turn the take-off completely off or on.
Salt Must Flow
There's another notation in the instructions about two different "flow control devices" that come with the still. Basically two different brass fittings with different size orifices drilled through them.
decoy
Post by decoy »
Salt Must Flow wrote: ↑Tue Oct 21, 2025 8:48 pm There's another notation in the instructions about two different "flow control devices" that come with the still. Basically two different brass fittings with different size orifices drilled through them.
the jet on my gas burner is bigger then that..
maybe ditch that valve and pick up proper needle valve
https://www.aliexpress.com/item/1005007 ... 1109407475
Thousands of people use these small off the shelf stills on a regular basis,
None that I see have a problem using the supplied jets/ restrictors that come with the still.
If they were a problem it would be common knowledge by now, these stills have been around for probably 10 years or more now.
SW_Shiner
Post by SW_Shiner »
You mentioned that your T500 column still works fine on the same boiler, how tight was the packing in the alcoengine? Is there any resistance when trying to breath through it?
Salt Must Flow wrote: ↑Tue Oct 21, 2025 6:27 pm It looks like all the valve is good for is so you can turn the take-off completely off or on.
Correct Salt .
The manufacturers don’t think we are clever enough to use a real needle valve so they stick a ball valve on there and use restrictors to set the reflux ratio . They have idiot proofed it .
Personally I don’t think it is a bad still . It is a basic LM . It’s all copper . Only gripe would be that the column is a bit short.
Nicolav
With the cap off and the coil out , if you pour methylated spirit or 95% ethanol down the top into the cup , does it pour out the side ?
It should gush out . Now bit by bit add the valve and restrictor and see where the bottle neck happens .
Note I said to use Metho or 95% . If you use water , it will behave differently due to the surface tension differences .
nikolav
Post by nikolav »
No resistance when I try to breathe through the column. I tried it without any packing as well. That didn't change anything.
I tried it with and without the restrictor, with and without the ball valve. Also with the two different restrictors. No matter what it is a drop a second or thereabouts.
Nothing is obstructing anything.
I'm beginning to think the problem lies elsewhere, it's probably not the still.
Two more things I'll try:
- as suggested elsewhere I'll try running it with much less water flow. I DO NOT believe this is the issue and I can't see how s higher input equals less alcohol output, but I'm gonna try it anyway. Kegland suggest minimum rate, not maximum.
- I'll try a different boiler. My mate has a newer t500 boiler so I'll do that this weekend. Mine is gen 1, who knows how old. The column came with the ceramic saddles. :). Maybe it's good enough for t500, but not for this still.
I poured water (didn't think of using spirit then) with the top off and it pours pretty well from the exit. I'll try with some metho as well.
PS. I don't have any reason to doubt the design of the still. I am not expecting it to be any better than T500, just easier to operate. I have external tanks I don't care what is the debit required.
nikolav
Post by nikolav »
Yummyrum wrote: ↑Tue Oct 21, 2025 10:56 pm Nicolav
I did it with water and over the coil actually. The cup itself is not restricted in anyway.
nikolav wrote: ↑Tue Oct 21, 2025 11:35 pm I don't have any reason to doubt the design of the still. I am not expecting it to be any better than T500, just easier to operate.
Correct , they are as good as a T500, but a whole lot easier to operate, Once you get your problem sorted you should be happy with it.
nikolav
Post by nikolav »
These I guess:
nikolav wrote: ↑Tue Oct 21, 2025 11:38 pm
That is good . So the internals are fine.
Everything that is being condensed by the Reflux coil is from the sound of things, falling into the cup .
If there is no restrictor fitted ( just use a 3/8” nipple ) and the valve is open , it should work just like a Pot still and with 2kw boiler , you should be able to strip at at least 3-4 litres an hour .
So , if that works , then I’d look at the restrictor hole size .
EDIT: or fuck the valve and restrictor off and put a real needle valve in there. :thumbup:
SW_Shiner
Post by SW_Shiner »
Well everything sounds fine with the column. Maybe it is just the boiler being under powered for the column. From memory, the older ones from the start of T500, were 2000w. Now the new ones ( The one i have), have two 1100w elements switched separately. If the head is designed to be on top of a 2200w boiler, running it on a 2000w boiler may be the cause of it running sub optimally.
Was thinking that at first SW , but, it’s an LM . The takeoff rate is always dependant on the valve setting or restrictor size . Reflux stills run with reflux ratios of at least 10:1 . So unless the power was reduced to less than 200w , the takeoff rate should not change . Only the reflux .
But the OP did say that he was pulling 92-93% so that would suggest there is a heap of reflux going on suggesting the power is not that far off .
So it’s coming back to what is causing the restriction in output .
SW_Shiner
Post by SW_Shiner »
I remembered OP mentioned he had tried both nozzles with no difference in output, which led me to believe there was not enough vapour going up the column. I had a similar thing with my boka, started with a 2000w element, upgraded to a 2400w and it was able to run faster while holding the same proof.
Looking more, gen 1 boilers may be 1850w, not 2000w.
Actually, something just came to mind. Since this design doesn't capture 100% of the reflux, unless it all flows down the guide stick (which its not going to do). Distillate sticking to the walls may be an issue. If the column is set up off level, or if the condenser contacts the internal wall.
nikolav
Post by nikolav »
Yummyrum wrote: ↑Wed Oct 22, 2025 12:32 am
That's what I did. No packing or restrictor. Same output. Well I used water, but I don't think that is the issue. At the end of the day, I should be able to make distilled water if I want to.
nikolav
Post by nikolav »
SW_Shiner wrote: ↑Wed Oct 22, 2025 1:47 am I remembered OP mentioned he had tried both nozzles with no difference in output, which led me to believe there was not enough vapour going up the column. I had a similar thing with my boka, started with a 2000w element, upgraded to a 2400w and it was able to run faster while holding the same proof.
The condenser does contact the internal wall. It's a very tight fit actually.
Otherwise it's level. It sits on.my garage concrete floor, which is dead flat.
yeah that bit gets me too SW .
There is no doubt that something is funky .
Maybe the factory accidentally included two of the same size restrictors instead of the two different ones .
I guess this is why I keep asking the OP to run the still with everything unscrewed from it and just see what comes out the hole in the side .
nikolav wrote: ↑Wed Oct 22, 2025 2:47 am
Did you have everything unscrewed …..no valve ….nothing . Just a hole in the side of the still .
Was there water pouring out or just a few small dribbles ?
Incidentally , water and ethanol will seriously differ . 2kw will vaporise a hell of a lot more ethanol than water . So tiu can expect lots more condensate from ethanol than water for tye same power input .
Also , due to the differences in surface tensions , how the condensed liquid runs off the coils or runs down the walls or follows the wires to the cup will vary significantly .
Not to mention , how it flows through a tiny little restrictor hole .
nikolav
Post by nikolav »
Yes, I ran it with everything unscrewed. No valve. The valve wouldn't be the problem anyway. It is very wide - 5mm internal diameter easily and opens fully.
The orifices of the two restrictors are visible different. Haven't measured the winder one, but the smaller is indeed at least 0.6 mm - 0.6 mm acupuncture needle fits just right.
I found a couple of liters of faints and will try again today. Over the weekend I'll try with a different boiler as well.
SW_Shiner
Post by SW_Shiner »
Im now convinced that the boiler is the issue. Everything else sounds fine. I still believe that if it was designed to run with 2200w, running it on less than that will make it perform different than expected. Turning down the power down further will only make the issue worse. This is assuming that you have run it using the manufactures specifications of coolant flow, and without a power controller, and still get the same issue.
nikolav
Post by nikolav »
Just tried a run w/out any restrictors, valves and packing using some ~40% faints. Same thing.
I was just looking at the Kegland's website and the description of their 35L Digiboil boiler, which is the recommended by them for this reflux. Here's what they say:
* Dual element control (so you can adjust the power from 500watts, 1900watts or 2400watts)
* Compatible with the reflux and pot still that we sell (NOTE: when using our pot or reflux stills do not use more than 1900watts)
So, I have a little hope that changing the boiler will do anything, but I'll try that as well.
SW_Shiner
Post by SW_Shiner »
Do you have a way to measure the actual wattage it is drawing while it is running? If you've got nothing but an empty column, and its still only drippling, I'm like, 99% convinced its the element. Or possibly the controller is broke, have you run it without the controller? Same issue?
nikolav
Post by nikolav »
No, I don't have anything to measure what it is drawing. And I don't know how. :(
I run it directly, without the controller.
