6 inch bubble cap glasser
Corn Cracker
Re: 6 inch bubble cap glasser
Post by Corn Cracker »
Ain't nothin but a step for a stepper like you, Shady
Here's the top plate downcomer with a reflux spreader.
After pounded waves into the ring, I discovered it was now smaller in ID and wouldn't fit so filing was needed. :roll:
jonnys_spirit
Post by jonnys_spirit »
It just might be a rumbrella
Very cool project Shady !
jonny
Rumbrella, that's what I was going to call the piece that spreads the reflux from the defleg over the top plate.
But I'm getting ahead of myself on that part of the build because it might not be needed. :wink:
If everything goes according to plan, the dephleg will drip reflux all over the top plate.
Copperhead road
Post by Copperhead road »
Shady did you end up getting the correct Seals for leak test?
Considering you started out with a furnace and a pile of scrap copper it’s all really starting to take shape and come together resulting in a very cool unique 6” glasser build.
Copperhead road wrote: ↑Thu Oct 30, 2025 5:07 pm Shady did you end up getting the correct Seals for leak test?
I searched for PTFE seals that had a silicone core but couldn't find any, so I bought a sheet of 1/8" food grade silicone and several rolls of PTFE tape.
Once I finish building all the copper parts, I'll cut the silicone sheet into rings and wrap it with several layers of PTFE tape.
30xs
Post by 30xs »
https://ebay.us/m/EhS0Rr
Something like this would allow you to machine out a couple grooved gaskets. I made a mandrel to cut flat copper discs with no holes I can try to get a picture of. A little expensive but could be done from solid PTFE.
I think solid PTFE is going to be too hard and not conform, That's the reason for silicone and PTFE tape.
Almost done with the plates, all they need is string wrapped around them for glass to plate seal.
Depending on how tight the plates fit in the glass a rod might be needed to hang the plates from.
If a tree bolt is needed, a 1/4" hole will be drilled in the bottom of the downcomer cups.
Sounds like a good option to me Shady . :thumbup:
Making the gaskets that go between the glass and end caps.
I'm not very proud of this one but there's enough material to make several and I'll pick between the lot and use the best 2.
Maybe with practice I'll get better at making them.
On a side note, trying to grind off imperfections from poor cutting doesn't work worth a shit on silicone. :lol:
I’ve found the easiest way to deal with it is to put a round thing on it of the correct size and cut around it with a very shape Stanley knife .
I'm thinking of a cutting tool made from a razor blade glued to stick of wood with 2 holes that can be used for a pivot point to center first the OD and then the ID of the cuts. Might work, might not. Here's a drawing to give folks an idea of what's in my abbynormal brain. :lol
Steve Broady
Post by Steve Broady »
I’ve started using this stuff for gaskets, especially for sight glasses. It’s some form of magical PTFE tape that you can shape almost like putty. I have no idea what the adhesive is, but I figured it is only there to hold the tape in place until it gets properly squished. Anything that might be exposed afterwards should be completely dissolved in the cleaning run, and in any case it’s got to be better than a silicone gasket in high proof spirits.
Here I’m using it at both ends of both glass cylinders, so four layers in total. Properly applied, it seals perfectly in my experience.
Steve Broady wrote: ↑Sat Nov 01, 2025 6:34 pm IMG_9135.jpeg
" It’s some form of magical PTFE tape that you can shape almost like putty"
I don't know what' you're using, but PTFE isn't noted to be squishy.
For now, I'll use silicon for squishyness and wrap it with PTFE tape because it's inert to hot alcohol vapor and other byproducts of fermentation.
SW_Shiner
Post by SW_Shiner »
shadylane wrote: ↑Sat Nov 01, 2025 4:20 pm I'm thinking of a cutting tool made from a razor blade glued to stick of wood with 2 holes that can be used for a pivot point to center first the OD and then the ID of the cuts. Might work, might not. Here's a drawing to give folks an idea of what's in my abbynormal brain. :lol
I think that should work pretty good. I have a similar tool that I used to cut out the centre of gaskets for pump housings.
SW_Shiner wrote: ↑Sat Nov 01, 2025 7:36 pm
I've got something similar that's made for cutting circles.
Unfortunately it will probably take longer to find than it will to make one. :lol:
Steve Broady
shadylane wrote: ↑Sat Nov 01, 2025 7:35 pm
It’s sold as “Expanded PTFE Tape.” https://a.co/d/0T3YlLb
As you said, PTFE isn’t known for being soft which gave me some reservations early on, but I will say that this stuff looks and feels and behaves a lot like a somewhat foamy version of the standard plumbing tape. And all that I have used in and around stills remains completely unchanged aside from occasional surface grunge. It sure seems like it’s inert, as PTFE should be.
I’m certainly not going to advocate for the stuff or trek another what they should be using, but I thought it might be helpful to share it. I learned about it here on HD some time ago, and it’s worked quite well for me.
End gaskets are done, next is to wrap the plates with string.
Damit man, nothing to show today other than I cut all 6 tie bolts too short.
Now I have to wait for amazon to bring some more. :roll:
shadylane wrote: ↑Mon Nov 03, 2025 3:23 pm Damit man, nothing to show today other than I cut all 6 tie bolts too short.
That's a shame .I was hoping you were going to wrap the string . I'm wondering how you hold it in place so it doesn't slide off the plate rims when you slide it in the glass ?
I'll do the string trick the same way I did it on this 4" glass build.
viewtopic.php?t=78254
The inner diameter of glass is notoriously imperfect and trying to get a usable seal can be difficult.
Here's a crude drawing of the workaround I've been using.
The plate OD is intentionally ground to be loose in the glass tube.
A ring is soldered to the plate and shaped to hold the cotton string from slipping off the ring.
decoy
Post by decoy »
I used copper braid, hope this helps.
I haven't thought about copper braid, there's definitely possibility's especially on a sieve plate build.
The first thing that comes to mind is me getting ham fisted with soldering on the braid and it becoming solid. :lol:
I'll have to give it a try but not right now since I've already headed down this path.
Shady , I saw on your 4” that you tried the ring as shown above and also below the plate . Whats your opinion on that now ?
Sorry for all the questions , I just remembered the string thing yiu did and it’s stuck with me as a good idea . I need ti make plates fir my stripper and hoped to try this as a slide in .
It worked very well.
Almost zero reflux got past the string seal to drain down and what vapor tried to sneak past the seal had to bubble up through the liquid.
It made the sieve plate easier to load with the seal than without it.
In hindsight, having that good of a seal was almost wasted on a sieve plate were weepage and bubbling are natural part of the plate action.
I'm thinking on a 6" bubble cap plate having a good seal is important considering the 18" circumference.
That and I want to be able to run the caps super slow if I want and weepage would limit that ability.
Yummyrum wrote: ↑Mon Nov 03, 2025 9:43 pm Shady , I saw on your 4” that you tried the ring as shown above and also below the plate . Whats your opinion on that now ?
This was the worst design.
It held reflux on the plate but let vapor sneek past without mixing with the liquid causing smearing.
Here's what happens with no seal, the weepage was excessive and the plate needed lots of power to overcome it.
But there was vapor/reflux interaction.
It's easier to have the ring centered the plate so it can be bent to hold the string from slipping.
Chauncey
Post by Chauncey »
excellent thread shady
