1st grappa
jonnys_spirit
Re: 1st grappa
Post by jonnys_spirit »
About halfway through a 14 day ferment on these two 20g brutes of Barbera grapes that came in @25 Brix and it’s looking great. More juice extraction that the Zin and PS i just did so I’m thinking i’ll get a 6g carboy of free run plus a gallon maybe 1.5g extra for top up and tester bottles as it bulk ages for 18-24 months. With the juice extraction I’m feeling like the remaining juice component will contribute about 7g to the second ferment and won’t need to actually press. I decided that I won’t be using any sugar in this series of runs and I’ll only use wine kit concentrate juice in the second ferment to keep the product 100% grape based and the false bottom in the big still will allow me to adequately spread out the pomace from each large batch.
Napkin math:
Approx 7g of solids/pomace per each second ferment.
Approx 30g of kit juice per each second ferment
Totals about three strips each at about 12g per strip in the 16g boiler. Leaving a bit of headroom because the wine kits 6g volume is based on a higher SG of around 1.090 and i’ll be setting the SG to 1.070 range and shooting for three strips times two on the pomace plus juice.
That leaves me with a full 5g bucket of two yr aged pomace that i’ve been sitting on to split between two spirit runs. I might do a small batch test run on that before committing all the low wines to two year old skins/wine-raisins vapor infusion but there is a nice chocolate aroma when I stick my head in that skins bucket.
Estimated spirit run hearts cut: 5-6g @120pf
jonny
jonnys_spirit
Re: 1st grappa
Barbera grapes dropped to 1.000 tonight from 25Brix in a week so i racked the free run out of the fermented must. No need to even use the press which was easy work 9p on a Sunday. Yield for wine was two 5g carboys at about the 4g mark. I’ll rack these off the gross lees in 24-48hrs and top up into a full 6g carboy with maybe a gallon jug extra for top up. Give all the wines into Nov to complete MLF before racking, sulfiting, and adding french oak. Light and medium toast this yr.
Everything left in the fermenters goes towards the grappa and it’s still pretty juicy in there. I probably could’ve yielded around 15g wine off these grapes if pressed but it’s not going to waste :) I did sample a couple bottles of 2022 Barbera this weekend from the same vines and I was surprised how good it was even if that yr was a little high in ABV.
-jonny
jonnys_spirit
Re: 1st grappa
50g barrel filled with pomace from 400lbs of wine grapes, six wine kits, and topped up with water to an sg of 1.070’ish. Threw in 16g of fermaid. No additional yeast added. Expect a nice cap to form and i’ll punch it down daily until dry.
Planning for three strips with the pomace on the top side of the false bottom also with pomace reserved for the spirit run.
-jonny
adamf
Re: 1st grappa
Post by adamf »
jonnys_spirit wrote: ↑Sat Oct 11, 2025 2:25 pm Planning for three strips with the pomace on the top side of the false bottom also with pomace reserved for the spirit run.
Looking good!
How will you use the pomace in the spirit run?
"...and I wound up spendin the night in a corrugated conduit with a cat." Suttree, Cormac McCarthy
jonnys_spirit
Re: 1st grappa
adamf wrote: ↑Sat Oct 11, 2025 3:07 pm
Looking good!
Thanks Adam. I’ll probably reserve some of the wine for a 1.5 style spirit run as well as using pomace in the boiler and riser/onion heads. If I can get the skins in there every-time I run it, i feel like it adds that flavor :)
-jonny
Copperhead road
Re: 1st grappa
Post by Copperhead road »
Jonny I have been following your thread with interest. How did the spirit run go with pomace stuffed in the onion and column.
Did this technique by adding pomace into the vapour path bring a lot of flavour carry-over into the distillate. ??
jonnys_spirit
Re: 1st grappa
Hey Cooperhead. I haven’t run it yet but it’s down to an SG of 0.995’ish so it’s ready. Cap is however still forming and it’s definitely losing some firmness when I punch it down. Might get a couple more gravity points out of it.
I have run with pomace in the vapor path in the past on my smaller still using varying amounts of sugar and yes it’s plenty flavorful. Really gives a grappa flavor and aroma. This will be the first time with all grape + pomace (no sugar) and i’ll be able to run three strips in the larger still with the false bottom plus pomace/wine then low wines + pomace for the spirit run... Not sure if that’s more of a brandy or a grappa this go-around but the skins do impart a lot of flavor IMO.
Unfortunately, I’m about to do a run at work for a couple/three weeks straight so it’ll have to wait at least until after that.
jonny
Copperhead road
Re: 1st grappa
Thanks for the update Jonny.
jonnys_spirit
Re: 1st grappa
Cooking some grapes!
Chugger pump is recirculating as it heats up. I might hook up a return to run it as a recirculating line during the run.
Jonny
adamf
Re: 1st grappa
Post by adamf »
Inspiring! Thanks for this grappa instalment, Jonny.
jonnys_spirit
Re: 1st grappa
Thanks Adam! Seems like one ~16g boiler charge stripped down to ~211*F in the onion head yielded almost a full 5g carboy at 50%abv. Not sure how that happened. I was expecting more in the 30%ABV range for a 5g carboy of low wines. I might need to rethink the spirit run(s) and/or remaining strips on this series…
jonny
jonnys_spirit
Re: 1st grappa
Yield from three strips this weekend was 16g total @86 proof. I'm planning to proof this down with wine into two spirit runs on pomace.
The wine kit wines were higher SG than I thought hence the unexpectedly high strip ABV. I guess I didn't mix them well enough when I measured initial SG on the second ferment.
Good turnout in any case and enough yield to split between two spirit runs so i'll plan to top up each spirit run with a different wine and different pomace to work two different products into the solera.
On a side note, using the onion heads for pomace worked well but it was a bit messy and I think I'll probably not do that again.. False bottom worked great and wasn't too bad to cleanup between runs..
jonny
zach
Re: 1st grappa
Post by zach »
I've also been busy. Steam stripping this bin yielded 30 gallons of low wine at 22% abv.
There was approximately 160 gallons of pomace or 8 loads in my steamer. Will run these low wines through a 4" CM with two sieve plates when I get a chance.
jonnys_spirit
Re: 1st grappa
zach wrote: ↑Tue Oct 28, 2025 12:07 pm I've also been busy. Steam stripping this bin yielded 30 gallons of low wine at 22% abv.
That's an impressive bin of pomace!
jonny
subbrew
Re: 1st grappa
Post by subbrew »
Reading this thread has confused me. It seems that since you are using a grape wine kit to ferment on the used pumice this would be more like a brandy than a grappa. I am now not sure of the difference between grape brandy and grappa.
I have no experience with grappa other than trying some at a winery in Italy. I was not impressed as it was the closest thing to jet fuel I have ever had in my mouth.
I read this thread as I have planted 36 grape vines so in a few years I should have a few hundred lb of grapes to play with.
jonnys_spirit
Re: 1st grappa
subbrew wrote: ↑Wed Oct 29, 2025 2:47 pm Reading this thread has confused me. It seems that since you are using a grape wine kit to ferment on the used pumice this would be more like a brandy than a grappa. I am now not sure of the difference between grape brandy and grappa.
That’s probably correct. A mix between a brandy and a grappa because of the pomace. This has been an ongoing experiment to infuse the grappa flavor with limited pomace. I feel like the most success I’ve had with that approach is using a geist style protocol with the pomace in the vapor path during the spirit run.
I have been a grappa fan for 30yrs since I first tried it :) It can be jet fuel of course depending on cuts. I have some that’s been in a neutral badmo for a couple yrs that is pretty smooth and a light straw color.
I like to use it also as a base spirit for rakki and similar.
jonny
decoy
Re: 1st grappa
Post by decoy »
Grappa is normally spirits made from the grape must after pressing out the grape juice to make wine.
My father would also caramelise sugar and add it to the grape must for fermentation.
Serbian Process.
jonnys_spirit
Re: 1st grappa
zach
Re: 1st grappa
Post by zach »
subbrew wrote: ↑Wed Oct 29, 2025 2:47 pm Reading this thread has confused me. . I am now not sure of the difference between grape brandy and grappa.
There are three categories of brandy made from grapes
1) Made from wine after pressing skins
2) Made from whole grape or must
3) Made from the pomace or skins only
Grappa, marc, tsipouro, orujo, bagaço and chacha are brandies made from pomace, so category 3
I've made brandies from the whole grapes , category 2, but don't see many commercial versions this type of brandy . In Italy I see Aquavite de Uva, but not sure how well it's distributed. I think much of what Jonny makes would fall in this category which is very similar to pomace brandy.
Cognac and Armagnac brandies are examples of brandy made exclusively from wine, category 1.
I understand the Italian jet fuel comment, as I recently had a chacha and a bagaco that were terrible. If the pomace is fresh you can get aromatics that are delicate that reflect the variety of grapes used. Not all enjoy, but a well made pomace brandy can be quite nice.
jonnys_spirit
Re: 1st grappa
That’s interesting Zach. Brandy > Grappa.
That time of year again :)
I have not run in a while but it’s wine season again and I ordered 600# of grapes for this season so I can make my normal batch of wine and also have enough for a good amount of grappa.
This season, I’m only taking free run for the wine. I use a 4” piece of capped pvc with holes drilled and insert that into the fermented must, drawing the free-run into carboys for wine. Any juice left in the must is not wasted and i’m not pressing for the wine, it’s for the grappa. Also, topping the skins up with wine kit concentrate + water to SG roughly equivalent to 10%abv for the second ferment. That will get pressed and cleared to strip/spirit. This yr, I will reserve some pomace to vapor infuse on the spirit runs instead of running with skins in the boiler like I tried last yr... Seems like that’s best bang for me, considering time, effort, and it tastes like grappa in the end. I’m making Zin, Cab Sav, and Nero in a blend this yr. Cab grapes are from Washington State and Zin/Nero are from Cali. I have about 10g low wines from last season and about 12g second ferment wine also from last season. Planning approximately 45g second ferment wine this season too so should have two full spirit runs if I get them all done. I do have some in a badmo from last yr too so on track :)
-jonny
PalCabral
Re: 1st grappa
Post by PalCabral »
jonnys_spirit wrote: ↑Mon Sep 07, 2026 6:07 pm That’s interesting Zach. Brandy > Grappa.
-jonny
To be a fly on the wall when you produce your grappa, Jonny. Super interesting but so totally far from what I am making here in my habitat.
zach wrote: ↑Sun Nov 02, 2025 6:41 am Grappa, marc, tsipouro, orujo, bagaço and chacha are brandies made from pomace, so category 3
Zach, only noticed your post today, and I have a question: with chacha, you mean Cachaça, is that correct? Cachaça is not a marc type of spirit but a Brazilian rom type of spirit, made from sugar cane juice. If there is a different spirit called chacha I just have learned something new :)
zach
Re: 1st grappa
Post by zach »
Chacha is from Georgia.
https://en.wikipedia.org/wiki/Chacha_(brandy)
I had a bottle of Cachaça from Brazil that was very nice!
zach
Re: 1st grappa
Post by zach »
It is that time again.
I harvested my vineyard of zinfandel in late August and have 80 gallons of must in fermenters. Brix is at 10 now. Started at 25.
In a week or two it will be time to press the wine and strip the pomace.
PalCabral
Re: 1st grappa
Post by PalCabral »
zach wrote: ↑Tue Sep 08, 2026 4:12 am Chacha is from Georgia.
Thanks for teaching me more, zach! One more spirit I'd like to try.
