My first Bad Mo Barrel
Threesixzero
Post by Threesixzero »
I finally took the plunge and decided to make a Bad Mo Barrel! I was fortunate to acquire some four-year seasoned oak from a friend's camp, which was a huge help. I followed the instructions and videos shared by Ben on the forums, and I'm very pleased with the result. The barrel looks quite nice and, most importantly, it sealed up perfectly within 24 hours.
To get the hang of the process, I started small, crafting two 4.25-quart barrels using Bain Marie Pots. I have an 8.25-quart barrel ready for assembly but ran out of time the night I was working on it.
The barrel is now filled with a batch of my homemade rye whiskey. Now comes the true test: the excruciatingly difficult part of leaving it alone for the next year or so!
tjsc5f
Re: My first Bad Mo Barrel
Post by tjsc5f »
Looks great.
The price of those from bad mo legacy are getting a bit too rich for me, good for you for being able to make your own.
subbrew
Post by subbrew »
looking good. I have made 15 so far and will do another 5 or 6 this year. I don't do the spigot though. For me lots of bees wax is the key. As the head swells it squeezes out of the joints. But I have yet to try the product. Three will turn 4 years this late winter and I will start trying them at that time.
MooseMan
Post by MooseMan »
Excellent job 360, they look very professional.
adamf
Post by adamf »
MooseMan wrote: ↑Mon Nov 17, 2025 10:57 pm Excellent job 360, they look very professional.
+1
Impressive and inspiring work. :thumbup:
"...and I wound up spendin the night in a corrugated conduit with a cat." Suttree, Cormac McCarthy
Bolverk
Post by Bolverk »
Looks good.
Not gonna lie, I've been eyeing balling 12 qt bane maries to do the same
Threesixzero
subbrew wrote: ↑Mon Nov 17, 2025 8:30 pm looking good. I have made 15 so far and will do another 5 or 6 this year. I don't do the spigot though. For me lots of bees wax is the key. As the head swells it squeezes out of the joints. But I have yet to try the product. Three will turn 4 years this late winter and I will start trying them at that time.
I am note sure if I will do the spigot on the next ones. And I would do a different design for the bung. Currently I am just using old cork stoppers and I don't see that being sustainable solution. I made the mistake and did not properly sand my bung hole.
Deplorable
Post by Deplorable »
I think you'll find out that a year in a Badmo clone is not long enough. I've been tasting one of mine for a couple of years, and it's about to hit the 4-year mark in February. Of the 5 I have, this one is the oldest.
tjsc5f
Post by tjsc5f »
My oldest is 3 years and 7 months, plenty good enough to drink at this point but I can imagine it continuing to get better for another 4+ years at least.
I like the spigots, makes it easy to sample them a couple times per year, which is half the fun, for me anyway.
Bolverk
Post by Bolverk »
Deplorable wrote: ↑Tue Nov 18, 2025 11:56 am I think you'll find out that a year in a Badmo clone is not long enough. I've been tasting one of mine for a couple of years, and it's about to hit the 4-year mark in February. Of the 5 I have, this one is the oldest.
This tracks, the 1.8 gal badmo has roughly the same liquid to wood surface area as a 53 gal barrel
Deplorable
Bolverk wrote: ↑Tue Nov 18, 2025 12:26 pm
This tracks, the 1.8 gal badmo has roughly the same liquid to wood surface area as a 53-gal barrel
This was always the intent with mine. These were all for spirits I intended to age for a 3-to-4-year minimum. I've got a couple of years left to wait on the other 4 barrels. CROW, 2 PNW single Malt whiskies, and a 3 grain Bourbon.
My nine 1-gallon glass aging vessels do all the heavy lifting oaking house whiskey for daily consumption for a year to 18 months. I've got damned near a lifetime supply of oak fingers for the glass jugs.
Threesixzero
I was figuring on at least 3 years but good to see what others are doing. Since i am new to this I figured 1 year is a good spot to start testing to see what the time has done to the alcohol and try to understand the maturation process a little more.
I am currently reading the cask management book from Matt Strickland which happens to mesh well with making these barrels right now.
I happen to find the science behind the whole distilling process amazing.
Deplorable
I didnt touch my first one until 24 months.
Make enough of 1 thing to fill 2 barrels, use one to take notes on over time, and the other to sit for a full 4 years untouched. Record the tare weight and full weight in grams on the side of the barrel on a painter's tape label.
That way you can keep track of how much you get, and how much the angels get.
My white dog weighs about .85 grams/ ml, so I can keep track of loss over time on all of my badmo barrels except the first one, #238.
Based on the known fill volume and average weight of all my badmos when new, I guesstimate the loss on that one over 45 months to be somewhere near a pint plus what I think I've sampled off over the last 21 months since I started tasting it.
Threesixzero
That is a really good suggestion thank you. I am absolutely going to do that, thank you
Deplorable
Just make sure you weigh the spirit at entry proof, because the proof of the spirit will affect the weight
Threesixzero
Deplorable wrote: ↑Tue Nov 18, 2025 4:27 pm Just make sure you weigh the spirit at entry proof, because the proof of the spirit will affect the weight
Ok I will make sure to do that. When you are pulling from one of these barrels are you noticing a change from entry proof to exit proof?
Deplorable
I've only pulled from 1 of them (the first) and never enough to float an alcometer. In February when it turns 4, I'll pull enough to test it.
subbrew
Post by subbrew »
Threesixzero wrote: ↑Tue Nov 18, 2025 11:40 am
I have been using the 1/2 stainless water pipe plugs for my bung. (npt 1/2 stainless steel Male Thread hex Head water Pipe Plug, adapt to cap brass socket fitting manifold nut (Pack of 4) on Amazon- can't seem to post the link)
And I have never sanded my bung, sounds uncomfortable
Threesixzero
subbrew wrote: ↑Tue Nov 18, 2025 9:03 pm
I like that idea better. It's what I love about this group. Everyone has good information to share
andystanton74
Post by andystanton74 »
Welcome to the DIY badmo club. They look great!
subbrew
Post by subbrew »
I would also worry about a cork pushing out on a hot day building up pressure. A warning, use stainless nails and nail the head in. I did not on my first ones and a hot day, a little sun on the barrel and 2 gallons of Honey Bear Bourbon made the shop smell wonderful when the head pushed out.
Archee72
Post by Archee72 »
I’ve posted this before, but if I was worried about leakage I’d store the barrels above a bunded area that is larger in capacity than the above barrel/s. You can sleep easy then knowing if it does leak you won’t lose your product.
Which side are you on Boy? Which side are you on?
Deplorable
subbrew wrote: ↑Wed Nov 19, 2025 10:36 pm I would also worry about a cork pushing out on a hot day building up pressure. A warning, use stainless nails and nail the head in. I did not on my first ones and a hot day, a little sun on the barrel and 2 gallons of Honey Bear Bourbon made the shop smell wonderful when the head pushed out.
Ben didn't use nails in his early barrel heads. I still have barrel 238 full of bourbon, it's been in there for 45 months, and it's tighter than a frog's ass, but my other barrels are all nailed. When 238 gets emptied, I plan to add a TC ferrule, so when the head goes back in it will get staked.
