My Children
CuriousRay
My Children
Post by CuriousRay »
Just as I'm starting my afternoon nap, they call for a "chat", sigh.
Today however it turns out that my eldest wanted to know what I wanted for my birthday. "well" said I, I just so happens that I have been looking at stills. Long story short, I have a small 30 litre still winging it's way to me and should be with me by mid April.
It's not perfect but its a start :) The very best thing about this still is that it's FREE!
I knew having kids would be a good investment in the long term :)
Wife still not convinced.
Re: My Children
Wonderful children Ray.
Might want to get some bits of copper pipe to through in the boiler and/ or a roll of copper mesh to put in the Riser
greggn
Re: My Children
Post by greggn »
CuriousRay wrote: ↑Wed Feb 04, 2026 3:50 pm
Make something that the wife drinks. Just, maybe, don't give her your first couple batches.
________________
CuriousRay
Re: My Children
Yummyrum wrote: ↑Wed Feb 04, 2026 4:05 pm Wonderful children Ray.
I think these things are subjective ;)
My plan is to assess on receipt.
I am unsure what you mean by "copper pipe to through in the boiler" but think you may mean that I should change the SS pipe to copper?
I think I may need to add another riser and pack with copper but to be honest, with my current objective of rum distilation, I'm not sure if I need copper as it's an all sugar fermentation, well molasses and dark sugar so nothing to create sulphers.
With the still design I think I can chose the size of column which is currently 2" but I can alternate between a pot and a reflux still of different diameters if so desired.
Currently, very happy.
Copperhead road
Re: My Children
Post by Copperhead road »
CuriousRay wrote: ↑Wed Feb 04, 2026 4:49 pm with my current objective of rum distilation, I'm not sure if I need copper as it's an all sugar fermentation, well molasses and dark sugar so nothing to create sulphers.
Ray I still think you need some copper in the vapour path. As yummy suggested even some copper mesh inside the riser.
SW_Shiner
Re: My Children
Post by SW_Shiner »
He may have ment throw in the boiler. Copper contact is not just about removing sulfur, there are plenty of other compounds created by the yeast and various other chemical processes during both fermentation and distillation. An easy way to get more copper contact with out swapping out parts, is to put off cuts of pipe or other bits of copper directly into the boiler. Packing the riser with mesh is another way to increase contact. Just be sure to not pack it too tight, it doesn't need to be as tight of packing as is required for reflux distillation.
CuriousRay
Re: My Children
Copperhead road wrote: ↑Wed Feb 04, 2026 5:05 pm Ray I still think you need some copper in the vapour path. As yummy suggested even some copper mesh inside the riser.
Thank you. I will add copper inside the SS tubes. I saw that I can buy rolls of copper mesh so i will use that.
CuriousRay
Re: My Children
SW_Shiner wrote: ↑Wed Feb 04, 2026 5:23 pm An easy way to get more copper contact with out swapping out parts, is to put off cuts of pipe or other bits of copper directly into the boiler.
Interesting, that would never have occured to me, I will definately read up on that.
Again, thanks.
Re: My Children
Yummyrum wrote: ↑Wed Feb 04, 2026 4:05 pm Might want to get some bits of copper pipe to through throw in the boiler and/ or a roll of copper mesh to put in the Riser
woops , my bad. :oops:
CuriousRay
Re: My Children
Yummyrum wrote: ↑Wed Feb 04, 2026 5:46 pm
:thumbup:
MooseMan
Re: My Children
Post by MooseMan »
That will make a good start Ray.
The kids will thank you once the free drinks start to flow, and I'm sure the wife will be more convinced when you start to produce something she likes.
Get your hands on some copper pipe, any size and shape, cut it down to bits small enough to put into the boiler.
Give it a scrub if it's old and dirty, doesn't matter.
When you get the still, you're going to do a vinegar run (You knew this already front the required reading, right?) so you can just drop the bits in and that run will clean them up nicely.
Do your water steam run immediately after, followed by a sacrificial alcohol run, and that's it, leave them in there.
Push a loose wad of copper (Make sure it's pure copper!) mesh into the riser too, and you're good.
Oh, and tape over the face of the thermo, it's just a distraction.
CuriousRay
Re: My Children
MooseMan wrote: ↑Wed Feb 04, 2026 11:05 pm The kids will thank you once the free drinks start to flow, and I'm sure the wife will be more convinced when you start to produce something she likes.
The wife doesn't drink. I could tell the kids that it didn't work and try to give them the foreshots or tails. Ooo, I could call it Dad's smelly sock rum :crazy: :lolno:
MooseMan wrote: ↑Wed Feb 04, 2026 11:05 pm When you get the still, you're going to do a vinegar run (You knew this already front the required reading, right?) so you can just drop the bits in and that run will clean them up nicely.
Everything I read tells me to dilute vinegar but to what percentage? I see that normal vinegar is about 5%, so diluted should be about 2.5%. I have lots of acetic acid but it's at 30% so I will dilute it down with distilled water to 2.5%.
MooseMan wrote: ↑Wed Feb 04, 2026 11:05 pm Do your water steam run immediately after, followed by a sacrificial alcohol run, and that's it, leave them in there.
:thumbup:
MooseMan wrote: ↑Wed Feb 04, 2026 11:05 pm Push a loose wad of copper (Make sure it's pure copper!) mesh into the riser too, and you're good.
I saw some coils of copper that I can stuff in the riser. The question is if I buy pure copper or something that is advertised as pure copper but isn't. Maybe saddles instead, who knows.
MooseMan wrote: ↑Wed Feb 04, 2026 11:05 pm Oh, and tape over the face of the thermo, it's just a distraction.
The only thing I currently use the temperature gauge for is to know when I'm at the end of the run. I try to make my runs at a simmer rather than a boil, and boiling/simmering at 100°C means to me 5% alcohol or less left so time to stop pulling 95% water. If I want water I can turn the tap on.
Copperhead road
Re: My Children
I dilute the vinegar with water 50/50 so you are correct in what you are doing Ray.
PalCabral
Re: My Children
Post by PalCabral »
CuriousRay wrote: ↑Wed Feb 04, 2026 3:50 pm I knew having kids would be a good investment in the long term :)
Kids can be great, mine gives me 5L jars. And wives are often not convinced. Mine doesn't drink either, but she accepts my hobby. She tells me, however, that I am accumulating shit. Her words.
You have a great still there, CuriousRay. And so much potential for you to enhance and grow. The copper is a good suggestion. The mesh you posted will be great inside the riser and you can throw some of it into the boiler too. It will help. At some point you may want to upgrade a little (it happens, I've heard :roll: ) or maybe you're into DIY, and perhaps you'd like to replace the elbow with a copper one or increase the tower with a 45cm copper spool? Or maybe go big, and get a copper onion? Time will tell if you think you'd want it. But copper in the ascending path will make your liquor taste better.
As for vinegar, if you're in the US it's 50/50. If you're in Europe, it's 1:3. The vinegar in Europe is more concentrated so you can dilute it more.
CuriousRay
Re: My Children
PalCabral wrote: ↑Thu Feb 05, 2026 12:24 pm At some point you may want to upgrade a little....
This is one of the reasons I picked this still, it has an 8" opening and a 4" tri-clamp reduced to a 2" tri-clamp so there is a huge range of future options but I can keep it exactly as-is if I don't get the urge. I don't want to get too far ahead of myself though as I'm still playing with a 4 ltr water distiller but the tri-clamps mean that I can make my own extras, and mix and match with standard market products too.
The other reason I picked this is because it is quite reasonably priced at USD 260 door to door.
PalCabral wrote: ↑Thu Feb 05, 2026 12:24 pm As for vinegar, if you're in the US it's 50/50. If you're in Europe, it's 1:3. The vinegar in Europe is more concentrated so you can dilute it more.
:thumbup:
CuriousRay
Re: My Children
To update, I put some copper in my 4 litre gizmo, some in the spout, some covering the spout and some in the pot and ran two rum low wines though it.
The first came out really clean and the second less so but both came out cleaner than I expected.
Thank you.
MooseMan
Re: My Children
Post by MooseMan »
Success!
Keep at It Ray, and keep reading the forum whenever you can, you'll soon be making some fine spirits to be proud of
CuriousRay
Re: My Children
MooseMan wrote: ↑Thu Feb 26, 2026 11:03 pm Keep at It Ray, and keep reading the forum whenever you can, you'll soon be making some fine spirits to be proud of
My eyes are not bleeding yet but they have started to water :)
I know when I have found a hobby I can really engage with because after 20 years of the wife saying "it's too cold" and me saying "OK" and going to sleep, she is now saying "it's hot up here" and I'm saying "do you want me to turn the heating down?" then going back to read the forum ;)
