stainless steel thumper
colin79
Post by colin79 »
Hello,
I have a Vevor kit with a thumper which is steel, so it loses a lot of heat and leaves a lot of distillate in it. I have two ideas about treating this.
1. Wrap it in towels
2. run a small gas burner on simmer under it
Currently the thumper has no thermometer, but I am thinking of adding one. Let me know what you think is a good solution.
Cheers
C.
PalCabral
Re: stainless steel thumper
Post by PalCabral »
I'm pretty sure, Colin, a thermometer is not going to help you. Trying to insulate it is probably the best. Is it not possible to get more flow from the boiler?
Vevor's a POS and the metal sheets are wafer thin, so insulation and increasing the heat is the only way to counter it, I think.
Bolverk
Post by Bolverk »
A thumper is going to collect a lot of liquid, thats why its generally recommended that they are 1/3-1/2 the size of the boiler.
Sorry to say... Those vevor "thumpers" are woefully undersized. You'd probably be better served just removing it.
MooseMan
Post by MooseMan »
Yeah I'd recommend to just lose the so called "Thumper" Colin.
It's doing more harm than good.
colin79
Post by colin79 »
Folks,
appreciate your comments. The thumper allows the addition of flavorings. I will be making brandy, so I plan to pour some wine in it. Still not sure if I should be adding cut up fruit. I agree that it tends to retain a lot of liquid even starting from empty and I cannot find instructions on what to do with that liquid. is it just tails?
also, nobody thinks that lighting up a heater under the thumper is a good idea? it will evaporate the liquid and force it through the condenser.
NorthWoodsAb
Post by NorthWoodsAb »
The problem with adding heat under the thumper will introduce water vapor to your distillate diluting your final ABV.
Edit as others have said you need more heat from the boiler. Insulating the thumper and line arm from boiler will help reduce heat losses in vapor path.
Uisge beatha
PalCabral
Post by PalCabral »
Honestly, and this is not helping you Colin, sorry, this is why thumper rigs are not for beginners. Pot stills, learning to use them proficiently, then maybe go next level. Learn to balance the pot still before learning to balance a retort to the pot still. My thoughts. Sorry, Colin, no offense!
colin79
Post by colin79 »
PalCabral wrote: ↑Fri Feb 06, 2026 11:29 am Honestly, and this is not helping you Colin, sorry, this is why thumper rigs are not for beginners. Pot stills, learning to use them proficiently, then maybe go next level. Learn to balance the pot still before learning to balance a retort to the pot still. My thoughts. Sorry, Colin, no offense!
No need to apologize. I will probably make a first run without the thumper. I ran the water+vinegar with the thumper, but did not light up the gas underneath. My stove allows me to set up the big bucket on a big burner and put the thumper on a small burner. If the big bucket is boiling then the steam from the thumper can only go to the condenser, it's double distillation. I can even add a thermometer to the thumper and regulate the temp inside.
Prolly on my next run.
PalCabral
Post by PalCabral »
Good luck! Practise makes master!
Bolverk
Post by Bolverk »
colin79 wrote: ↑Fri Feb 06, 2026 11:58 am
Heating the thumper to get it up to temp faster is fine but you dont want to heat it when your actually running... it defeats the point of a thumper. The thumper naturally runs a little cooler than the boiler, it effectively works as a tails trap and will extend your hearts a bit.
Also keep in mind a thumper is not a true double distillation, its generally regarded as a half of a distillation due to the fact that once the liquid gets up to temp not all the vapor condenses in it, some will bypass.
SW_Shiner
Post by SW_Shiner »
colin79 wrote: ↑Fri Feb 06, 2026 11:58 am I can even add a thermometer to the thumper and regulate the temp inside.
Also, get that idea out of your head. A thermometer will not help you at all in this case and will only lead you to more confusion. Too many newbies get caught out with constantly looking at temps and wondering why things aren't working. IMO, until you actually know what the information means, thermometers are a detriment to running a pot still.
SW_Shiner
Post by SW_Shiner »
Pot distillation works on power regulation, not temperature regulation.
Agree with what Bolverk and SW_Shiner said
30xs
Post by 30xs »
Your thumper is just cleaning your alcohol as it passes through the system. Have faith that the good stuff made it to your jars and what’s left in the thumper is nothing you want.
