Malting corn is easy!
tommysb
Post by tommysb »
Haha I like to use a bit of a clickbait title. But, I would say that it's accurate. I've looked through a few old threads on here lately to get inspiration, but I have a mission to malt some corn.
EU definitions of whiskey require that it is made from malted grain, with or without the additions of unmalted grains. Therefore, no malt, no whiskey.
What do you do if you want to make 100% corn whiskey then? You need to obtain some corn malt. What if you want to make 100% corn whisky with local specialty corn? Well, nobody malts that, so you have to do it yourself!
I took delivery of 250kg of 'Belgrano' corn grown by a local farmer, and I want to convert some of that to malt. I make batches of 500litres of wash at a time, using 100kg grain, and so want to be able to malt 50-100kg at a time.
I want to test my malting on some cheap corn first, so I went and bought a 25kg sack of feed corn for 10euro. Honestly, that stuff is not bad either, but I can see that the Belgrano is better.
Reading other threads there seems to be a couple of things you have to do to malt successfully-
1. Soak your corn, and keep it oxygenated throughout the soak and not get infected. (16-30 hours)
2. Let your corn germinate, and keep it moist, and not overheated whilst it germinates. (3-6 days?).
For soaking, one approach is to soak, drain, soak, drain in cycles of 6 or 8 hours (this allows oxygen in).
There's another thread, where someone soaks for 24 hours without draining, but use the addition of Hydrogen Peroxide (H2O2) during that soak which both helps prevent infection though its disinfecting properties, and also releases oxygen. THat H2O2 breaks down into 2H2O2 -> 2H2O + O2.
Anyway, I did a bit of both.
First, dumped the sack into a blue barrel with a tap (and filter!) and covered in water, skimming off as much floater as I could. Left a few minutes, and drained. Just to give the corn a first wash.
Then, filled, covered with water, and left it a few hours. I didn't have any H2O2 at this point, so I just left it. How long? 6 hours? 8 Hours? Something like that. The exact number doesn't matter. Then I drained it and let it air out, and went out to do some errands. Whilst I was out,, picked up 3 0.5 litre bottles of 3% H2O2.
When I got home, it have been airing for some hours. 4? 6? 8? Don't recall, doesn't matter. I refilled with water, chucked in 1l of H2O2, (probably in about 30-50 litres water - 25kg corn covered with 5cm at the top). and went to bed.
Next morning, drain, and leave a few hours. Refill. Add 0.5L H2O2 and went out for a hike. When I got home, I drained again and started to construct my malting tumbler.
This was a 500L 'dorna' used for winemaking, mounted on wheels as rollers. I threw the corn into that on Sunday night and turned a bit.
Corn sits in the bottom of it. There's a few batons screwed to the inside to agitate corn as you turn it. (by hand for now).
One tip - 25kg of dry corn, after hydration, weighs a lot more than 25kg!
Over the next few days I have been turning that thing every few hours, and pouring a glass of water onto the corn if i 'felt' it was getting to dry. This morning, we could clearly see some of the roots starting to grow on the corn - germination is happening!
The root grows out of the pointed end (I think), and the shoot grows the other way. So, I put it in on sunday night, and thursday morning it was like this. It's probably about 11-15c here on average at the moment, so not too hot, not too cold.
This evening, I decided to do an experiment. I took a try of the corn, (now at 96 hours), and decided to try and turn it to crystal malt.
From 20 grains of corn picked at random, here's what they looked like. Germination present in most of them at this point.
Crystal malt is made where you let the corn enzymes convert the starch inside the corn (to make sugars), and then raise the temp to caramelise some of those sugars. Do we have enough enzymes for that at this point? No idea. Let's try.
Anyway, loaded them into a baking tray, covered in foil, (foil to keep moisture in as we try and convert those starches) and put into the oven at 60c for one hour
After an hour in the oven, time to check -
They grain bed didn't seem like it was at 60c. Of course, the oven just sets the air temp. THe grains were warmish and moist, but I think they needed more time. I put the timer for another 30 minutes, and switched on fan assist. Before, I didn't want to, to try and minimise drying out, but I think the heat transfer will be better so it's a good trade off.
Here's what the inside of the grains looked like after 30 mins:
Compared to un-ovened:
I WANT to believe there's some difference, but in honesty, if there is, it's not significant. I will check again in 30 minutes.Differences in taste at 60 minutes? I want to say 'yes', but it's subtle. The texture IS different though, with the oven sample being less hard!
Oh - the smell on this stuff! It's hard to describe, but it's much more intense and rich than unmalted corn. Honestly, I am excited about that. Anyway, going to do another update post when the corn has had more time in the oven at 60c, and then going to raise up the temp to hopfully roast any sugars into caramel.
If there's no caramelisation, I'm still going to have a few 100g of roasted corn I can still use in a mash.
I will repeat this experiment again tomorrow, and maybe the next day to see the 'best' time to start this process. I am SURE that this is too early, but hey, I don't know what I am doing so I might be wrong!
PalCabral
Re: Malting corn is easy!
Post by PalCabral »
Wow! Thanks for sharing this, Tom. My first attempt at malting Emmer wheat was a failure. But I will read your post carefully!
tommysb
Post by tommysb »
Might be due to the quantities involved having more tolerance for over/underhydrating, and temp changes? Just a thought!
tommysb
Post by tommysb »
An update on the 'crystal malt' attempt - after 90 minutes at 60c, still the corn was pretty much the same. There's a few of possibilities for what might be going on.
1) the corn might not yet have enough/any enzymes to convert the starch
2) not enough hydration of the corn
3). The temp is too low for corn, where we need to hit gelatinisation temp for this process to work.
4). Not enough time at 60c, or the corn didn't properly get to 60c, despite oven air being that temp.
I have bumped the (oven air) temp to 100c and will check for changes in 30 minutes. Of course, there is a lag between the air temperature and the actual temperature of the corn.
tommysb
Post by tommysb »
Ok - after 30 minutes at 100c, still no big difference from the first couple.
SO i bumped to 120c and cooked for 80 minutes. Figured that gelatinisation would happen (if not already) whilst enzymes would work if there as the temp rose.
The roasted tray of corn
Random sample of 5
inside the sampled kernels
tommysb
Post by tommysb »
So something has happened! I think that the 'glassy' completely yellow/orange appearance throughout some of them is an interesting sign - suggesting that something has happened to the white starch. Others still have the white, powdery centre.
I will try again tomorrow, when the corn is more modified, on a similar, maybe identical roast schedule, and compare the difference.
Maybe malt the corn until the shoots are longer before drying. This way there's more enzymes for conversion and malt character.
The pics show the corn just past the chit stage of germination, I think letting the corn grow until the acrospire is much longer would be better.
Are you planning to use added enzymes or just the natural enzymes in the malted corn?
Just asking because corn is notoriously low in diastic power and needs to be malted longer and to a higher degree of modification than any other grain.
tommysb
Post by tommysb »
Thanks for the heads up Shady. I saw you had a few posts from a few years back about malting various things.
The majority of this 25kg is still in the tumbler. I added another glass of water this morning to keep moisture up, and turned it around some more. It was cold(ish) last night, I suspect I get more activity during the days when the sun is out, I will check the development this evening.
This is going to be mashed with enzymes, so the diastatic power isn't an issue for me here. Even roasting it a bit without any conversion is fine. Might have to do my next roast Saturday morning. It would be interesting, as that would be almost exactly one week since the start of this malting experiment!
Mentioning chits/chitting - I came across 'chit malt' last night. It's a barely modified barley malt. Apparently it allows Rheinheitsgebot brewers to include practically unmalted grains. I suppose it would work for Single Malt producers, too.
PalCabral
Post by PalCabral »
I will give malting another chance now that warmth is coming back. Stockholm has sun shine today and the temp are roaring at 8C. The snow is melting. With that, the temps in my distillery are more controlled, less variance between day and night. I will give Emmer another chance, maybe I'll try the malted corn a chance too?
Interesting about the Belgrano corn. It's Italian of origin, funny you found it being grown in Portugal. I also read your mashing story of the Milho Rei, the red corn. Do you think it could be the same corn as the Bordeaux Cribbs? They looked very similar, physically. I hope I'll get some of it back from Portugal - tbh, I'd rather bring back Portuguese flint corn than molasses. I think I need to buy a van.. :)
tommysb
Post by tommysb »
Honestly I don't know with the Rei but to me it looks different to Cribbs. I think there is always going to be a bit of genetic variation from cross pollination. The guy who grew Rei for me had a field full. Some of that gets polinated by corn from other fields carried on the wind.
If you look at how corn fertilisation occurs, a single grain of pollen fertilises each corn thread, and each of those grows into a single corn grain on the cob.
My grower would reserve some of the cobs which were 100% red and had the qualities he desired, and save seed from them to replant next year. So there will be some cross pollination and variation even within a local population of corn that's not a heavily controlled hybrid or something.
I think the Belgrano here is actually the name of a hybrid from a company - https://advantaseeds.es/wp-content/uplo ... 26-Web.pdf so probably not identical to Italian Belgrano.
wv_hillbilly
Post by wv_hillbilly »
Time consuming process but it’s well worth it!
tommysb
Post by tommysb »
Yeah been working on this a week - decided to try and dry and roast more today, as a very slight mould smell starting to creep in to the main batch.
I wrote this up a couple of times, and failed to post :(.
The main difference today is that I got a thermometer into the grain bed when roasting, and there's a big difference between grain temp and oven air temp, so need to watch that in future. I filled my trays much deeper too, and without turning, the grains in the middle stay moist for a long time!
tommysb
Post by tommysb »
SO yesterday was spent messing around with the rest of my corn malt.
I have about 20kg left in the tumbler, I tried a few different things as I will outline here. Wanted to just dry first, rather than do the crystal process. TO do the drying, we need to first remove moisture and keep below starch conversion temps. Once moisture has been removed,, we can do a small roast, but not convert starch as there's not enough moisture in there for it to be active (that's the theory at least). In every casem roasting/drying the corn with a heat source improved the smell a LOT. The wet/green corn had a funky/cheesy/lacto smell which wasn't pleasant. Roasting/drying completely removed that, and brought in that wonderful biscuitty malty caramel smell. I don't imagine a green/wet corn beer being any good to be honest.
Oven Drying:
My previous oven roasting I had kept the bed of corn fairly shallow. With so much corn to dry/roast, I decided to fill 4 oven dishes and put in the oven.
First load (saturday evening), - I put in the oven at 45c, and just let it go. Opened the door from time-to-time. This had a really hard time drying (the aim here was to dry), as the moisture in the middle of the deep grain bed just couldn't escape. I'd try to turn the corn from time-to-time. Anyway, it stayed in the oven a few hours, and got dryer, but it really wasn't an efficient way to dry stuff.
Air drying, oven finish:
Next morning, Sunday, weathr was good, so I tried to air dry a load of corn on a tarp.
It was outside throughout the day, but had to move it at the end of the day, as was due to rain at night.
By the end of the day, much dryer, but not as dry as it ought to be. Still, loaded this dryer corn into the 4 roasting dished (again full), and put into oven at 60c. figured that oven at 45 isn't really enough to dry corn well, (especially deep beds) and 60c won't deactivate enzymes. (Not too worried about that though as i use external enzymes).
This worked pretty well. A load of the moisture had been removed in the air, and so the oven heat was able to remove more, and do a small roast.
tommysb
Post by tommysb »
Wood Oven roasting:
Out of curiousity, and also failure from the previous night's attempt to roast in the kitchen oven, I tried to construct a small wood-fired roasting setup outside. I had seen some of the Norwegian farmhouse brewers drying malt over a fire inside a kind of brick structure, just letting the heat and smoke pass up into the malt through perforated planks so realised this doesn't have to be too complicated.
A wood fire is lit underneath and smoke follows the path shown. The shelf in the middle is metal, with some gravel thrown on for thermal stability (slower heat up, less swings). The smoke passing through the chamber to exit should cause airflow, which is, I think the biggest issue with dryin inside the kitchen oven.
This worked relatively well. I was able to also control temp by using a fan to blow in cool air, when the chamber temp got too high. This also carried moisture away so it's definitely something to use in future. If I do this oven in a more permanent setup, (for more malt), I will plumb in a duct and extractor fan that pulls air rather than pushing it.
I realised here, that the deeper beds cause the kind of crystal malt effect, and i guess this can be used if you want that.
The middle of the deep beds almost always just stew, and end up moist, almost sticky. Here is some corn from the middle of a deep bed:
vs from a shallower bed where moister could escape more easily and it could dry more readily:
The wood fire also put in a light smoke character. Not sure that this is really necessary, but it might be interesting.
I think that having various levels of roast/toast/crystallization on the corn will probably bring in layers of complexity that I am quite excited about, to be honest. I will see it as feature, not having uniformity across all the malt I produced.
Overall, it's been successful. I have put on my first 25kg of Belgrano corn to soak, and want to work out a way to dry it all more effectively. I predict a bigger oven, more trays, shallower with corn, and more airflow will do the job. I was hoping to be able to do 100kg batches, I think that might be too ambitious, but 50kg is quite reasonable. After the next 25kg, I plan to upgrade to try and do the 50kg batch.
To reiterate - the smell/flavour got SO much better after drying and light roasting. I am really excited to brew with this.
Bee
Post by Bee »
I found that if there's any, ANY hint of mold that it will come through to the product.
tommysb
Post by tommysb »
O man I hope I am not pushing my luck, but I thought there was a tiny hint just before I started my final drying. After roasting and everything, I can't perceive it at all.
I have another batch in with the 'good' corn, I will err on the side of caution and start to dry it as soon as it chits. I convert with additional enzymes so lost diastatic potential isn't an issue.
Bee
Post by Bee »
I did almost exactly what you are doing, but got a few spots, tiny spots of mold on my corn. I picked them all out, sorted them with a fine-tooth comb and still had it come through to the drop. Had to toss it all.
tommysb
Post by tommysb »
Another week, another 25kg Malted.
This time it was the Belgrano corn. Smaller kernels, seemed harder, less hydrated. This time I had an aquarium oxygen pump in the soak stage to add oxygen.
Schedule was;
Soak 6/8hours /air dry 6/8 hours, for about 30 hours.
Transfer to the tumbler (last sunday). And have been rotating during the week.
Chitting started on thursday, 3/4 days after removal from the soak. The next 2 days (Friday, Saturday) it was raining, so no chance to dry. Today, sunday morning, the corn was well modified. Seemed that the roots were longer than the last batch -
Spread it out over 3 smallish tarpaulins outside to dry in the sun today, as we have better weather:
THis evening or tomorrow, when it is more dry, I am going to roast in either the oven or wood oven thing I constructed outside. I bought 4 more oven roasting trays, so should be able to do more per batch. If the malt is already much dryer, then the oven portion should be much more effective too, as energy doesn't just go to evaporating water, but instead to roasting the corn.
PalCabral
Post by PalCabral »
Great work, Tom. It's hard if not impossible to find malted corn in Europe. Maybe this is the start of a side business?
Oh, I really miss the sun and the warmth from it. I envy you now. We got a bit of snow this night and this damn winter seems to never end. We could need some spring here.
