First-use Romanian oak barrel prep
MattHoll
Post by MattHoll »
A 20 liter barrel I ordered from Moraitis in Greece showed up this week. Romanian oak, ordered here:
https://oinos-meli.gr/en/c/wooden-barre ... k-barrels/
It smelled amazing. And the craftsmanship is lovely. On the body, it’s so tightly put together that it’s difficult to see the seams between staves.
The barrel did, however, come with a wooden spigot, which I don’t trust or want. So, I took an old wine cask cube I had, and drilled out a cylinder. Than I screwed a screw in part way, and used the drill to spin that cylinder against 40 grit sandpaper to lathe the cylinder into a bung shape. The bung is 35mm deep, and is seated halfway into the wood.
To prep the barrel, I rinsed it out with 3 liters of RO water, three times. Some wood shavings came out. I looked inside with a flashlight, and you can see the char. After the rinse, I put about 5 liters of water at 75-80º C in the barrel, so quite hot. Then I stood the barrel so one head got soaked. On the top head, I poured hot water on the outside so it sat like in a swimming pool, to also wet it from the outside. I let it sit, and after a half hour, flipped the barrel and did the same to the other side. Then I repeated this, so each head got soaked for an hour. And I sloshed the liquid around. When the wood was softened a bit by this soaking, I gave the bung I made a decently hard hammering with a rubber mallet, trying to be cautious so I wouldn’t split the barrel head. It went in a few more mm.
After the hot water soak, I dumped the water, and filled the barrel to the rim with cool RO water. There were no signs of leaks from the barrel at any point during this process, even during the very first rinses or hot water soaks. I left the cool water in the barrel for 24 hours. No leaks at all. The bung I made stayed in position.
I’ve read a lot about aging in smaller barrels, and along the way, though I can’t remember where, I read about using barrel wax to seal up some of the wood to reduce the angel’s share and aeration, because of the greater surface contact in smaller barrels. So, I figured I’d give that a go. I used barrel wax from Kegland in the EU. I heated the wax with a hair dryer, and worked off pieces, rolled them into little strips of sort of pasta looking shapes, and jammed them into the chimes, the place where the heads meet the body, that seam. Then I used a handheld torch at a distance to slightly melt the wax so it dripped and created a sort of weld to the wood. I coated the bung I made with wax like a volcano. And I sealed up the seams between staves on the heads. I don’t want to stop the micro oxidation and angel’s share. The intention is to just reduce it a touch because of that greater surface to liquid ratio in smaller barrels.
Here, you can see the waxed heads/chimes/bung:
I dumped the RO water, and it has a faint color to it, and a lovely oak taste. I’m saving the water for my next beer. I’ll brew a Dark Mild (a low abv brown ale) and use that water for that beer and hope maybe a touch of that oak flavor will survive fermentation.
After dumping the water, I poured in two bottles of sherry and two bottles of port. The sherry is an Oloroso-based sherry, Cristina Medium Gonzalez, and the ports are Porto Ruby Fonseca and Porto Bin 27 Reserve Fonseca (all of them cheap, €50 total for the four bottles). I’ll leave those in the barrel for 6 weeks, gently rotating the barrel regularly to soak all staves. The intention is to leech off tannins, but also season the wood with sherry/port flavor. I’ll store the barrel in our house during this, where it’s warmer, so the oak drinks the fortified wines.
About 6 weeks down the road, I’ll fill the barrel with a Queen’s Run/All-Feints Run whiskey that I wrote about here:
viewtopic.php?p=7823913#p7823913
My main worry is that bung I made popping out. But it seems well seated. It had no leaks at the seams when the barrel was filled with RO water for 24 hours. No signs of any trouble. And it now has a wax volcano also holding it in place. The whiskey aging will take place in a basement with some seasonal temp swings, but not big swings.
Any comments welcome and appreciated. I'm a noob, and can't say I recommend all of this madness to anyone, since I've never done this before. But I'll report back over time as things progress. Cheers from the Balkans.
PalCabral
Re: First-use Romanian oak barrel prep
Post by PalCabral »
Interesting. Since I am planning to buy a 20 liter barrel this summer I am interested to learn from your experience with how quickly the oak impacts the liquor and the angel share ratio. Where are you planning to store the barrel while maturing, Matt?
MattHoll
Post by MattHoll »
PalCabral wrote: ↑Thu Mar 26, 2026 11:07 pm Interesting. Since I am planning to buy a 20 liter barrel this summer I am interested to learn from your experience with how quickly the oak impacts the liquor and the angel share ratio. Where are you planning to store the barrel while maturing, Matt?
I'll move it down to the basement. I have a beer room down there. Relatively high humidity and cool temp, so alcohol should evaporate, as I understand it. The whiskey won't go in until 6 weeks from now, though. At the moment, I have the barrel in our house where it's warmer, with the intention of the wood soaking up more of the sherry and port.
I still have to do four more spirit runs of 26-27 liters of feints to fill that barrel, so the seasoning time won't go to waste. Likely, I'll finish those over the next few weeks, then blend the blends into one big demijohn so they can marry before pumping over to the barrel.
MattHoll
Post by MattHoll »
As a precaution, I flushed the barrel with CO2 for 30 seconds. I don't want the sherry and port turning to vinegar over the next 6 weeks. I'm a brewer and have two CO2 tanks, so it's a no-brainer.
MattHoll wrote: ↑Thu Mar 26, 2026 10:18 pm My main worry is that bung I made popping out. But it seems well seated.
Ive put both brass and stainless taps in the heads of my barrels quite a few times. Barrels that range in size from 25L through to 98L.
Ive done it two different ways and never had one leak of let go in any other way.
Some of the barrels have come without any hole in the head, with these I've drilled the correct sized hole and then used a Metal Thread Tap to make a thread to suit the tap. Its important to have the correct size drill bit to suit the thread tap.
Ive also at times just drilled the correct size hole and screwed the tap straight in, not bothering with the thread tap first.
both ways have worked and not failed.
If the hole in the head is bigger than the tap that you wish to install you can buy threaded stainless steel reducers to reduce the hole size down.
Some of the barrels that Ive used these methods on are now in excess of 12 years old , none to date have failed.
MattHoll
Post by MattHoll »
Saltbush Bill wrote: ↑Fri Mar 27, 2026 3:09 am
Good to know. Thanks.
