( non scientific ) By the numbers, trying to predict your outputs ( all grain )
planohog
By the numbers (all grain) , this is non scientific but rather information collected from legal distillers and from rumors collected over time.
Mash : expect 50% converting it to beer
Low-Wines : expect 21% converting the beer.
Spirits say 65-ABV : expect 4-5%
lets try that math with five gallons mash.
2.5 gallons of finished beer
half gallon of low wines
1/4 gallon of spirits.
So those that live in 5gallon buckets quickly find out they
need to make two - three sets of mash.
and carry them to the legal distiller for processing.
- bilgriss
Re: ( non scientific ) By the numbers, trying to predict your outputs ( all grain )
I'm not sure that I'm interpreting this correctly.
I use about 8 gallons mash water to get 5 to 5.5 gallons of beer - more for higher gravity, less for lower.
Most typically from a 5.5 gallon ferment I get somewhere in the neighborhood of 1.5 gallons low wines
Three batches combined (almost but not quite 5 gallons) yields a bout 1 - 1.5 gallons for aging on a good day.
So front to back - 24 gallons mash water ends in 1.25 gallons in a barrel. Very broad strokes here. Less for a sugar wash, more for all grain.
- PalCabral
Why are we talking about volume of water? Shouldn't we be talking about kg/lb of grain?
I use 5kg/11lb grains to produce a 25L/6.6 wash. I stripp this and I get 7L/1.8g of low wines. I distill that again and I have approx (depending on cuts strategy) 1L/0.25g of hearts at about 75% ABV.
This is traditionally mashed Bourbon. YLAY give a much lower yield.
- bilgriss
I agree that is a more relevant metric. It seemed the post was attempting to track reduction of input vs output volume by each stage.
planohog
your front to back is about what I was talking about. Its not hard and fast black and white but rather a decent waybilgriss wrote: ↑Sat Apr 11, 2026 8:36 am I'm not sure that I'm interpreting this correctly.
to plan.
I was thinking about the start of my journey, in five gallon bucket land. I never realized what that really was. tons of recipies in 5gallon,
but very very very few talk about that that might me in a taste-able jar.
planohog
volume of mash, how ever you got there and squeezed it out. ( beer )PalCabral wrote: ↑Sat Apr 11, 2026 8:47 am Why are we talking about volume of water? Shouldn't we be talking about kg/lb of grain?
- Deplorable
This is in line with my results as well. It's a good way to explain to those who are unaware of just how much water is required to make a bottle of spirits. (not including cooling water, of course)
When I explain just how many gallons of water go down the drain for a typical Badmo barrel full of whiskey, people always ask me, "How is this cheaper than buying a bottle at the store?" I can tell right there they have no clue how they're billed for their tap water, or how many gallons of water they use in a billing cycle.
planohog
well , once you compare a mid range commerical to a hobby brew, then that price goes out the window and you claim all commercial is swill and make horrible headaces with 2oz consumed. It is very hard to make cuts on a half gallon of low wines. You have to add water to it to keep the boiler from self destructing and use 1/2 pints to collect . For the new guy with a 8 gallon boiler, make a couple of the 5 gallon recipes and combine the low wines
into one strip run. So yes there is not much in a one and done, first is a strip , to get low wines, followed by a final spirit run of less than < 40abv .
J A
If the concept is that vessel size is limited to 5 gallons, then mash and fermentation numbers should be something like 4 gallons of fermentable wort of around 1.055 gravity from 6.5 gallons of water and 10 lbs of malt with no boil or very short one. That's assuming a reasonable mash conversion efficiency of 70% and some sort of sparge/rinse (usually a mesh bag system of some sort when using buckets).
Fermenter loss for 4 gallons would probably be in the range of half gallon or so, depending on yeast variety and how long it's allowed to sit and clear before racking off for distillation.
If you do that 3 times, you could strip a couple of gallons of 30% low wines and end up with a gallon-ish of 50% spirits.
planohog
heheh 3A now you made it difficult, if the ferment size is 5 gallons , that includes grain water, and space for the ferment so it doesn't over flow all over the floor. Think in terms of a person trying to follow the recipe and buy components to build it. The SG and FG are very real and important numbers but left out to simplify the work. I check them and document those numbers every time but first time . maybe you do not have all the tools yet.
My question for 3A: do you somewhat agree or disagree with the
J A
If limited to 5 gallon vessels, seems like fermenting on the grain is not the way to go. Though, I guess buckets are cheap so you could set up as many as you have room for.
A 5 gallon bucket pretty much brim full should hold about 6.5 lbs of grain plus a little over 4 gallons of water and should yield somewhere between 2 and 2.5 gallons of 1.055 gravity wort for fermentation.
planohog
well i would say after the fermentation has completed and it is no longer active. FG 1.00 ish
siphon the beer off to another bucket.
then squeeze the grain with paint strainer bag and get what ever you can out of the grain
into the bucket with the beer.
now let that sit over night, or say 8 hours . It should settle with a inch or so of spent yeast and other junk we call trub.
This is not going to be used. The rest of it approx %50 of that 5 gallons , this is the beer to be [ sent to your legal friend distillery for stripping run .
one or more of your legal friends stripping runs can be combined to feed one single spirit run ]. The output there is aged or kept white.
JA, only gentle correction for the group is [ change 1.055 gravity wort for fermentation ] to [ 1.00 gravity wort after fermentation.]
couple of other planning items:
1 lb of ground grain displaces about 0.09 gallons of water
6.5 lbs grain = displacement of .585 gallons . ( so you can use the 4 gallons of water and its going to be really full as you specified ).
JA this is all great discussion as we all like to plan our favorite and new recipes in a bucket , with plans on growing them later. It is fun to use spreadsheets to help with the calculations. I often work backwards using my max ferment bucket size and changing component quantities.
some people have had to answer the question from the lady of the house. Why is this big bucket in my kitchen on wheels ?
J A
1.055 would be the gravity after mash conversion and before fermentation. Yes, after fermentation it should be around 1.00 gravity and somewhere around 8% ABV. The amount of finished beer would, as you describe, be less than the volume of fermentable wort within the mash.
I
For brewing beer I developed a pretty complex spreadsheet that allows calculation of all the values of a brewday and fermentation. It works backward from a finished batch amount and list of grain to calculate whether a given amount will fit within my mash and boil vessels. Since I have gotten more into distilling, I have worked out similar calculations that can tell me what to expect from my distillation system so that I know what sort of volumes I need to start with to get a proper amount of stripped low wines for a spirit run, for example.
Beerswimmer
My quick & easy math is that ~5% of the total volume of wash/mash ends up in my barrels
Ut Alii Vivant!!!!
- subbrew
Lot of variables such as initial gravity, cuts, yeast, how low you go on low wines and barrel entry ABV. Just going by water volume as I am not sure of my final volume in the fermenter.Beerswimmer wrote: ↑Fri Oct 23, 2026 12:33 pm My quick & easy math is that ~5% of the total volume of wash/mash ends up in my barrels
40 gallons of water and 90 lb of grain gives a about 35 gallons of beer after squeezing. That will give me about 2.7 to 3.2 gallons of 62% abv white dog.
My question on the initial post was the 50% converted to beer. But when brewing beer I don't have that much lose. On a medium beer 7 gallons of water, both mash and sparge water, will get me 5 to 5.5 gallons in the boil kettle.
- PalCabral
The interesting thing about Planohog's theory is that it actually is correct. At least for me and when I am not using feints.
I love stats and I recently made a spreadsheet to calculate how much pure alcohol I actually get per kg grain. However, the data also makes it possible for me to calculate the percentage of hearts per liter of wash. Without feints, I typically get 4-5% hearts at 70-76% ABV. With feints, it goes up to 7-8%.
- Corn Cracker
Man, I suck at keeping records like y'all, i go about it knowing I want between 1.060 and 1.090 starting gravity, ferment that and do the math for the alcohol % and that gives a rough number of what to expect from that run. I know I could be more scientific about it in many ways but in my mind, we're just making whiskey and enjoying the process and that process is where my notes come into play keeping track of how and why I ran like I did etc.
- Username
Hey CC I keep a lot of records in work, so in my hobby I'm a bit lax like you.
I know I should do better in this department, but like you say we're only making whiskey. I often have to look up what I wrote here to figure out what I done
- Bee
You can basically recover ~50% of the total alcohol with a post still and 2x distillation.
