8" plates
30xs
Re: 8" plates
A scroll saw would make short work of the plate slots. Building the box like Fzb said would be a piece of cake. Pushing the envelope I think I would go for the gusto and do rectangle.
Re: 8" plates
Here's a couple of the caps that I'm going to braze together.
Re: 8" plates
Here's the finished caps after brazing.
Re: 8" plates
All the caps are made and the holes drilled in the plates for them.
I'm waiting until the downcomers are done and the hole cut for them before starting to solder everything together.
Re: 8" plates
Here's the cap dimensions.
Re: 8" plates
I made the downcomers out of 1" ID tubing, they haven't been cut to length yet.
Re: 8" plates
Here's the downcomer dimensions.
Re: 8" plates
Plates soldered together.
Re: 8" plates
Next on the list is to redo the TIG welds connecting the ferules to the copper.
I should have done that earlier but didn't get around to it.
Re: 8" plates
Finished re-welding the ferules and it looks like shit. But the welds are in the inside and no-one will see them.
One of the seals on the window is missing so I need to fix that and then I could put everything together and do a leak check.
- Copperhead road
Re: 8" plates
It’s looking killer Shady….
Can’t wait to see that behemoth running.
googe
Re: 8" plates
Looking good shady, like the angle on the downcomers, any extra flow is a bonus.
"Homer J Simpson"
"Homer J Simpson"
Re: 8" plates
I capped off the bottom of the column and filled it with water to see if there's any leaks and there is.
So instead of fixing them, I decided to put it on the boiler and take a pic.
Maybe tommarrrow I get motivated and do some more work.
- Copperhead road
Re: 8" plates
I like the angle of your site glasses also like googe mentioned, much easier to see what’s happening on your plates.
You’re definitely innovating with leaps and bounds for Home hobby distillers…..
Re: 8" plates
I think it needs a couple more sections for experiments.
Otherwise it looks the bees knees.
That seats getting dusty, time for a ride.
Re: 8" plates
Actually , that boiler looks undersized now .
….wait
Just get on and run the damn thing
….wait
- BigSwede
Re: 8" plates
Shady, that is art. Leaks always seem to pop up in a big, complicated build. Hopefully it's just a gasket rather than a weld or solder joint.
Thank you for all the great details and pictures!
Re: 8" plates
Zero leaks on the plate and triclamp seals.
It's a couple pin holes on the ferule to copper that's busting my balls. Once upon a time I could weld better.
- Copperhead road
Re: 8" plates
I love your work…… Mr Shady
30xs
Re: 8" plates
I’d just smooth out a little of the the ugly that bothers you and just use some stay brite and Harris 8 to fill in the leaks. The structural shouldn’t be an issue with a mostly welded construction. Just my two cents.
I will say it is a thing of beauty as it sets. Top notch work as always.
Re: 8" plates
I'll get the job done, just not as good or fast as I once could.
The extra space between the plates is to limit entrainment. I almost used 12" because that was the size of the copper sheet.
But decided 9" would work as good and be less ugly. Plus I had a need for a couple 3" x 24" strips.
Most of the plate builds I've seen have only 4 - 6" of plate spacing, but I think there's an advantage to have extra distance to allow more time for droplets to fall back to the plate and not get carried up with vapor to the next plate.
Using a 4" glasser that had the plates on a tree, I did some experiments using different plate spacing and found more is better.
- Copperhead road
Re: 8" plates
I decided to give this thread a bump.
How is the 8incher going Shady ?
I get enjoyment out of your wild unique builds....
Re: 8" plates
Everything is done and ready to go, but me.
OtisT
Re: 8" plates
I am looking forward to hearing about your results Shady. One specific question will be how much power you will use for a moderate spirit run rate.
I have an 8” ferrule on my boilers and am thinking about putting two or three plates on that before reducing diameter.
Following with interest. Otis
- Copperhead road
Re: 8" plates
i have been waiting for Shady to post an update.OtisT wrote: ↑Sat Oct 03, 2026 12:40 pm I am looking forward to hearing about your results Shady. One specific question will be how much power you will use for a moderate spirit run rate.
I have been following this thread with interest... Thanx for giving it a bump otis.
30xs
Re: 8" plates
Hanging out with Otis and Copper waiting.
Re: 8" plates
I'll start by running wide open just for shits and grins. The elements are supposed to be 4.5kw each @ 240v.OtisT wrote: ↑Sat Oct 03, 2026 12:40 pm I am looking forward to hearing about your results Shady. One specific question will be how much power you will use for a moderate spirit run rate.
According to my measurements the elements have a higher resistance than they should and including voltage drop I figure just slightly above 4kw.
Just guessing the plates sweet spot will be around 5 - 6kw but only time and experience can decide that.
It's finally cooled off enough to catch up on all the "honey do" things my wife has on her list.
But in the near future, I'll run a sacrificial sugar wash to get some hard numbers for Ya'll.
