Oak stick life expectancy
- PalCabral
Hiya distillers.
Some of my oldest jars with oak are now one year old, and others soon getting there. I am using sticks from american white oak that I've cut from new planks destined for barrels. I've toasted them and charred them. Although they have different sizes, a rough average would be 12cm x 1.8cm x 1.9cm, or 4.7" x 0.7" x 0.75". My longest server is now 367 days old, still in the jar. And I plan to oak even longer, and this leads me to my question.
So the first question I've got is: is there a point where the oak stick will do more harm than good in the jar? Will old oak sticks start impart flavors that I don't want in my liquor? Or will they just stop providing any flavors at all?
Second question: how long will oak sticks this size, or your size, last? How long to do you use them until you put them on the BBQ, or whatever you do with them?
What do you do after the oak sticks have expired? You stop the oaking and bottle or do you add a new stick? Or a used stick? What are your thoughts on oak stick management for long aging stock?
Your thoughts and experience are much welcome!
MooseMan
Re: Oak stick life expectancy
I have got into a habit of using sticks for Bourbon/Whisky, then Rum, then anything else.
If I get the impression that sticks need "Refreshing"or if I empty a vessel that's been there a year or two, I'll let them dry for a bit then re-char them.
I also religiously soak some in red wine and then dry/caramelise them on top of the still when I'm doing a run, then char just one face before putting into a spirit, this has a big effect on colour, and adds a very subtle dried red fruit flavour hint that you probably wouldn't detect if you weren't told to look for it.
Here's an example. On the right, red wine soaked staves added to the aging Rum.
- PalCabral
That’s brilliant, Moose! This is what I will do.
OtisT
I think it’s a preference, with no hard and fast rules. I’ll pull the oak when I think the spirit is ready to proof and bottle, but sometimes I want to see how things develop and will leave them in longer. If it starts to get bitter, I pull the wood out because that won’t get any better.
Using less wood it can soak longer w/o bad effect, though that may take longer to get where you want to be. With more wood, sticks needs to be pulled sooner. Like you, I mostly use 3/4” x 3/4” sticks, 5” or 4” long per quart jar. I like the 4” long sticks more these days.
If the oak is seasoned well (Long), they can stay in longer W/o adding to much bitterness.
I recently pulled some seasoned / toasted oak sticks after four years in an all rye whiskey. I think it would have been fine to drink sooner, but had a goal of going 4 or 5 years. Those 4 yr sticks will be going into my next new make rum.
I reuse sticks w/o any reconditioning. I don’t usually char them anyway.
Everyone dose it different. Experiment and find what you like.
- Copperhead road
OtisT wrote: ↑Sun Jun 07, 2026 4:10 pm I think it’s a preference, with no hard and fast rules. I’ll pull the oak when I think the spirit is ready to proof and bottle, but sometimes I want to see how things develop and will leave them in longer. If it starts to get bitter, I pull the wood out because that won’t get any better.
- subbrew
My sticks are 3/4 by 3/4 by about 2.5 or 3 inches. They are cut from used barrel staves, and are usually from the ends as I cut the middle sections to use for badmo clones. For the product put in jars I try to leave it for 2 years and so far have never had anything that I thought was over oaked. I put in two sticks, both toasted in the oven and then one charred. I have used the used sticks for rum and been happy with the outcome. I did try used sticks on an apple brandy and decided I like new sticks, toasted and no char better. Since I make more whiskey than rum, after two years a few sticks go into a jar to wait for the next batch of rum. The rest get saved to be wrapped in foil and put on the grill or dropped in the smoker to add smoke flavor to steaks, burgers or brisket.
- PalCabral
For my apple brandy 2026 I used a toasted and charred oak stick (12cm x 1.8cm x 1.9cm) that had been in use for 8 months in a jar of whiskey. After a month on jar, the apple brandy has no tints of color and a vary faint wood aroma. I was a bit surprised because up to now I had thought the sticks would be active up until a year in jar, but apparantly not.
- Copperhead road
I never use second hand dominos, there cheap to buy & i have found i get better results using new oak. less oak gives me better results also.
- Deplorable
I've reused a few, but I have a growing collection of them under the bench in the shed. Honestly, most of them will likely end up in the BBQ pit for smoke.
Most of my glass aged stuff stays in the jug with the sticks until the remaining volume in that jug won't make another 750ml bottle when tempered down to 80P.
That last bit gets poured into my Infinity jug, and the sticks removed to dry out before adding to the potato sack under the bench.
When the infinity jug gets too full to add to it, I pull enough to temper down a bottle or two and the process continues.
Stump Lake
Perfect. I am beginning to get a collection of those Oak sticks too. I never thought about using them in the grill. That's where mine are going to go.Honestly, most of them will likely end up in the BBQ pit for smoke
The truth shall set you free. But first it will piss you off.
- Deplorable
Stump Lake wrote: ↑Sun Nov 08, 2026 7:13 amPerfect. I am beginning to get a collection of those Oak sticks too. I never thought about using them in the grill. That's where mine are going to go.Honestly, most of them will likely end up in the BBQ pit for smoke
- PalCabral
I am not a quitter. I don't necessary compete if the odds are too bad but once in the race I don't quit. And I wasn't just going to give up on that 8, now 9, months' old oak stick. I decided to sand and the scrape off all the char from the stick, so that the oak was exposed again. Then I decided to add it back to the jar with Apple Brandy. I dont think it will give much color but I am hoping the brandy can get access to the oak still. I could have recharred it but I already have a used (but younger) charred oak stick in the jar, so l decided to focus on flavor and not color. Let's see if this makes a difference.PalCabral wrote: ↑Wed Nov 04, 2026 11:58 pm For my apple brandy 2026 I used a toasted and charred oak stick (12cm x 1.8cm x 1.9cm) that had been in use for 8 months in a jar of whiskey. After a month on jar, the apple brandy has no tints of color and a vary faint wood aroma. I was a bit surprised because up to now I had thought the sticks would be active up until a year in jar, but apparantly not.
Before: After:
HeyBroChuckNorris
I have a few once-used sticks soaking in a bottle of oloroso sherry that I plan to use to finish one of my single malts in
- Coyote
When I first started I used oak sticks cut to fit a gallon wide mouth jar. 3/4 x 3/4" baked then charred.
I would replace on or 2 sticks for the next used and age for 3 or 4 months. 6 to 8 sticks per jar.
Now a bunch of years down the road I reuse the sticks for probable 12 to 15 aging cycles.
When the aging starts to take more than 4 or 5 months I change a few out. Most will tell me I am
doing it wrong, but Wifey and my lips says it is just fine.
Coyote
Coyote
- PalCabral
Interesting, Coyote. Are you noticing that the flavor impact is there but not the color after some cycles? My impression is that the color fades first.Coyote wrote: ↑Fri Nov 20, 2026 9:50 am When I first started I used oak sticks cut to fit a gallon wide mouth jar. 3/4 x 3/4" baked then charred.
Coyote
- MattHoll
Hello again, Moose.MooseMan wrote: ↑Sat Jun 06, 2026 10:55 am I have got into a habit of using sticks for Bourbon/Whisky, then Rum, then anything else.
Here's an example.
How long do you soak in wine? Does the wine oxidize, get sherry notes? Do you use a small jar for soaking, to reduce headspace with air? Curious. I have some spent oak I want to soak in sherry and reuse, so would love to hear your process in a touch more detail. Cheers!
MooseMan
I'd love to tell you that I use a carefully mapped out process with it Matt, but I'd be lying!MattHoll wrote: ↑Sun Nov 22, 2026 5:00 amHello again, Moose.MooseMan wrote: ↑Sat Jun 06, 2026 10:55 am I have got into a habit of using sticks for Bourbon/Whisky, then Rum, then anything else.
Here's an example.
Any that I intend to wine soak, I'll either air dry or force dry on the still if the timing works.
Then, I'll drop the dry stave's into a convenient jar and pour on just a splash of red (My own, heavy hedgerow red, not the thin cheap stuff you buy) and shake them around in it to have them all wetted, no measures.
If they soak it all up and are surface dry by the next day I'll add a little more to wet them back up.
When I'm next running I'll then tip them into an open stainless bowl that happens to sit nicely on the top of my boiler, and I'll keep turning and flipping the staves to sort of "Bake" the wine residue into them.
Then I just re-char one face and drop them into a vessel!
- MattHoll
Great. Thanks for the info!MooseMan wrote: ↑Sun Nov 22, 2026 10:43 amI'd love to tell you that I use a carefully mapped out process with it Matt, but I'd be lying!MattHoll wrote: ↑Sun Nov 22, 2026 5:00 amHello again, Moose.MooseMan wrote: ↑Sat Jun 06, 2026 10:55 am I have got into a habit of using sticks for Bourbon/Whisky, then Rum, then anything else.
Here's an example.
How long do you soak in wine? Does the wine oxidize, get sherry notes? Do you use a small jar for soaking, to reduce headspace with air? Curious. I have some spent oak I want to soak in sherry and reuse, so would love to hear your process in a touch more detail. Cheers!![]()
