Corn Cracker wrote: ↑Sat Jun 06, 2026 1:49 pm
Pretty cool, Big! Do you have a CNC machine at home?
Thanks Corn Cracker, my machines are manual. I have digital readout, so doing things like die tooth spacing is as simple as moving the table like 0.200" per pass.
Yummyrum wrote: ↑Sat Jun 06, 2026 2:29 pm
I’m excited Bigswede
Did the commercial ones use mesh or solid ? Do you think there is going to be any advantage , between stamping from mesh or solid ?
This is where certain theories on this stuff are way over my head!
It seems that there are mesh varieties, perforated solids, mesh with bigger holes in places, a huge variety of material styles. I'm just going to use some intuition. Making perforations is beyond the scope here. The mesh pressed so well that I think it's a no-brainer.
Coarse mesh (bigger holes) vs finer mesh (smaller holes) - With the segments stacked, it creates angled void channels, through which vapor and liquid can travel and mix. There will be some movement THROUGH the mesh instead of along it, but I think we want the bulk to be along those formed channels. So I'm leaning towards a finer mesh, but not so fine that it prohibits migration through the mesh itself. And a fine mesh creates huge surface area and wetting. Does this make sense?
OtisT wrote: ↑Sat Jun 06, 2026 8:30 pm
Damn Bigswede, this is very cool. And yes, you are nuts, but in a good way.
Looks like a fun project, and I’ll bet it’s gonna work well. Cant wait to see the finished product and hear your results. What size and height of column is this going to go in? Hopefully the same as you use now so you can compare like for like.
Hi OtisT - First go will be a 2" column, since that is what I'm used to, and it'll use a lot less material than a 3". It's hard to estimate material cost for the mesh. It won't be cheap like scoria, but I don't think it'll be too bad. 304SS mesh rolls are all over the place online.
