A wheated peated, inspired by..appreciate input
- Username
So I had a really tasty whiskey last weekend https://micildistillery.com/our-spirits ... h-whiskey/ the Madeira Island one, it's fantastic.
Absolutely not trying for a copy/clone of this but the flavours that it brings together is something else, so here's my thinking.
This derives a subtle peat smoke from one of the casks its aged in, I'm generally not a fan of peat but this really worked for me, nice fruitiness and a definite chocolate note on the end of the taste
So here's what I'm thinking
78% Lager malt
10% Wheat malt
10% medium peated malt
1% pale chocolate
1% brown malt
The wheat is for some fruit, I'm thinking I should probably up this to 20 or even 30%, any thoughts?
I've not used peated malt before and as I say looking for subtle, almost undertone, but I've read it's easily lost so what say you? Is 10% about right
Again new to the roast malts in whiskey but I believe less is also better, 2% overall with a blend of 2 lovely roasts, any feedback?
Edit: I know much of the complexity of this whiskey is coming from the barrels and such trickery, but I think it'll be fun to do a tribute to it and see what it gives me
78% Lager malt
10% Wheat malt
1% pale chocolate
1% brown malt
- PalCabral
Re: A wheated peated, inspired by..appreciate input
Now this is innovative, Username!
I agree with your thoughts. If you want the wheat to show up in this mash bill, you need to crank it up. 20% minimum. With so much barley malt, you need to give it more space.
Did you know, BTW, that Bestmalz (or was it Weyermann) have a smoked wheat malt? Never tried it. I don't think it's peat smoked however, but honestly, I doubt I would be able to tell the difference what heat source the malt was toasted in. Peat or birch wood, how different could it really be?
- Username
They are actually quite different, it's Weyermann, they have 2 smoked malts.
An oak smoked wheat malt, and a Beech smoked barley malt. Think Rauchbier if you've had it.
It's a different, subtler smoke than the peat, more bbq than Irish bog, I think it could be quite nice in a whiskey too.
However in this case I'll stay true to the inspiration for this whiskey and go with the peated malt.
Good call on the wheat, I wasn't sure but it makes sense to up the percentage
- PalCabral
You're probably right. I've never tried to use smoked malt in distilling, or even beer making. - I do love rauch beer but making a smoky whiskey is not on my horizon. I do enjoy a peat smoked Islay whisky every once in a while but I am not slightest interested in making it myself. Yet!Username wrote: ↑Fri Jun 12, 2026 8:32 am
Let us know how it turns out. I am sure that it will turn out great, but if you want that fruit up the wheat a little. Or add 20% corn.
- Username
So, I went ahead with this today, taking onboard the advise from Palcabral
I've also stepped up my mashing in game. I'm now using 2 x 60L fermenters, so rather than 23-25L of wort at a time I've 90-100L.
Half of this I'm going to ferment on the grain in a BIAB bag, the rest I used my mash tun and will ferment as normal.
It'll be interesting to see is there a noticable difference between the 2 post fermentation
Anyway, final recipe is
68% Lager malt (MCI)
20% Wheat malt (Weyermann)
10% medium peated malt (Simpsons)
1% pale chocolate malt (Simpsons)
1% brown malt (Simpsons)
Smelled amazing when running it off.
Pitching Safspirit M-1 yeast as soon as I hit 28C, I leave for a beer break in west Flanders at the end of the week and would like to have this clarifying when I'm gone
- PalCabral
- Username
Just getting round to stripping this today. I put the ferments on to work away before I went on hols, thankfully the M-1 is a quick worker and the bulk of fermentation was finished before the heatwave hit. They were sitting for longer than usual and have developed a touch of sourness, not necessarily a bad thing I believe. Not a lot, no pellicle but it's noticeable from the smell.
Anyway double strip today should leave me with 20ish L of low wines and maybe 12L of wash to be processed when I get the chance, summer time is much harder to allocate time.
Another fresh Badmo clone put together yesterday to put this to sleep when it's done
- Username
Job done, I stripped down a bit lower than normal, I read that's where a lot of the smoke lives. I went down to 3 or 4% off the spout, I normally stop at 7 or 8% don't know if it'll make any difference.
An observation on the 2 different ferments, one was my usual mash tun, run off and ferment as for beer.
I done a second on the grain for the 1st time, brew in a bag style and left everything in there.
Both beers were clear and similar in many ways, the on grain was more flavourful, funky and had more aroma, all subtle enough. However the low wine were quite a bit funkier, not in a beer funk way, maybe more dirty, sniff twice to check kind of a way if that makes any sense. I know not to judge anything from the low wines, I just thought it worth noting.
Anyone found similar when comparing on grain to off grain?
Only question remaining is do I add my feints from my last whiskey into the spirit run, wildly different recipe, but I'm leaning towards doing it.
I think I'm going rum next and then maybe try a bourbon TBC, I know I'll still have feints from this run, getting close to time for a neutral run
- PalCabral
I would not use any feints with my spirits run, but if the recipes are close enough, go for it.
I have only fermented on the grsin with ULAY and aleays thought the the dirtyness came from the yeast. Maybe it’s the on grain part?
MooseMan
Sounds good!
I always ferment on grain as I'm looking for max flavour, I only ever sparged when I was beer brewing so can't help there really, but I'd say any part of your process that adds flavour is a keeper.
If you are doing very different products I wouldn't mix the feints, as it might muddle the tastes and you won't know if it was the recipe or the added feints that brought it.
If you're planning a neutral run then probably best to keep them for that I'd say.
- Username
I went out for a spin on my bike and was mulling over things. I had come to the conclusion that it was a grain funkiness, rather than fermentation funky, so that might line up
- Username
Can't argue with anything there MM, thanks for the inputMooseMan wrote: ↑Sun Jul 05, 2026 5:12 am I always ferment on grain as I'm looking for max flavour, I only ever sparged when I was beer brewing so can't help there really, but I'd say any part of your process that adds flavour is a keeper.
- Username
Well I got ahead of my weekend last night and got the spirit run done after work. It went well, very relaxed, I at last feel I'm getting there.
This evenings job was to go at cuts and making my blend. It was very interesting and quite challenging, in fact I will re-visit it tomorrow. I feel I have the main body in a good spot and will re examine a few jars to add or not.
I seem to have a larger heads cut than usual, I collected a total of 7.2L before running 3.5L to feints. Of this I still have 2.2L plus .2L of fores on the table. I do try to make a call as it comes off the still as a learning exercise and I made this evenings cut in the point I called it yesterday, confirmation bias? maybe.
I had read that the smoke shows up near the end of the run and that's a fact.
There was a real bang of chocolate from 2 of the jars also towards the tails, it's not as noticeable in the blend as expected, but I believe I can still get it. At this point I've very happy with this recipe, if it ages well I can see it being a decent whiskey with added interest, fingers crossed.
As it stands I've enough to fill my latest Badmo clone with a touch over, so a good result all round
- PalCabral
Great, Username! Your efforts are getting results.
What was the total volume in this run? When I don't have any feints going in, my heads cuts are typically between 8% and 12% of the total charge, with feints from 5% to 10%. This is of course totally personal, your cuts on your product will never be the same as my cuts on my product, but it is always interesting to compare.
I can't taste the distillate while running. It totally fries my taste buds. I rub a drop on the back of the hand and smell it. Works for me. My blending often takes days, over a week sometimes. I've learned however not to over-dramatize it. I try to always make a small sample of the cuts, diluted to 40%, that will make the hearts before I finally decide, but too often I am too eager to put the liquor on oak.
I never used peated malt but I've also heard that the smoke comes strong in the tails. So does chocolate flavors, which I've noticed on my malt whiskey. How far did you collect? How much of the total charge was your hearts cut?
I am sure your whiskey will be a success.
- Username
Thanks Pal
Yeah I currently stand around the 20% heads, which as I say is very high for me. My whiskeys would generally fall into the same bracket you indicate. Rum on the other hand, I get leave a tiny amount of heads behind
I'll get back to them this evening, but I'm not too concerned. Fermentation was on the warmer side, but M-1 likes warm. I'm happy where the whiskey is at and won't spoil it by greed
Coming off the still I use the teaspoon method to get a rough idea. A few drops of distillate and more water than spirit, I don't check the abv of the sample, but I find it can give a good indication of where I'm at, when combined with the evidence my nose presents. High abv off the spout I can't tell you anything about what's happening
Thanks for your guidance on the recipe. I feel I'll be using chocolate and brown malts in those percentages again
