Dephlegmator build
- AJB
Dephlegmator build
I like to build stuff. Wherever I can, I prefer to use my engineering background to solve problems and make things myself.
Not happy with the selection of dephlegmators available online, I gave some serious thought to building my own.
I sourced a 304 stainless tri-clamp spool, 400mm long, for the project. That part was easy. The original plan was to buy some copper disc blanks, drill a few holes on the drill press, run copper tubes through and silver solder them in place. First problem: the internal diameter of the spool is 72mm and the copper blanks are 75mm... more rework required. Realising it would be a real pain to get this accurate by hand, I opted to have the plates laser cut from 304 stainless instead. Submitted the order on Friday morning and the parcel arrived Monday at lunchtime! Possibly a few too many tubes, but that can always be changed down the track by blanking some off. Now I'm waiting on the copper tubes to arrive before assembly begins - could be a few weeks. The tubes won't run the full 400mm, more like 350mm, leaving roughly 25mm inset at each end. I will also have 1/2" inlet and outlet that will be welded or brazed on.
Re: Dephlegmator build
Nice , I’m all for max tubes that will fit in the shell . Maximise vapour area in the tubes . What diameter are the tubes ?
There becomes a point of no return . Less than 1/2” OD and the condensed liquid seems to have problem falling back down the walls due to the vapour speed forcing upwards .You got a lot of tubes . Got my fingers crossed this is gonna work .
- BigSwede
We never get tired of seeing good fabrication work. So it's roughly a 3" Dephleg. Hopefully the sheer number of tubes can keep the vapor velocity under control? What size are the tubes themselves? I'm guessing 10mm or so.
One option which works well is to silver braze the copper end disks to the SS spool, and this allows soft soldering of the smaller copper tubes without disturbing the silver braze. If you elect to silver braze the entire works, be ready to have a LOT of BTU handy. The inner tubes will suck away a lot of heat.
If you can give the small tubes a bit of flare on one end, this simplifies soldering or brazing a lot. Something like this:
Thanks for sharing. Looks like a great project.
MooseMan
Love a build thread!
As BigSwede says, flared ends will provide way more surface area and give you a stronger solder joint.
I elected to flare the holes in my plates rather than the tube ends when I built a shotgun, but same result.
- AJB
Thanks for the input, all. Exactly the kind of feedback I was hoping for.
Yummyrum - tubes are 9mm OD with 0.5mm wall, so 8mm ID. Definitely under your 1/2” threshold, but with 19 of them the total vapour cross-section works out to ~955mm². For comparison, a 5-tube 1/2” design gives around 440mm², so per-tube velocity here should actually be lower than in a lot of builds. That said, your flooding point is fair and I’d rather have data than theory. I’m going to build a second plate for 1/2” hard copper from Bunnings (13 tubes fit at a sensible pitch, ~1,213mm² of vapour area) and run both back-to-back on the same spool, same power, same coolant flow. Interestingly the 1/2” version has more flow area but less copper surface (~0.15m² vs ~0.19m²), so it should cleanly isolate whether per-tube diameter is what matters at hobby power levels. Will post results.
BigSwede - the plates are already laser-cut stainless rather than copper, but your sequencing advice still applies and I’m taking it: silver braze the plates into the spool first as the high-heat operation, then do the 19 tube joints afterwards without risking the plate joint. And yes, fully expecting the tube bundle to drink heat. MAPP torch and patience. Good call on the flare too, I’ll put a slight trumpet on one end of each tube before assembly. Solder well plus self-locating tubes sounds like a win with this many joints.
MooseMan - flaring the plate holes isn’t really an option on laser-cut stainless, so tube-end flares it is. Same result as you say.
Copper tubes are still a few weeks out, plenty of time for a Bunnings run in the meantime. Updates to follow.
Sláinte
GrumbleStill
Love to see a good build thread.
A few things you might want to consider, and apologies in advance if these are dumb.
Looks like you’ll have quite a bit of knockdown power there. Is it matched to your power supply? Dephlegs can be finicky to run if oversized.
I didn’t see any mention of baffle plates in the design? These are important for getting consistent performance in a shell and tube.
He takes a different construction approach, but there might be something useful to learn from Twisted Brick’s build viewtopic.php?f=87&t=67972
Looking forward to seeing how it goes.
While Baffle plates may be considered necessary by some, there are many many examples out there working very well with none at all.
Both my 4 inch and six inch are just a couple of examples, there are many hundreds more.
What is more important is a quality needle valve or flow meter to accurately and incrementally adjust water flow to the defleg.
- LWTCS
Baffles are not a requisite at all.
However, they do safeguard against channeling at lower CW flow rates ( if low flow is a desirable goal).
There are other ways to reduce channeling. Opposing port orientation, tangential port orientation as an example.
Baffles can reduce the amount of surface area (through tubes) needed to achieve the same and even better efficiency if dephlegmator efficiency is a goal.
But I would also remind that too much efficiency for a dephlegmator makes the system less responsive.
Responsive behavior at the hobby scale is important because the transitions happen very quickly compared to much larger industrial counterparts.
But also, part of spirits distillation for flavored spirits is to exploit inefficiencies.
Plus one Yummy.
At first glance a shotgun dephleg looks like a tube and shell heat exchanger.
But the optimal diameter is different because the vapor and liquid have to occupy the same space while traveling in different directions.
I think 19 tubes with 8mm ID will work but a smaller number of 1/2" or 3/4" tubes would work better.
Both in knockdown power and controllability.
Agree 100% shady , more smaller tubes in a defleg are not ideal in my opinion.
Less larger ones work fine for defleg purposes.
My old 4 incher runs 4 x 3/4 tubes and works perfectly.
- Copperhead road
I wanted to put extra tubes in my defleg on the Custom build emptyglass did for me Salty, he advised the same as you have and said 4 wider tubes works better than 8 smaller tubes.
I think the same principal works on a shotgun condenser, Emptyglass put three wider tubes in my 2 inch shotgun condenser instead of six smaller ones.
That was all on my 4 inch Bubbler.
- AJB
Thanks all, this thread has earned its keep. The experience here on fewer larger tubes has genuinely shifted the plan, and since the plates are cheap to laser cut and the copper is a Bunnings run away, this feels like a chance to map the sweet spot properly and give something back to the forum.
First change: the 19 x 9mm design is scrapped. Between Yummyrum’s flooding threshold and shadylane’s point about vapour and reflux sharing the same tube, the small-bore option has too much working against it to justify a slot in the test. The comparison will run entirely in the size range you’ve all had success with.
GrumbleStill - fair question on power matching. I’ll be running 2.2kW or 3.6kW elements. Doing the heat balance, the 400mm shell is oversized for both, which lands exactly on LWTCS’s responsiveness warning: I’d be running the coolant valve barely cracked, right in the touchy zone. So the final dephleg goes in a 300mm shell, which handles 3.6kW with sensible margin and stays responsive at 2.2. The 400mm spool gets repurposed as a shotgun product condenser, where oversized is a feature not a bug. Thanks for the Twisted Brick link too, good read.
On baffles - I did look into them before this came up. My conclusion was they solve an efficiency problem this build doesn’t have: they earn their keep in industrial exchangers where surface area costs real money, but here there’s surplus surface for the duty and I’ll be throttling coolant back rather than chasing efficiency. At dephleg trickle flows they can also create dead pockets that make control response less linear. Saltbush and LWTCS confirming the same from experience settles it: no baffles, quality needle valve, and port placement doing the work - diagonal in/out plus the tangential inlet, which I’ll build in when the fittings go on.
shadylane, Saltbush, Copperhead - your collective experience on tube sizing is exactly what I want to build on. I went looking for a controlled side-by-side comparison on the forum before starting this and couldn’t turn one up, though that may say more about my search skills than the archive. If someone knows of a thread where this has been tested on the same shell at the same power, please point me at it and I’ll build on that rather than repeat it. Otherwise, that’s the gap I’ll try to fill. Three plate designs for the same 72mm bore, laser-cut pairs of each:
• 13 x 1/2” - ~1,213mm² vapour area
• 7 x 3/4” - max flow area, ~1,588mm²
• 4 x 3/4” - Salty’s 4-incher geometry brought down to 3”, ~908mm²
That covers the span from “lots of 1/2 inch” to “a few big ones”, so the results should show where the knee in the curve sits between knockdown power and controllability.
Short 200mm test mules first using tube offcuts, run back to back at the same power and coolant flow, measuring knockdown and response time to valve changes. Winner possibly goes in a 300mm shell. I’ll post the results and the plate drawings here so anyone can get them cut for their own build.
Sláinte
Roo
I just clocked your reference to the big green shed...AJB wrote: ↑Tue Jul 14, 2026 9:22 pm Thanks all, this thread has earned its keep. The experience here on fewer larger tubes has genuinely shifted the plan, and since the plates are cheap to laser cut and the copper is a Bunnings run away, this feels like a chance to map the sweet spot properly and give something back to the forum.
Where are you getting the plates laser cut? I just saw this thread and just assumed you were in the states and using send cut send or a similar service.
Is it local to you or are they posting the job to you? I'm just outside Melbourne.
As a side note , you may not have seen this before.
https://www.thermopedia.com/content/691/
Its the definition of a deflegmator.
In my opinion to many people use the word deflegmator and condenser in an interchangeable way.
The two are quite different things that are designed to do different jobs.
Id strongly suspect that if you were building a shotgun condenser then more smaller tubes and baffles might be a good thing.
This is not the case though, your wanting a deflegmator.
- AJB
It was at mates ratesRoo wrote: ↑Tue Jul 14, 2026 10:01 pmI just clocked your reference to the big green shed...AJB wrote: ↑Tue Jul 14, 2026 9:22 pm Thanks all, this thread has earned its keep. The experience here on fewer larger tubes has genuinely shifted the plan, and since the plates are cheap to laser cut and the copper is a Bunnings run away, this feels like a chance to map the sweet spot properly and give something back to the forum.
Sláinte
- AJB
Spot on. Thank you for the read!Saltbush Bill wrote: ↑Wed Jul 15, 2026 12:20 am As a side note , you may not have seen this before.
Sláinte
- LWTCS
As I recall, old dog's very first dephlegmator design was inspired by a drawing that showed a vertically oriented tube-in-shell HX whereby there was only a single, larger through tube. Probably and ideal design for flavored spirits as a lite scrubbing is all thats really needed to create reflux while simultaneously allowing flavour compounds to carry over.Saltbush Bill wrote: ↑Wed Jul 15, 2026 12:20 am As a side note , you may not have seen this before.
What was your recollection Salty? Single or multiple tubes on his original "Majic Flute"?
I suppose I could look at the thread and refresh my memory.
30xs
From memory it was 2” through 4”.
You could well be right Larry, without going back to the original build thread I couldn't say for 100% sure.
His earliest build came up for sale a couple of years back on another Australian distiller site.
Would have been a nice piece of distilling history to own.
What column is the experimental dephlegs going to be used with, is it a packed, sieve or bubble cap?AJB wrote: ↑Tue Jul 14, 2026 9:22 pm
Thats a darn good question Shady .
A 3” running at 2kw on a plated still with beer in the boiler won’t take much effort to knock back 3/4 of the vapour as reflux .( typical running conditions of a 3” plater)
If it is a 3” packed reflux column intended to make Nuetral , it will need all of that 3.6kw and with 30% abv low wines typically in the boiler , there is going to be significantly more vapour hitting the deflag , of which 9/10s or more will need to be knocked down as reflux
Running in full reflux in both instances will obviously take more effort to knock down .
- AJB
shadylane / Yummyrum - it's a 3" bubble cap column with 4 plates (I might add another 2 soon). Mostly running low wines at 2.2kW, with 3.6 available for stripping. So going by Yummyrum's breakdown, I'm in the plated-still camp: partial knockdown around a balance point rather than the near-total knockdown a packed neutral column needs. Good to know the duty is on the gentler end of the scale. I'll set the testing up to spend most of its time at partial knockdown settings since that's where it'll actually live - happy to hear if there's anything else worth measuring while I've got the mules on the bench.
Sláinte
Just my opinion and it ain't based on science or math.
When driving 3" bubble caps @ 2.2kw I think 200MM long 7 x 3/4” is going to be almost too much, shorter might be better for what's needed.
Maybe use around 100 - 150mm, it will be a water hog during 100% reflux. But be much easier to control during the hearts run.
A dephleg is a "partial reflux condenser" anything more powerful than the absolute minimum for 100% reflux is getting too big, unless water use is critical or low water flow is needed so the dephleg waste water is hot enough for mashing the next batch.
The majority of shotgun dephelegs I've seen are way too long and powerful, then folks complain because their CM is fidgety.
- LWTCS
- AJB
shadylane/LWTCS - that's very useful, and it simplifies the project a fair bit. The 300mm final build is off the table then, and the plan improves for it: the 200mm test units were only ever meant to be disposable mules, but at my power they're now candidates for the finished article.
The water hog point is well made too. Waste water has a job here (Sydney water bills being what they are), so a dephleg that does 100% reflux at a trickle without being fidgety through hearts is exactly the target. Sounds like shorter and just-enough is the way there.
Might be a few weeks before there are numbers to share, but the plates are ordered this week. Thanks all for steering this before I brazed anything I'd regret.
Sláinte
30xs
A trickle of water at full reflux and not fidgety do not go hand in hand. A barely capable of 100% reflux at full flow gives a quicker response to adjustments. On a 4” mine is only 4-4 1/2” and easily hits full reflux. Shady’s coil works great that he used works great. Easier to build and almost instant response time. I’ve built both styles, and both work. Shotgun will give you less flow needed for full reflux, but I’d keep height to a minimum.
I have to agree to some extent with that, full reflux needs good flow, however it still surprises at times at how little flow is needed once you have plates loaded and product leaving the still at your desired output speed. When we talk of fiddly , that can often come down to hours of experience that the operator has.
One tiny tweek of a needle valve can change the product output speed a lot. The Art is in getting to know your particular needle valve/ water flow/ heat input/ desired take off speed.....it can be a juggling act when you first start out
Newbs tend to over compensate and not wait long enough to see the change to take effect before tweeking again.
googe
Nice to see a good build happening, awesome advice from the fellas
I've always done the biggest inner tubes that will fit. You'll be amazed how little water flow you'll need to knock down. Multiple small inner tubes are a pain, lots of work for no gain. Flaring, baffles are unnecessary. Hobby distilling is the K.I.S.S principle (keep it simple stupid) i love builds so go hard
"Homer J Simpson"
"Homer J Simpson"
- Copperhead road
That’s a bloody good saying Googe!Saltbush Bill wrote: ↑Fri Jul 17, 2026 2:03 amThats going straight to "Notable and Quotable Goo."
Way to much over thinking goes on at times. Keep it simple , dont take short cuts = good booze.
It’s the way I roll in the shed with the still…
