Dead barrel??
Username
Dead barrel??
Post by Username »
I'm inclined to call time of death on this barrel
It was given to me, had been a display item in a bar for years and came with no bung. As far as my friend could remember there was never anything in it. It smelled/smells like fresh oak
So I made a bung from an oak dowel and Filled with water to seal it up, which was actually a pretty quick and easy affair.
However when I was draining it there were floaters in the water, so I popped the head.
Is there anyway of bringing it back? Google says scrub with vinegar and sand it, possibly add a re-charr into the mix.
Would you chance it? Have you previously done similar, I'd be eager to hear opinions
Corn Cracker
Re: Dead barrel??
Post by Corn Cracker »
Well, youve got the top off, how much harder would it be to dissasemble and rework it, barrels are kinda pricey in my finacial world, i would rework it. If it doesnt work out youll have plenty of staves to cut and age with
PalCabral
Re: Dead barrel??
Post by PalCabral »
Thanks for sharing the pics, Username, I was a bit wondering what the inside would look like when you’ve got mold in there. What was the smell like from the bung hole or when you opened it?
Fire usually kills everything, right? Why not just torch the inside well, like level 3 char or gator skin, the patch up, fill with water to seal, then water mixed with potasium metabisulfite and citric acid to nuke any new growth. Empty after a couple of weeks, empty, rinse real well, the fill with you favorite liquor.
I am guessing here, so this is more a question than a recommendation.
Copperhead road
Re: Dead barrel??
Post by Copperhead road »
PalCabral wrote: ↑Sun Jul 19, 2026 8:12 amWhat was the smell like from the bung hole
:lol: :lolno: :lolno:
Username
Re: Dead barrel??
Post by Username »
Copperhead road wrote: ↑Sun Jul 19, 2026 9:33 am
:lol: :lol:
Thats the weird thing about it, it smelled fine, not musty actually pretty nice oak smell.
There were some floaters in the water as I emptied it, that's what alerted me that all is not well.
Corn cracker I reckon you're right, I think I'm going to work this end and what's accessible of the barrel, re assemble and pop the other end. My thinking is that it would be easier than building it back from scratch
Re: Dead barrel??
Username wrote: ↑Sun Jul 19, 2026 11:03 am I think I'm going to work this end and what's accessible of the barrel, re assemble and pop the other end. My thinking is that it would be easier than building it back from scratch
Sounds like a plan Username .
I’ve never pulled a barrel apart but have read a few posts from guys that did and getting them back together again without leaking is a nightmere .
Copperhead road
Re: Dead barrel??
Yummyrum wrote: ↑Sun Jul 19, 2026 1:18 pm
That’s for sure, yummy, upmost respect to the guys that actually have a go at rebuilding barrels. Being a Cooper is really an art..::
Re: Dead barrel??
Yummyrum wrote: ↑Sun Jul 19, 2026 1:18 pm but have read a few posts from guys that did and getting them back together again without leaking is a nightmere .
Same here Yummy, a lot less go back together successfully than do from what ive seen.
Id pull one head only , clean as best possible and leave it st that.
A high pressure water blaster should clean any crud out.
Copperhead road
Re: Dead barrel??
Saltbush Bill wrote: ↑Sun Jul 19, 2026 1:44 pm
For some reason, Salty I thought you were one of the guys that has successfully put a barrel back together without any leaks.
I was sure I remember a thread you did on CCSC years ago.
And you had a lot of old tools like draw knives and things like that…
Corn Cracker
Re: Dead barrel??
I've read about numbering the staves at one end and only removing the surface the spirit will contact so they go back together with the exact mating surfaces they previously had. Your only shaving the surface of the inside of the barrel. Damn thats was a strong drink
30xs
Re: Dead barrel??
Post by 30xs »
With popping one head at a time and scraping, and there isn’t a thick layer of char, I'd try slipping using a contour card scraper. You could slip a band back on the open end and scrape the inside pretty easily. A sharp scraper just cuts thin shavings.
Re: Dead barrel??
My 2 cents, you already have one end removed. Don't disassemble it any farther.
Use a torch to burn a light char on the inside of the keg and put it back together.
Maybe it will leak, maybe not. Wooden kegs are never perfect.
Re: Dead barrel??
Copperhead road wrote: ↑Sun Jul 19, 2026 1:54 pm Salty I thought you were one of the guys that has successfully put a barrel back together without any leaks.
Ive played around a bit Copper , fixed a few barrels that leaked by using different methods, also had a couple that worked but still were not perfect......Ive never pulled one completely apart because Ive seen how much trouble a few others have got them selves into by doing that.
shadylane wrote: ↑Sun Jul 19, 2026 6:01 pm you already have one end removed. Don't disassemble it any farther.
Spot on, that's the way Id be going to.
Username
Re: Dead barrel??
Post by Username »
Saltbush Bill wrote: ↑Sun Jul 19, 2026 8:42 pm
Fair enough gents, let's see how that approach works. I defiantly know I don't want to re-build from scratch
Powder Monkey
Re: Dead barrel??
Post by Powder Monkey »
viewtopic.php?t=95343
I disassembled, scraped, recharred and reassembled a 5 and 15gallon barrel and detailed some of my learning points above. It was a process and more intimidating before I dove into it but I think doable for most folks. If you weren’t going to disassemble and scrape it I do think taking out both heads would make it easier to clean/sand the heads and also rechar/toast them separately. If you make a small fire inside the headless barrel you can char the staves. Just be careful to keep the mating surfaces where the heads and staves come together intact/not charred.
Username
Re: Dead barrel??
Post by Username »
Thanks for the link and the advise powder monkey, I had already jumped in two feet first by the time I saw it :D
After the advise this morning I decided to leave the remaining head in place, it being only a 10L barrel it's all easily accessible from one end.
It appears to have just been surface mold and came off easily with a good scrubbing, followed by a power hosing, repeated a few times.
I then let it dry out to check when the surface was dry, all looked good and I'm happy I removed everything including a good portion of the original charr.
Insert blow torch was the easiest way to re-charr for me, I didn't overdo it as I was afraid of shrinkage.
It did take two attempts to get the head to seat snug, I pulled it apart and started again when it was obvious things weren't lining up.
Second try went a dream, I used a hammer and cold chisel to set the hoops, I had marked the position before taking them off.
Some small amount of leakage from both heads for maybe 1/2 hour and it dried up nicely.
I had made a sugarhead a while back viewtopic.php?t=95834 which I had hoped would live in this, before I discovered the issue and procrastinated for a while. It's been sitting in various jars at different abv's on different profile oak, those experiments came to a premature end however and it's all blended back together now at 62%abv in it's new home.
Re: Dead barrel??
Username wrote: ↑Mon Jul 20, 2026 9:57 am
Insert blow torch was the easiest way to re-charr for me, I didn't overdo it as I was afraid of shrinkage..
Some small amount of leakage from both heads for maybe 1/2 hour and it dried up nicely..
..I had made a sugarhead a while back viewtopic.php?t=95834 which I had hoped would live in this, before I discovered the issue and procrastinated for a while. It's been sitting in various jars at different abv's on different profile oak, those experiments came to a premature end however and it's all blended back together now at 62%abv in it's new home.
There Ya go. :thumbup:
But depending on how aggressive you got with the torch, don't leave the sugar head in the keg for too long.
Re: Dead barrel??
Another hint, given to me by the Cooper that ive bought new barrels from.
To swell the heads stand the barrel on end the fill the head area with hot water.
Let soak for half an hour, repeat at other end..
Copperhead road
Re: Dead barrel??
Saltbush Bill wrote: ↑Mon Jul 20, 2026 4:43 pm Another hint, given to me by the Cooper that ive bought new barrels from.
Different Coopers give different advice, AP Johns Cooperage told me "never" put water inside New Oak barrels. i use a small kids inflatable pool. fill it just deep enough to soak the head for 24 hours, then flip the barrel and do the other end.
its always worked a treat for me... :D
Re: Dead barrel??
I never said to put it inside.
I was also given that advice by my Cooper, never soak from inside, only from the outside.
Hot water works best what ever the case.
Username
Re: Dead barrel??
Post by Username »
That's interesting. I have used badmo's and clones and followed their protocol on soaking, water was no longer than 2 hours in there and about 50C going in.
Thanks for the tip Shady, I'll be sampling it soon enough :D, the sugarhead is designed to keep me away from the malt whiskeys, so a quickish turn around would suit
Copperhead road
Re: Dead barrel??
Saltbush Bill wrote: ↑Mon Jul 20, 2026 9:43 pm I never said to put it inside.
Apologies Salty my bad, i misunderstood what you said. :oops:
i use warm water also, just heat up 40 L in my beer keg stockpot.
Re: Dead barrel??
All good 👍
Swedish Pride
Re: Dead barrel??
Post by Swedish Pride »
Since you are on the fence about chucking it you may as well pull it apart.
Number the staves and mark where stave 1 lines up on the head.
Make sure to mark the numbers in such a way you can not screw up the orientation of the staves.
Had a small barrel taken apart twice ( once on purpose) and was easy enough to put back together again.
Don't be a dick
tommysb
Re: Dead barrel??
Post by tommysb »
+1 Was given the same advice by a winemaker. Works well.
Username
Re: Dead barrel??
Post by Username »
Just a quick update on this.
What a worthwhile few hours this was.
I just took my first sample from this barrel. Not quite 4 weeks ago I put my sugarhead in the barrel and I'm sipping away on a glass of what is the nicest whiskey I've finished to date. It's amazing the difference between a barrel and glass and staves. Ok so the whiskey going in had a head start in glass and oak but it has rounded out so much better than some of the same liquid that is still in glass. I'm very impressed.
Don't get me wrong, it's a simple one dimensional, bland enough, smooth, easy, whiskey. It's still far from being over oaked, so I guess it will improve some yet. The cuts were tight on this and I guess that combined with it being a sugarhead is where the simplicity and smoothness is coming from. However it gives me great hope for what's coming down the line in a few years when my badmo clones, with my malt whiskeys come good.
I believe it's time to measure up what I have left in glass, of this and bottle the equivalent, so I can get the rest of what's sitting in the jars in there.
I also have a demijohn of a tailsey early attempt, my 1st all grain. It's slowly coming around. I'm tempted to add a small amount of it in here to aid in complexity. I don't want to overdo it though, I'd like to be able to continue to take out young whiskey from this, as I need to and keep out of the good stuff for a few years
I actually never believed such a change could happen in so short a time, happy, proud and just a little drunk :lol:
PalCabral
Re: Dead barrel??
Post by PalCabral »
Username wrote: ↑Sat Aug 15, 2026 11:41 am Just a quick update on this.
Super happy for you, username! I am hoping to be there 6 months from now! :) Keep us posted!
Copperhead road
Re: Dead barrel??
Username i always get the same results as your findings, i 100% guarantee that spirits age so much better in a barrel apposed to glass. i have barrel aged 8 year old bastardised thin mashed corn, wheat, malt barley UJSSM sugerhead and you would struggle to say it wasn't an all grain whiskey.
Barrel + time = Dam good sippin whiskey...
Username
Re: Dead barrel??
Post by Username »
Copperhead road wrote: ↑Sat Aug 15, 2026 2:29 pm Barrel + time = Dam good sippin whiskey...
Appreciate that lads, thanks!
It is a case of follow the formula and accumulated knowledge on this site and the magic will happen.
I believe it was one of your older threads Pal, that inspired me to make this into an infinity sugarhead barrel.
Coming from brewing, I had a snobish notion that sugarhead could never make a decent drink, but again taking a lead from the masses that went before me I took a punt on it.
I know I'm waffling like a child at christmas and at best it's a mediocre drop, but it's the realisation that the good stuff will come.
Anyway, thanks to the hive mind of Homedistiller
Username
Re: Dead barrel??
Post by Username »
A little over 3 months since first fill.
I've pulled several bottles from this as a mixing whiskey, also topped up a bit with all malt whiskeys from jar projects, so it's a bit of a blend and tasting quite good. There's quite a bit of oak in the whiskey now and it's still good, but I think it's getting close to the point where it will take a turn downhill if it stays much longer in there.
I had intended to keep a sugarhead rolling and top this up over time in that manner, obviously not going to happen :shock: I seem to be settling in to a pace where there's something happening all the time in the stillhouse but I'm still keeping up with other hobbies as well.
This leaves me with some questions on where this barrel goes next. A good portion of this will need to come out in the next few weeks I reckon, which is nice I'll have some bottles to enjoy and present over christmas. But then I'll want to fill again
I could blend more of my jars and top up this way, I do also want to keep at least a bottle's worth of each whiskey that I have in jars separate to judge on it's own as time goes on, actually more when I think about it
I could top up with my Bag end whiskey viewtopic.php?t=96355 which will be my next spirit run. But then I'll be blending that and won't know what I get from this whiskey
So what I'm favouring at the minute is to empty the barrel and fill with the new make Bag end whiskey. Being an all grain it will take more time to age and come good I reckon, but I will also be putting it in a 2nd use barrel.
There is a question here as always. What's people's experience with a barrel of this size (10L) on second use. I kind of presume if I got 3-4 months on the 1st fill I should get 6-8 months on second fill, does that sound about right?
