Condensing Water Vapour from a 1000W Water Distiller with PC Radiator ?
WaterisDry
Post by WaterisDry »
I have a water boiler with a 1000-watt heating element and
want to condense all of the water vapour it produces using an Crossflow PC- Watercooler
(no ad but a quick search got me this example Alphacool X-Flow Copper Condenser)
I'm not sure what size would be appropriate, or what fan power is needed.
Any advice on the lightest condenser that would be sufficient for this task?
Something like a condenser that is 10% overpowered,
to condense 1100 watts of water vapour.
(I know how to solder copper piping and connect it all up this is only about finding a suited crossflow radiator.
Re: Condensing Water Vapour from a 1000W Water Distiller with PC Radiator ?
Instead of using a pump, radiator and fan to supply cooling water to a condenser. Just use an aircooled condenser.
WaterisDry
shadylane wrote: Sat Jul 25, 2026 4:15 pm Instead of using a pump, radiator and fan to supply cooling water to a condenser. Just use an aircooled condenser.
I actually want to use the PC Radiator as the condenser , the steam will enter the PC condenser, i dont use this to cool my condenser...
My bad, I was confused as normal. :lol:
The radiator is going to be used as an aircooled condenser.
A radiator could be used to condense water vapor but it would be the wrong tool for the job.
It works best for a liquid to air heat exchanger, the small tubes have limited surface area for condensation.
What's needed for a condenser is large tubes such as these.
SW_Shiner
Post by SW_Shiner »
Anything meant for a PC probably wont work. Unless you get something server sized, you probably wont find anything that can handle that many watts. Not only that, most manufactures list a max temp of 60°c, and its probably not very food safe either.
If what you are suggesting worked well it would have already have been done here years a go.
If experienced older members say it's not a good idea, then there is good reason for that.
WaterisDry
shadylane wrote: Sat Jul 25, 2026 8:10 pm A radiator could be used to condense water vapor but it would be the wrong tool for the job.
if I want to use such a heat exchanger how much length and pipe diameter would I need to condense 1kw of water vapour?
since I need the lowest weight most compact condenser.
BigSwede
Post by BigSwede »
WaterisDry wrote: Mon Jul 27, 2026 9:33 am
Shady is correct, wider piping is a requirement to condense vapor to liquid and have it flow without huffing, spitting, or system back pressure.
Guys here have for decades worked with every imaginable form of condenser, seeking efficiency and yes, a compact size. It's going to be hard to beat something like a 5 or 7 tube shotgun or similar. For an air-cooled system, it's going to be significantly larger than one water cooled, with the probable need of a fan as well.
For condensing steam, 500w per foot for 3/4" finned tubing with a big fan blowing on it.
viewtopic.php?t=56652
Here's a build by Mason jar
viewtopic.php?f=87&t=54596
