So, we have a 3rd year apprentice, that should know better, not do his task as instructed,
We had gotten all of this crowded system plus a little more ready to burn and told him
" go upstairs, stick the oxygen sensor tube over the purge holes you made in the caps and come down when all 8 pipes are showing below 0 on the sensor" nothing he has not done before
That would have left the pipe looking like this on the inside
I reckon he heard
"go upstairs put tape over the holes SO NO PURGE CAN FLOW"
Which leaves the inside of the pipe looking like this
it was a 10 hour days labor for 3 journeyman plumbers and 2 apprentices today cutting out all of this brazed, type k copper from every size, 3 inch down to ¾ inch and fitting it all back together with new pipe and fittings, ready to be brazed in the morning.
I don't think he's gonna stay on the med gas crew much longer. That was Friday afternoon, im in charge of the 2nd floor med gas crew and i let him stay and gave him a chance (we all fk up) but he can't listen and I can't risk carelessness on his part causing anymore problems for my crew or worse yet jeopardize the medical gas system of a new hospital. He may be more suited for the water or waste pipe crew
Oil free nitrogen purge results
- Corn Cracker
Re: Oil free nitrogen purge results
Sounds like a tough call to make Corny , but the right one . If he can’t get something like that right in third year , you don’t need him on a life critical installation team .
Shame you can’t pump citric acid i to the pipes and give them a rinse . I hope you offered to deal with all that waste copper
- Corn Cracker
Boss was so pissed I have not,,,,,yet. I think our general foreman (the big boss) is keeping up with the scrap copper pretty close, this is his last job before retirement and I know he's working on his last big haul, he will have collected enough for a new boat for sure once it's all done.Yummyrum wrote: ↑Mon Jul 27, 2026 10:43 pm Sounds like a tough call to make Corny , but the right one . If he can’t get something like that right in third year , you don’t need him on a life critical installation team .
Shame you can’t pump citric acid i to the pipes and give them a rinse . I hope you offered to deal with all that waste copper![]()
- Corn Cracker
Trisodiom phosphate is used to clean a dirty fitting from time to time that has to be used. Citric is probably not as harsh, never looked into it.
Damn , we had heaps of that going to waste at my old work . Wished I knew it had a good use .Corn Cracker wrote: ↑Tue Jul 28, 2026 12:34 am Trisodiom phosphate is used to clean a dirty fitting from time to time that has to be used. Citric is probably not as harsh, never looked into it.
Might have a look at work tomorrow and do some trials if we got some .
- BigSwede
Dang CC, that's a rough one. I was not aware of what went into this sort of work. Maybe I should purge with TIG argon gas before brazing up any more copper condensers! I'd love to see the insides looking more like the first picture.
- Corn Cracker
It's in most breakfast cereals here, it's a pretty harsh chemYummyrum wrote: ↑Tue Jul 28, 2026 2:32 amDamn , we had heaps of that going to waste at my old work . Wished I knew it had a good use .Corn Cracker wrote: ↑Tue Jul 28, 2026 12:34 am Trisodiom phosphate is used to clean a dirty fitting from time to time that has to be used. Citric is probably not as harsh, never looked into it.![]()
Welding might not be as bad, these fittings and pipe ends are glowing orange when we get it up to temp
