Dephlegmator build
BigSwede
Re: Dephlegmator build
Post by BigSwede »
Saltbush Bill wrote: ↑Fri Jul 17, 2026 2:03 am
googe wrote: ↑Thu Jul 16, 2026 11:37 pm Hobby distilling is the K.I.S.S principle (keep it simple stupid)
Thats going straight to "Notable and Quotable Goo."
Way to much over thinking goes on at times. Keep it simple , dont take short cuts = good booze.
I an the screaming opposite of KISS. Can't help it. It's how my brain is wired. :lol: But if it wasn't fun, I wouldn't do it!
AJB
Post by AJB »
30xs - that's a really useful data point - a 4" hitting full reflux on 4-4.5" of tube is well below what I would have guessed. Good steer on keeping height minimal.
Saltbush - the needle valve as the main skill to develop rather than the hardware makes sense. I'll go in expecting to spend more time learning the valve than building the kit.
googe - appreciate it, and the K.I.S.S steer is landing. Funny timing too, because the plates showed up today.
Progress photo attached: the 13 x 1/2" plate next to the two 3/4" plates, 7-hole and 4-hole. Seeing them side by side makes the "fewer, bigger, simpler" case pretty visually obvious on its own.
Given the flow feedback in this thread, I think the 13 x 1/2" plate is looking less necessary now too, might drop it from the test and just run the two 3/4" versions against each other at 200mm length. Now waiting on the 200mm tri-clamp shells to arrive and using the wait to get some brazing practice in before committing torch to the real thing. Will report back once assembled.
Sláinte
The 13 x 1/2" would be the best compromise for a product condenser.
I think the 4 x 3/4" would be about right for setting on top 3" bubble caps.
Copperhead road
Post by Copperhead road »
Many years ago i had a full copper custom 4" 5 plate Bubbler professionally built, the dephleg come with a gate valve to adjust water flow, i found it impossible to keep all the plates bubbling nice and stable. Saltbush Bill suggested to swap out the gate valve for a good quality needle valve.... i have never looked back, the column was a whole different animal and it kept all the plates bubbling away perfectly.
i wouldn't run a column still without one!!!
googe
Post by googe »
Agree with shady. Forget my kiss comment, I have done so much random build shit, like many others here. The only way we have learnt is to do what we wanted to do. You obviously love trying things and want to build your own. At the end its just copper and solder, easy to work with and easy to modify if you have a extra brain fart half way through the build.
"Homer J Simpson"
This the first defleg that I ever built, 4x 3/4 inch tubes.
The soldering isn't pretty but its still in use to this day and works perfectly imo.
I put an air bleed valve on this one because I was worried that maybe some air would get trapped in the defleg.
EDIT, how time flies, I just went looking for the old build thread for that still on another forum.
Its 15 years since I built that one and I got a couple of facts wrong. The 4 tubes are 1 inch not 3/4 and the overall length of the defleg is 4 inches.
Salt Must Flow
Post by Salt Must Flow »
AJB that 13 x 1/2" would make a really powerful shotgun condenser. I cut a bunch of plates to start a 3" shotgun build, but never completed it. I just need to get a bunch of 1/2" OD copper pipe. It's relatively hard for me to find locally these days. I was able to get 14 x 1/2" drilled out as end plates and baffles.
30xs
Post by 30xs »
Saltbush Bill wrote: ↑Fri Jul 31, 2026 3:20 am This the first defleg that I ever built, 4x 3/4 inch tubes.
I’ve always liked this dephleg. Shady’s coil is easier to build and worked as well as either the 7 tube 3/4 or 1” that I built. Saves some headroom over a shotgun style.
googe
Post by googe »
any progress mate?
"Homer J Simpson"
AJB
Post by AJB »
googe wrote: ↑Wed Aug 26, 2026 10:31 pm any progress mate?
Funny you ask! The 200mm Tri clamp spools have arrived, copper tubes have been cut and endplates have been prepped. I just need to find some time to put it all together!
Sláinte
