ph crash
amh71
ph crash
First ph crash. Not sure why, I've made the same shadys sugar wash at least a dozen times without problems.
To help buffer ph I always hang a mesh bag with 3 cups of crushed shell, by the time it gets down to about gravity 1.000 ph will be around 4 to 4.2 so I remove the shells then and let it finish without them, usually gets down to between 0.990 and 0.995 in 5 days.
Did the same this time but opened a new bag of shell, same vendor, looked as normal. My wife buys Doves Farm yeast for bread so I use that too, couldn't find any this time so got a bag of Fermipan Instant Red Dried Yeast from amazon. Made good bread and foamed up nicely when rehydrated.
Only those 2 variables, everything else as normal 25kg sugar made up to 130l, 2/3 cup of boiled yeast, 1 tablespoon yeast nutrient and another 2/3 cup of yeast to pitch.
Pitched yeast Sunday evening, Monday morning not much activity in airlock and ispindel saying gravity unchanged at 1.064, opened it up and a bit of activity but a big plume of bubbles coming up from the shell bag. Tested ph and down to 2.7.
Went shopping to see if I could find some pickling lime, didn't so ordered from amazon.
This morning a bit more active and ph was up to 3.2 so shells doing their job a bit, pickling lime arrived so added 2 teaspoons and ph increased a bit so added 4 more and got it up to 4.2.
A lot more active this evening and gravity down to 1.050 so seems to have recoved, have to see how well it finishes.
Odd one.
Odd one.
- Salt Must Flow
Re: ph crash
3 cups of oyster shell may be not enough for 130 l/32 gal. I've always suspended a lot and never had a ph issue. I can only think that using more would keep the ph from dropping like it did.
howie
Re: ph crash
what was your starting PH?
the other variable could be the water.
Re: ph crash
Another variable is temp, the faster yeast works the more Co2 made.
amh71
Re: ph crash
Didn't measure ph before pitching after mixing ingredients, will do next time, but our tap water ph is 7.2, also quite hard so should buffer on its own to some degree, total hardness is 220. Although this summer has been so hot and dry that many reservoirs are very low, perhaps the water company is switching the supply around.
Will add extra shell next time, I throw out pretty much the same volume as I add so always assumed I use too much but its cheap. Perhaps thats not true.
I normally fill with a mix of hot and cold water aiming to get close to 28C as I can, after pitching the yeast it slowly goes up to between 30 and 32 depending on the weather, I then wrap it up so it stays there with a small heating mat underneath which often never comes on. Looking back this batch did exceed that, it peaked at 33.5C and then dropped back to 30 overnight as it stalled. Not seriously hot but different to others.
I've been doing a batch every 3 weeks or so all year to build up stock as didn't get many chances last year, this is the first year using the 150l drum but done no end of 30l batches over last 10 years without any big issues so it surprised me.
Perhaps I've always been a bit marginal with amount of shell and a little bit more temperature dropped the ph faster than the shell could dissolve.
Its back to trying its best to blow the water out of the airlock and down to 1.035 so hopefully salvaged and at least I've got lime to fix any future ones now, unless the wife steals it for pickling...
We'll see how the next one goes.
Re: ph crash
Glad to hear the wash restarted.
I'm curious how the pH crash is going to affect the character of the sugar shine.
amh71
Re: ph crash
Me too, dumping 130l would be a pain.
I generally just blend all the strips together and spirit run as and when i get chance, think I'll keep this one on its own and see, smaller hearts cut at a guess.
Bit apprehensive about the all grain batches I've got planned after these now, they cost a lot more!
Re: ph crash
I'd mix the low-wines in with the rest but save a pint from the middle of the strip and set it aside for future comparisons.
Re: ph crash
I had my first Lactic infection in a Shadyshine a few weeks ago .
I could smell it when loading the boiler , I could smell it in the stripping run and sadly I could still smell it after a reflux run .
So if you experience that , don’t go adding it to your other stripped SSS .
Anyway pleased your wash restarted .
amh71
Re: ph crash
Me too.
A long time ago I had a butiryc infection in a suger wash, the smell was pretty epic, NZChris said don't tip it out it'll get better and end up like pineapple, no it didn't. I foolishly ran it and the whole house smelt of puke for days.
Having said that what happened to NZChris, his posts were usually an interesting read?
Re: ph crash
This was his last post. search.php?author_id=46146&sr=posts
Re: ph crash
Looks like there was several variables at play.amh71 wrote: ↑Wed Aug 19, 2026 2:13 am Didn't measure ph before pitching after mixing ingredients, will do next time, but our tap water ph is 7.2, also quite hard so should buffer on its own to some degree, total hardness is 220. Although this summer has been so hot and dry that many reservoirs are very low, perhaps the water company is switching the supply around.
A bigger fermenter, different yeast, maybe a coarser grind of grit, maybe a change in water, a slightly higher temp and faster Co2 production.
Each in itself wouldn't make a measurable difference, but all added together was enough to cause a crash.
Maybe in the future, use 2 or more bags of grit suspended 1" above the bottom and try to keep the fermenter temp as steady as possible.
- subbrew
Re: ph crash
amh71, not sure of your location, units of measure and Dove's suggests UK, but low reservoirs and dry suggests western US. Anyhow if is US I have found the larger ACE hardware stores always have pickling lime, so if you need it fast that is a place to look.
- Username
amh71
Re: ph crash
Yes, UK. We are having our second very hot (by our standards) very dry summer. The south gets most of their water from underground sources, tends to be soft and not very good for brewing, the north mostly has reservoirs, tends to be hard and better for brewing. Luckily we had a wet enough winter to refil everything in between. Next year may be interesting.
We're in the Midlands and many would argue have the best brewing water there is, the monks founded the town so they could make beer using it and i haven't had many failures over the years. Sadly many hundreds of years later most of the brewerys have gone and its just Molson Coors making fizzy piss.
Picking lime isn't really much of a thing over here, we salt pickles overnight and then rinse rather than using lime but I did find some on Amazon, otherwise a garden centre would have been the next visit.
Re: ph crash
Pickling Lime is Calcium Hydroxide . Also known as Brickies lime in Australia . It is used to make morter . Can buy 20kg bags from Hardware store for bugger all . Also rural stores sell it for braking up clay soil and also for helping to brake down dead animals when burying .
- Username
Re: ph crash
Also known as slaked lime or hydrated lime
amh71
Re: ph crash
If only I'd still got our allotment, there was most of a sack of it in the shed, always spread some before planting cabbage etc but we gave it up a few years ago. The pound I got from amazon will likely see me out.
It's still bubbling away, down to 1.010.
amh71
Re: ph crash
Well it's finally done at 0.991, it took 10 days to get there rather than the normal 5 but I'm happy it finished OK.
Hopefully get time go do the strip runs at the weekend.
