BlueBerryBrandy (Triple B)
Peaty Jones
Post by Peaty Jones »
I’m going to do a small batch of brandy. The goal would be to have 1,5L french oak barrel filled approx with 1,3L of cask strength in it. I’m a bit short with the recipe. I was thinking of using those old berries from my freezer. I quickly weighed that i have 11kg total of blueberries and cloudberries. I read that their sugar content isn’t that high also. I may have some apples also but i think the gravity content would stay low without extra sugar. The plan is that i unthaw the berries, whip them with paint mixer and add pectic enzyme. Ferment about 30-50l with EC-1118 which i then strip in my 50l kettle and do the spirit run on air still. This is my first brandy so would want to ask few advice and tip.
Should i ferment on the crushed berries or not?
If not then should i press the berries? I read that it could plausibly add astringency if the berry seeds get crushed but does it?
I think i definitely need to add sugar so what type of sugar would be the best?
Should i use campden?
What temperature would you suggest to EC-1118? Topside of the specified like 25C?
PalCabral
Re: BlueBerryBrandy (Triple B)
Post by PalCabral »
Hi Peaty! I am no expert on berry brandy (double B) and I am also interested to know if a fermentation of the berries would give anything, thinking your yield would be very very low.
Inverted sugar ferments more easy, theoretically it will give the yeast less of a struggle and thus a cleaner ferment. But Shady tipped in a thread from a year back that neutral alcohol would more clean and easy to use if all we want to do is to bump the alcohol level. To me this makes a lot of sense, if you have neutral lying around (naturally).
With my fruit, I always use pectinase and campden, I want to make sure there's no rogue fermentation taking off while I let the pectinase do its' thing. I use EC-1118 in the 18-20 room temp I have in my distillery at the moment. This is what there is to love about EC-1118. It ferments at any temp and at any temp swings. Great workhorse yeast.
Copperhead road
Post by Copperhead road »
PalCabral wrote: ↑Tue Sep 01, 2026 12:41 pm
+1 I religiously use pectinase and EC-1118 with all of my fruit Brandys. It just works... :thumbup:
TDick
Post by TDick »
PalCabral wrote: ↑Tue Sep 01, 2026 12:41 pm Hi Peaty! I am no expert on berry brandy (double B) and I am also interested to know if a fermentation of the berries would give anything, thinking your yield would be very very low.
I agree with most of what Pal said. I've have access to unlimited blueberries BUT I can't ferment them during the summer because of the heat.
Even EC-1118 which is SUPPOSED to have the highest temp tolerance is no match for Alabama Summers.
(It was between 105-110 F in The Shed last week)
Frozen berries (ruptures the cells) is preferred then you can use pectic enzymes or not.
I used EC-1118 last summer - a mistake. I still had to keep the wash temp down with frozen water bottles.
But mostly, EC-1118 is a tough bad ass fermenter designed for high ABV and fast ferments. It's perfect for a sugar wash because it STRIPS flavor.
I suggest wine yeasts Lalvin K1-1116 or 71-B. They ferment slowly but to minimize off tastes you want a slow fermentation any way.
Add INVERT sugar - less sugar bowl taste and less stress on the yeast.
After the EC-1118 kerfuffle, I used a blender to turn the berries into a pulp.
(I don't remember how many pounds, more is better)
I added water and enough invert sugar to bring the OG up to around 1.075. Low stress, more berry flavor.
Pitched 71-B and fermented "on the berry".
Sparged using a pillow case (NOT SWMBOs!) and kept the pomace.
Double distilled in my Air Still then added the pomace back for maceration.
I did not put it on wood but it's been "aging" in my refrigerator and the blueberry has come through.
Maybe the best thing I've made. But sadly that is a LOW bar. :D
PalCabral
Post by PalCabral »
Yeah, here I’ve never had to compete with heat in the distillery like in your case, TDick. Even in the summer the top temp in the distillery, my basement, is rarely above 22-23C/72F. And now as we’re marching into September, it has cooled to 20c/68f during the day, and the temp swing between day and night is starting to be noticable. It’s in this environment I find EC-1118 the safest bet.
As a result, I havent tried any other yeasts yet for my fruit fermentations yet and since the fruit projects are only once a year I am too chicken to test another yeast, under the old if it aint broke… principle. I believe you when you say other yeasts give better flavor profiles, but with that said, I have never found anything negative to remark on the flavors I get from the EC1118.
Your blueberry recipe looks great. I really hope I’ll find time to make it myself. Blueberries is something we have a lot of here. Thanks for sharing, TDick!
Peaty Jones
I have a kegerator so i have full control of the fermentation temperature so that should’t be a problem. I just ordered 20l of fresh blueberries more and even with that i still think its going to be quite low yield. I think i will try to ferment it on its own natural sugars for the science of it so i can record the fermentability. I will make another batch of inverted sugar wash on the side and at the end i mix them together. If the ABV is still low i will add some leftover feints!
Ill post the results and the actual recipe here when i’m done.
I googled a bit and i found out that blueberries here aren’t actually the same blueberries which you have there in states TDick! Actually the ones we have here should be called bilberries (european blueberries). I didn’t know that till this day. Live and learn.
PalCabral
Post by PalCabral »
Peaty Jones wrote: ↑Tue Sep 01, 2026 10:18 pm I have a kegerator so i have full control of the fermentation temperature so that should’t be a problem. I just ordered 20l of fresh blueberries more and even with that i still think its going to be quite low yield. I think i will try to ferment it on its own natural sugars for the science of it so i can record the fermentability. I will make another batch of inverted sugar wash on the side and at the end i mix them together. If the ABV is still low i will add some leftover feints!
:thumbup:
TDick
Post by TDick »
PalCabral wrote: ↑Tue Sep 01, 2026 9:50 pm Yeah, here I’ve never had to compete with heat in the distillery like in your case, TDick. Even in the summer the top temp in the distillery, my basement, is rarely above 22-23C/72F. And now as we’re marching into September, it has cooled to 20c/68f during the day, and the temp swing between day and night is starting to be noticable.
Doing a Jaggery rum stripping run with the Vevor today.
Put in a new fence, tree limbs kept falling and landing on it and The Shed.
Cut the trees, no more damage- good
eliminated the shade - not so good.
A little warm in here.
(Even running slow, it’s coming out cloudy)
PalCabral
Post by PalCabral »
TDick wrote: ↑Wed Sep 02, 2026 12:14 pm A little warm in here.
Holy cow! :shock:
Peaty Jones
Wow. Here we have about 5C(41F) at night and 15C(59C) during the day right now and its slowly getting colder. Speaking of it i just stored 1,5-2 cords of firewood for the winter. At the coldest time in january/february it could even drop down to -40C/-40F at its worst and the energy prices are through the roof.
TDick
Post by TDick »
Basically the same. Keep your ass in the HOUSE!
SWMBO asks me what I'm doing today.
"Not a damned thing!"
Peaty Jones
TDick wrote: ↑Wed Sep 02, 2026 8:04 pm
I mean negative 40F. Thats when you absolutely want to stay inside :D
Swings of + 40°C and -40°C does my head in .
Man , we bitch and moan when its 6°C to 35°C … mind you , the Humidity does get up in the 80’s -90% for a few months …. Thats what fucks us . :|
Anyway , good luck with the Blue Berry Brandy :thumbup:… going ti water our little bush tomorrow .
Peaty Jones
Yummyrum wrote: ↑Thu Sep 03, 2026 3:30 am Swings of + 40°C and -40°C does my head in .
Thanks Yummy!
It is quite rare but happens. This picture is from january 2024. About -25C is quite common. At summer +20-25C is common but sometimes it gets to over 30C but the humidity does stay quite low so it isn’t that bad.
I think these are just things which we have born into and grow up with. Its the ”Kaamos” which is the worst and depressing part in winter. Sun stays up only few hours so its dark as night for months. No wonder our ancestors celebrated spring because it honestly feels like you had crawled out of a cave :problem:
Peaty Jones
Heres a picture what the wild blueberries here look like. Got about 15l after cleaning them of leafs and pine needles. Theres some lingonberries mixed but i think its about 2-3% of them so i dont bother to separate them.
I’m not sure but i think the ones you guys have in the states are much bigger and they grow in those tall bushes. Ours are like 5-10mm in diameter and they grow in these 25cm bushes in the forest ground everywere.
PalCabral
Post by PalCabral »
You are right about the differences between Nordic blueberries and American blueberries, Peaty. The American blueberries are a lot bigger and taste a bit different. Nordic blueberries have more acidity I think, that's why we sweeten them with sugar. Dont think you need to do that with the American ones.
Lingonberries, Tyttebær in Norwegian, is uncommon outside the Nordics I believe. I wonder if Lingon would not make a nice eau de vie actually? At some point I will make a Gin which is flavored by Lingonberries and Rowanberries, besides the juniper, bitter orange peels and coriander. #todolist
Peaty Jones
That is a brilliant idea Pal!
I have always thought that those ”tangy” berries such as lingonberries (Puolukka) and rowanberries have no place in distilling but never even had given a thought of using them in Gin!! This opened a whole trail to me.
I have thought of trying aronia chokeberries for wine or brandy since they have this mild sweet taste which for me mildly resembles the taste what you have in grapes.
PalCabral wrote: ↑Thu Sep 03, 2026 10:59 am You are right about the differences between Nordic blueberries and American blueberries, Peaty. The American blueberries are a lot bigger and taste a bit different. Nordic blueberries have more acidity I think, that's why we sweeten them with sugar. Dont think you need to do that with the American ones.
Peaty Jones
Update!
I just dumped the frozen berries to a fermenter. Those 11kg of berries were from a relative of mine and i thought they were mostly blueberries but once i opened the bag it was about 80% cloudberries and 10% frozen lingon berry juice and jam, and 10% lingonberries. Quess beggars cant be choosers. Theres not that much berries anyways for a proper batch so i decided to use them all even though i didn’t like the idea of lingonberries on it.. i also added those 15l of blueberries which i got recently and froze them. So i kind of messed up the ”in the name of science” about the blueberries now…
The recipe is now a blop of mixed units because i also forgot to weight the blueberries but it is something like this:
15l of blueberries
9kg of cloudberries
1kg lingonberry juice
1kg of lingonberry jam
I have no clue what the outcome will be in case of liquid volume, gravity yield etc. Just have to see what i get out of it :)
PalCabral
Post by PalCabral »
Subscribing to this thread now! :)
Copperhead road
Awesome job Peaty Jones,
I will be following your journey with great interest, as i love making fruit brandy's from scratch. I have not heard of some of them berries so i might have to do a bit of research. Maybe we don't have them in Australia... :?:
Do you know what the brix is on Lingon and cloud berries.?
Hopefully they have a good sugar content.
Top job mate. :thumbup:
Peaty Jones
Thanks Copperhead!
Cloudberries for what i know grow in northern hemisphere but i’m not totally sure. Lingon berries are spread a bit more but not sure if to Australia also?
I’m not sure of their brix content is but i looked their nutritional content. I just dont remember them right now. Ill get back to this with another post soon!
Copperhead road wrote: ↑Sun Sep 06, 2026 1:05 pm Awesome job Peaty Jones,
Copperhead road
Peaty Jones wrote: ↑Sun Sep 06, 2026 7:03 pm Thanks Copperhead!
I have done a bit of research and lingon berries do grow in Australia but they are rare. Cloud berries do not grow here though.
I am going to put down a blueberry ferment once i can source them at a reasonable price, i think Blueberry brandy would be nice. I intend to age it in glass using heavy toasted Hungarian Oak mini staves.
Peaty Jones
For clarity, here’s some information I gathered about the berries I used. The pictures are not mine; I found them through a Google search.
Bilberry (European blueberry)
Growing conditions
Bilberries grow wild here in forests and heathland. The berries are approximately 5–12 mm in diameter, so they are considerably smaller than traditional blueberries. They grow on low-growing shrubs, typically only about 10–50 cm tall, close to the forest floor.
Taste
They are slightly more acidic than regular blueberries, but still quite sweet. Perhaps the best indication of how sweet they can be is that when my daughter was two years old, she used to spend hours eating them straight from the forest and didn’t mind the mosquitoes at all. They are used quite much like regular blueberries (Jam, juice, bakeing, etc. I prefer to just use them on their own with oatmeal).
Sugar content according to Wikipedia:
According to Wikipedia it has 10,2g of carbohydrates to which of it 8,4g is sugar (per 100g). I even found a table that those 8,4g of sugars are fructose (4,6g), glucose (3,7g), maltose (< 0,1g) and saccharose (<0,1g). If that's true, then it should be somewhat fermentable.
Lingonberries
Growing conditions
Lingonberries grow wild here in forests and heathland. The berries are approximately 5–10 mm in diameter. They grow on low-growing evergreen shrubs, typically around 10–30 cm tall, close to the forest floor.
Taste
They have a distinctly tart and slightly bitter taste, with a pleasant sweetness underneath. They are considerably more acidic and less sweet than bilberries. This is why i wouldn't have wanted to use them but what the hell.. Its quite small portion of the mix. They have a place in different kinds of recipes, such as juice, jam (this is commonly served with reindeer meat and it serves it well), pies etc. Eaten them on their own is not my thing. @PalCabral had a good idea that these could be used in gin basket as a replacer of juniper. To me that sound worth a try and should be tested definitely.
According to Wikipedia it has 8,9g of carbohydrates to which of it 8,2g is sugar (per 100g). I even found a table that those 8,2g of sugars are fructose (4,2g), glucose (3,8g), maltose (< 0,1g) and saccharose (0,2g). If that's true, then it should be quite fermentable.
Cloudberries
Growing conditions
Cloudberries grow wild here in bogs and swamps. The berries are approximately 10–25 mm in diameter when fully ripe. They grow on low, creeping plants, typically around 10–30 cm tall, close to the ground.
Taste
Cloudberry taste is a bit hard to explain since the taste is quite unique. Its this very pleasently round sweet, rich in taste and a bit fruity. The sweet taste of it isn't as "Sugary" as strawberry, but its this bit of honey kind. Its very very hard to explain it. The texture of it is this kind of half liquid half jam like when eaten as its own. Its used for baking, juices, jam (often served with this Finnish delicasy named Bread Cheese which is another story), some have made wine from it (usually with added sugar) and theres also cloudberry liqour but to my knowledge that is made by soaking the berries in booze, not fermenting them.
According to Wikipedia it has 6,8g of carbohydrates to which of it 5,8g is sugar (per 100g). I have no idea how much of it is fermentable sugars. But my quess that the yield will be low.
As summary i would say i think i need to use that inverted sugar and feints on this batch but i think i give it a try ferment it on its own first to see what it does. I'm interested to see the OG and FG of it and if the alcohol yield stays low i add a Small portion of inverted sugar to it. I just wouldn't want to use it much so maybe some feints from AG whisky also.
Bilberries, cloudberries and lingonberries, My brandy wine is really made from all these things. After writing all this, my head felt twice the size, and i couldn't find my silver spurs...
Peaty Jones
I was thinking of separating the pomace before pitching yeast and maybe boil them in water to extract all the leftover sugar in them and then throw the pomace out. To that water i could add that inverted sugar. I remember reading that the bilberry seeds could add astringency especially if you crush and ferment on them. Not sure that does astringency transfer on the distillate though.
TDick wrote: ↑Tue Sep 01, 2026 6:51 pm
Peaty Jones
Update:
After 24h in the garage i opened the bucket to give them a whip but the berries were still frozen. Only the topmost of them were thawn. Note to myself: if the buckets side condensates water, it isn’t thawn enough. Its getting colder here and it was +10 C in the day and +1 C at night so i thought it will take ages for it to thaw fully. I carried the bucket inside to the sauna (its off ofcourse) and let it sit there for another 24h.
Just opened it and gave it a good whip with my power drill. The resulting pomace liquid slurry was 23l in volume. Added 3g of campden powder and dissolved 15g of pectinace to 1,5dl of water and threw it in also. The manual said to use 0,2-0,4g/l for skin maceration of red grapes so 9,2g would have been enough but it also said that if the temperature is low you can compensate it. It was barely thawn. I think i let it sit for 48h because it takes time for that quantity to get warm and thus bit longer time for the pectinace to have effect.
Ihave no idea how much the volume will be after separating the pomace. I hope its something like 17l. At the process i made a bit of a mess with the power drill and paint mixer. The shower was like in The Bates Motel. Had to clean it carefully before Madam Peaty comes back home and thinks i’m some kind of Norman Bates.
PalCabral
Post by PalCabral »
Are you running with elements or gas, Peaty? Apple chunks and plums meat is okey to separate but berry slurry?
Peaty Jones
I have a 3kW element in the bigger 50l still and an airstill. I hope the pectinace makes it more liquid like. I’m also going to separate it with a cheesecloth or a BIAB bag before fermenting. If it stays too thick then i need to add that inverted sugar with water
PalCabral wrote: ↑Tue Sep 08, 2026 10:46 am Are you running with elements or gas, Peaty? Apple chunks and plums meat is okey to separate but berry slurry?
Peaty Jones
Update:
After 48h in the pectin enzyme i opened the lid. It looked like this thick slur.
I inserted a BIAB bag on a fermenter as a secondary filter. As a primary screen i used this stainless juicer basket which hanged on top of the fermenter from the handles. I filled the basket with the slur but only a few drops got through it. The pomace stuck the holes quite quickly. I put plastic gloves on and scooped it a bit and it started dripping. I swept the holes open from time to time and i got the separation done quite quickly. After that i had about 14l of Juice. I dumped the pomace to the BIAB bag and squeezed it thoroughly in the basket for quite a long time. I saw that lots of Juice was inside the biab but it came out so slowly. In the end there was 17,5 l. I took the pomace and but it in a kettle, added water and boiled it for 5 minutes. In hindsight that was just extra trouble. I got about liter of Juice out of it and the gravity of the boiled part was just barely 1.015. Picture is taken after separating.
I dumped the boiled Juice in the fermenter and dropped the hydrometer in it. The reading showed about 1.041 - 1.042.
The total volume was 18,5 l. I threw 3 bags of EC-1118 in (i forgot to hydrate but im not worried) and a Rapt pill to monitor the temperature and gravity. I decided to keep it inside the house because the temperature (20 C) should be quite spot on for it.
Rapt pill gravity calibration is bit off (it says 1.037) but i dont mind it. I prefer to check the change of the gravity rather than the values. I know the correct reading which i got with the hydrometer. When Theres no change in 24h i know the fermentation has stopped.
A bit offtopic:
Rapt pill is very helpful when fermenting beer because it can be connected to the thermostat. It also reads the temperature from the mash instead of my fridge. I have made a program (profile) to it so when i do lager, it keeps it at 10C and when it reaches 75% of the fermentation, it starts diacetyl rest (bumps temperature to 18C). And after two weeks, it starts slowly ramping the temperature to lagering temperatures 1C per day. After i have it about 3-4C i transfer the beer to a purged keg and set it on my lagering freezer which i have set to 1C and let it sit there for months.
Copperhead road
Excellent work Peaty, a picture is better than 1000 words. :ebiggrin:
Peaty Jones
Thanks Copper! I think so too. (I mean the picture part)
I usually would do this kind of ”report” work with a PC. Its a bit time consuming and error prone work with a phone. :)
Copperhead road wrote: ↑Thu Sep 10, 2026 9:56 am Excellent work Peaty, a picture is better than 1000 words. :ebiggrin:
