Poison Ivy Cure
423moonshiner
Poison Ivy Cure
Post by 423moonshiner »
Hey everybody some of ya’ll might have done this before or maybe not but I just recently stumbled upon doing this out of desperation. Anyway I’m real allergic to poison of all kinds if I get it it spreads like hell and I’m stuck with it for a while. Anyway I save my foreshots in half or gallon jugs for fire starter in the winter because I burn wood and I was sick and tired of itching so I scratched it open and dipped a rag in the high shots I’ve saved and rubbed it on it and it took care of it better than anything else I’ve ever tried bleach included. So if you save some it makes a fine poison ivy medicine.
Corn Cracker
Re: Poison Ivy Cure
Post by Corn Cracker »
A cure is a cure, i bet it burned like hell though
Re: Poison Ivy Cure
I can attest to the fact the very first foreshots is good for clearing up poison ivy. :thumbup:
Every time you get the urge to scratch, instead use foreshots and a cotton ball to dab on the itch.
However, don't slather forshots on your balls to cure chiggers.
It's "almost" impossible to run in circles while simultaneously trying to blow air in that direction.
Just don't try it, especially if your wife is a witness, some things are never forgotten.
Username
Re: Poison Ivy Cure
Post by Username »
Haha Shady that reminds me of that famous amazon review "not for knob and bollocks"
Powder Monkey
Re: Poison Ivy Cure
Post by Powder Monkey »
I assume I’m a top percentile for poison ivy allergy. I’ve used high proof isopropyl in the same manner. I always try to dry the spots out asap. As soon as they stop weeping it stops spreading. Along those lines my standard cure was alcohol rub then mix hydrocortisone with the benzol peroxide based acne cream. This stuff is harder to find but it’s thick white paste but it really dries it out. For itching relief I just take as hot a shower as I can stand. Good luck and offering my sympathy. Poison ivy is the worst.
bilgriss
Re: Poison Ivy Cure
Post by bilgriss »
Poison Ivy is my nemesis. I once got a case from head to toe - everywhere in between and back again. I was just covered from clearing off a sloped area behind the shop where I worked at that time. I was oozing so much from my own skin my clothing was being glued to my body by my own fluids.
Since then, just gazing upon any related plan seems to trigger a systemic reaction which basically keeps spreading until I do a run of steroids. As such, I have spent some significant time finding out what works and what doesn't. The key is always cleaning off the plant oils before it starts. Poison ivy oils just stick to you, and they spread by contact, so you tend to spread your own rash by scratching or even rubbing with clothing.
Soap does an okay job if used well. Real soap. Not bath bars or body washes, which are all made from petroleum derived detergents and designed to be gentle to your skin. They don't remove oils at all for the sake of skin moisturizing. Scrubbing with a lye based soap for instance will do a fair job of removing poison ivy oils, if you do it thoroughly and soon right after exposure. Dawn Dish soap breaks down oils well also, if you want to keep with the detergent side. There's a commercial product called Tecnu that works fairly well, and is one of the few over-the-counter cleaners that do a good job and helps soothe your skin.
High proof alcohol works about the best to strip oils. I do the same as above and keep a jar of foreshots/heads as a solvent, and liberally use it if I see a poison ivy patch starting. It both strips the oils and dries out the skin in that spot, which seems to help with the itch somewhat as well as minimize the spread. I've had fairly good luck with the 90%+ ethanol or isopropyl you can purchase from a drug store, but they don't smell as interesting...
Deplorable
Re: Poison Ivy Cure
Post by Deplorable »
shadylane wrote: ↑Sat Sep 26, 2026 8:03 pm I can attest to the fact the very first foreshots is good for clearing up poison ivy. :thumbup:
Fore shots on Chiggers, eh?
I've never thought of that, but next summer if I get into chiggers again, I might just give it a go to try reducing the itch.
I can't say that I've ever gotten into the chiggers so bad as to have them on my ball sack. Usually just up the calves, and around the ankles.
Then again, if Im worried about chiggers, I generally avoid lying down in the grass, especially naked. :wtf:
NorthWoodsAb
Re: Poison Ivy Cure
Post by NorthWoodsAb »
shadylane wrote: ↑Sat Sep 26, 2026 8:03 pm Just don't try it, especially if your wife is a witness, some things are never forgotten.
Isn't that the truth. NEVER EVER let wife witness ANYTHING remotely embarrassing or personal.
They relish watching THEIR guy squirm as they relay said experience to anyone that will listen.
Conversely it is absolute suicide for a guy to take the same liberty when wifey is involved.
Uisge beatha
