Lingonberry Brandy
Peaty Jones
Lingonberry Brandy
This is kind of a ”sequal” for Trible B (BlueBerryBrandy) viewtopic.php?t=96252. After having a taste of it as white i thought that since the bilberry taste and flavor doesn’t come through that much, why not test something with a more tense flavor. Why not try Lingonberries!?
Lingonberries have a distinctly tart and slightly bitter taste, with a pleasant sweetness underneath. They are considerably more acidic and less sweet than bilberries.
Lingonberries have 8,9g of carbohydrates to which of it 8,2g is sugar (per 100g). I even found a table that those 8,2g of sugars are fructose (4,2g), glucose (3,8g), maltose (< 0,1g) and saccharose (0,2g). This makes it very well fermentable on its own but the downside is that they are full of this natural preservative called benzoic acid so that makes it hard for the yeast.
I had problems in fermenting the Triple B and this was one part of the problem in it. Triple B had lingonberries in it also. I found this recipe for lingonberry wine which i will use as an approach. It stated that because of the benzoic acid it should be approached much more cautious way and it suggested to use
something else to start the fermentation and then add lingonberry juice to it in smaller portions. The recipe suggested using ”Raisin Bomb” as a starter, which is basically boiled raisins which are gently crushed, cooled and introduced with the yeast. I think i’m going to dump the lingonberry Juice in three batches in 24h intervals. As yeast i am currently thinking either K1-V1116 or 71B. Convince me which?
I am not sure but i also believe that lingonberries are highly acidic so i must consider adjusting the pH also. But well see.
My goal is to get another 1,5l barrel filled with it so i have to bump the sugar content. I’m currently thinking of using either inverted sugar or raisins. Which would you guys propose and why? I would also want to test the fermentation with its natural sugars only so i think i add the sugar or raisins after it has done fermenting with the Juice only.
The berries i use are picked yesterday and today so they are still fresh but i am going to freeze, thaw, add pectic enzyme and whip it with power drill and paint mixer, let it sit for 24-48h and then separate the juice from the pomace and use the Juice only.
Many of you guys have propably never even seen or heard of lingonberries but any tips or things to consider?
- PalCabral
Re: Lingonberry Brandy
Great write-up, Peaty. I am really looking forward to the hear how it goes. Let's hope for a smoother ride than your triple B.
I've heard good things about both K1-V1116 or 7B. As far as I know, the K1-V1116 is a little bit more temp and PH tolerant but it's touch and go.
As for the choice between raisins and inverted sugar, I'd go raisins. Inverted sugar has citric acid and for me I've had so many sugar washes semi-stall or struggle because of the PH drop. Maybe it's the water here but since you had PH problem the last time, maybe you should try to avoid any pit falls.
Interesting about Benzoic acid. Never heard of it. I wonder if it is present in cloudberry and other "arctic" berries too?
- Copperhead road
- subbrew
I do not have experience with either yeast mentioned but D-47 is a workhorse. I have used it to restart fermentations of tart apple wine that stalled due to PH crash. I always keep a few packs of D-47 in my fridge as a backup if I have fermentation troubles.
Peaty Jones
According to this source yes, cloudberries contain benzoic acid about 50mg/100g.
https://www.sciencedirect.com/science/a ... 4678900468
Where as lingonberries can contain about 1gram/kilogram, so its double the amount that cloudberries have
https://research.abo.fi/en/publications ... y-using-a/
I read that benzoic acid has this protonated and deprotonated state. In Protonated state it can bypass the yeast cell membrane easier than the deprotonated. The amount of protonated correlates with the lower pH so bumping the pH up a bit helps.
Theres also the fact that yeast cells catch protonated benzoic acid so that they drop the acid content but that means the cell dies in the process. So basically cultivating a huge yeast colony can help get the fermentation but it will be a yeast massacre
. But i promise their fight will be remembered and it wont be for nothing
I would not want to bump the pH much because that can result loss in flavor and good esthers. But i believe some sort of compromise must be done.
PalCabral wrote: ↑Wed Sep 30, 2026 10:34 am Great write-up, Peaty. I am really looking forward to the hear how it goes. Let's hope for a smoother ride than your triple B.
- Corn Cracker
Have you thought about propagating the yeast on the lingonberries? From what ive read and heard, fruits have yeast on them that can tolerate its specific make up, might be something to look into. Good luck either way
Peaty Jones
Yes, i have read and thought about it, and have been super eager to try it at some point but in this one i think i stick to the plan using commercial yeast. I think this project will be another fight and i fear that there just would be too many variables to handle using wild yeast.
The thing is these berries are super tolerant. They are the last berries which survive before snow and subzero temperatures. I dont know what kind of conditions would trigger the wild yeast for the fermentation since the time window is so small. I would imagine that just as they are starting to ”go bad” the snow hits it and kills/freezes them.
By this i mean that harvesting and get it to work could be awful lot of work and fiddling. Atleast i fear it would. Because i have no experience in it so i think this wouldn’t be the best place to start with. But at some point with something else i will try it! Perhaps with the blueberries next season?
Corn Cracker wrote: ↑Thu Oct 01, 2026 5:17 pm Have you thought about propagating the yeast on the lingonberries? From what ive read and heard, fruits have yeast on them that can tolerate its specific make up, might be something to look into. Good luck either way
Peaty Jones
Update:
Thawed the berries 60h ago, whipped them while icy. Carried them to room temperature and added pectinace enzyme. Theres about 30l of juice with the pomace mixed in to it. I think i will get something like 20-23l of Juice from it but well see.
Today i grinded 500g of raisins and boiled them in 3L of water. I raised the water level to 5l and let it cool. I also added a pinch of Fermaid K yeast nutrient to it. The nutritional values (per 100 g) said that the raisins have 82 g carbohydrates which of 76 g are sugars.
I decided that as a yeast i go for 71B. I’m hoping it wont strip the juice out of flavors. I rehydrated the 71B and introduced it to the raisin bomb starter which was 27-30 C.
I think i will introduce the lingonberry Juice to it in 12h intervals so that the fermentation is still vigorous and vital. I start in small volumes and i make my way up everytime. Something like 1l, 2l, 4l, 8l and then the rest. This is so that the yeast can slowly increase its population high and that it would stand against the increasing benzoic acid. I keep record of the pH after every addition. I think it wont be a problem at first when the additions are small but when the amount of Juice gets high it will drop wastly. I want the pH to stay as low as possible so it wont effect the esthers but high enough not to boost the benzoic acid.
I still have the Juice and the pomace mixed and i think i separate them tomorrow.
- PalCabral
Sounds like a good plan, Peaty. Crossing my fingers.
Peaty Jones
Update:
After 9h the fermentation was
going quite well on the raisin bomb so i decided to add the first liter of the lingonberry juice.
I measured the pH of the raisin bomb and it was about 4.0.
The Juice was acidic like i thought. It was 2.9.
After mixing the pH was 3.5
The fermentation went to full halt
Immediately. I stirred it well and left it alone for now and decided to separate the rest of the pomace from the Juice. I have to say these berries are tough. Even though i froze and thawed them, mixed them with a drill and paint mixer and bathed them in pectinace enzyme for 72h, about. 30% of the berries were still as intact as they where after picking. Separating the pomace was a tough job. I had to physically crush them by my hand in the pillow case and after that squeeze them. Squeezing only did nothing.. i spent 2 hours crushing and squeezing them and at the end my hands were numb. Blueberries were childs play compared to these.
At the end i got 20l of juice from those 40l of fresh berries.
I checked the gravity and was surprised. I thought it would be bit less than blueberries but on the contrary it was bit higher (1.050).
I went and checked the fermentation and it
seemed that the fermentation was stopped fully. I took a spatula and move the surface a bit and i saw it! SMALL BUBBLES! IT HAD REVOKED!
I let it be and after 10h after dumping the first liter the fermentation was much more vigorous. Not a blast but definitely more lively.
I dumped 2l more of the Juice and same effect. Fermentation halted. The pH dropped to 3.3. Its 4h from that and i start to see little bubbles gathering. It will revive for sure. I have to check it tomorrow and decide if i go to the full 4l next or will i be a bit more merciful to it next. Oh and almost forgot. I have added a pinch of Fermaid K at every addition of the Juice.
- PalCabral
Some work! Good you are persistent, Peaty.
Peaty Jones
Update:
Next morning the fermentation was going a bit slow but still going. I decided to go soft on the yeast because of that and add just 2l more so the benzoic acid levels and pH together wouldn’t be too much. After that it was dead silent for the next 8h… i measured the pH and it was 3.16.
I think the low pH level made the benzoic acid mostly in protonated state and killed the yeast or its just too low pH level for the yeast.
To test this i decided to bump the pH back to 3.5 so that if its only the pH effecting the yeast, then it should restart again because the yeast had worked before even in lower levels of pH (even at 3.2). I waited for 8h and nothing happened. It was dead silent. So i think it could be concluded that the yeast was dead. I rehydrated another batch of yeast and dumped it in and quite soon i saw very weak fermentation happening. So this tells me again the yeast can actually work at this pH level.
I was worried because the fermentation was weak. Next batch of Juice could kill the weak population. I decided to do few actions.
1. Strengthen the New yeast population.
I couldn’t just dump lingonberry Juice because the benzoic acid could kill it so i boiled another 500g of raisins in 2l of water, cooled it and dumped it in.
2. Lower the pH of the juice and the fermenting batch. This is so that the following juice batches added wouldn’t drop the pH and protonate the benzoic acid. I tuned the pH of the Juice to 4 and the fermenting bucket to 3.75. as i bumped the fermenting bucket i could see quite quickly that the fermenation came much vigorous. From this point on the fermentation pH should stay somewhere between those pH levels and hopefully its high enough to keep the protonated benzoic acid levels low so that the yeast can survive.
Tomorrow i have to decide the volume of the fourth addition. I have to consider it based on how vigorous the fermentation gets now. If its weak ill add smaller addition. If its strong
I think i can add a bit more and hopefully the yeast population gets net positive (population growth because of the added sugar content is more than the benzoic acid kills them)
Side note: i dont know what magical level there is somewhere in the pH range of 3.6-4.0. At first the calcium carbonate didn’t react in any way. I know the pH scale is logarithmic so thats why The pH just stood like a rock. I added it in small bumps and finally it started to rise but then something happened in that 3.6-4.0 range. Suddenly it started to foam quite much. It created this 1cm thick layer of foam on the surface and it rised all the trub with it. After that even though the foam vanished, the trub stood in the surface even though earlier it always sunk to the bottom. That was quite strange and interesting at the same time. No idea what happened.
Peaty Jones
Update:
Next morning the fermentation was happening, not a blast but somewhat vigorously so i decided to add 4l of the Juice. This time the fermentation didn’t stop so i waited for a few hours to see what will happen but the fermentation kept going so i added another 4l of it and it still kept going. I had only 7l of the Juice so i decided to dump the rest of it in. The fermentation still kept going but after few hours i saw that it had slowed down. It still kept going but it was very subtle.
The Rapt pill was in there allready so i decided to let it sit for the night and check the gravity decline speed. Next morning i saw that the fermentation had slowed down so much that it would take two months for it to get to around 1.000… it was still fermenting but very very slowly.
I was going to add the rest of the raisins (2kg) to the fermentation later to bump the sugar content but i thought its best to ferment them now separately so i can get a new healthy yeast population with it. If the fermentation wouldn’t catch up i could possibly start dumping it to this New raisin fermentation the same way i did in the start. I grinded them in the blender, boiled it and cooled down and pitched the last pouch of 71B to it. The pH of the raisin Juice was 4.0 but it still kicked off like crazy. This tells a lot. Same temperature, same pH but still the lingonberry Juice isn’t fermenting even the fraction of the speed it does with the raisins. At this point there is not a single doubt of the effect of benzoic acid.
I decided to bump the pH of the Lingonberry Juice one more time to the level of 5 and see what it
does.
After night it hadn’t speed up but i noticed that the lingonberry Juice had the same kind of effect which happened with Triple B (BlueBerryBrandy). The Juice had turned blue. I wrote about this effect in the Triple B thread if someone is interested.
The fermentation temperature was about 20C and the raisin Juice was rockin like crazy so it shouldn’t be about the temperature also but i still decided to try to heat the LingonBerry Juice that maybe it could ease the yeast somehow. I added the heating pad into it and few hours later i checked the Rapt app and saw that something had tilted the pill somehow. I went and opened the Lingonberry Juice bucket and Voila! The yeast trub had risen to the surface and the fermentation was much, much, much more vigorous. I mapped it from the Rapt data that at this rate it should take 5-7 days to fully ferment to 1.000. Ofcourse it slows down to the end and i can’t say for sure that if it even gets to 1.000 but its easier to work with assumptions.
The trub has settled back to the bottom for the most of it now but the fermentation is now in a good run. Hope it stays that way.
does.
Peaty Jones
Todays lunch was a dish that fit the theme!
”Kaalilaatikkoa puolukkahillolla” which is Finnish Cabbage casserole with lingonberry jam.
It doesn’t sound and look great but its actually very delicious!
https://en.wikipedia.org/wiki/Kaalilaatikko
Peaty Jones
Update:
The fermentation is kicking great. It was at 1.034 just now that i checked it. From Rapt app i can see that it has even speed up a little bit. I assume the fermentation will be done somewhere around next weekend.
- PalCabral
Kaalilaatikkoa puolukkahillolla!!!Peaty Jones wrote: ↑Sat Oct 10, 2026 9:10 am Todays lunch was a dish that fit the theme!
Next time in Finland I will master pronouncing it and order it in a restaurant. There is a risk the restaurant will have closed for the evening before I am finished saying it.
Peaty Jones
I also suggest you try ”Poronkäristystä, perunamuusia ja puolukkahilloa”
and ”Rönttösiä ja ruisräiskäleitä puolukkahillolla.”
If youre at the west coast du kan också tala svenska! Just ask for kållåda med lingonsylt
Du behöver bara förstå muminsvenska.
PalCabral wrote: ↑Sun Oct 11, 2026 10:31 amKaalilaatikkoa puolukkahillolla!!!Peaty Jones wrote: ↑Sat Oct 10, 2026 9:10 am Todays lunch was a dish that fit the theme!
Next time in Finland I will master pronouncing it and order it in a restaurant. There is a risk the restaurant will have closed for the evening before I am finished saying it.![]()
Peaty Jones
Update:
We are currently at 1.020 and the speed of it seems stable. You can see the Juice additions at the start of the graph and if i remember correctly it was 8th or 9th of october when i got the pH to 5 and added the last addition and then bumped the temperature a bit and it started rockin. At the very beginning i didn’t have enough high level of Juice to use the Rapt pill in there so theres no data of that. The OG in the app is messed up in the picture because it got screwed by those additions which bumped the gravity reading. It also calculates the ABV with that and current SG so the ABV is wrong in the picture. I could manually update the OG myself in the app but i forgot when i took this screenshot.
The Rapt had an update and instead there is now a new app which i am currently trying to learn. It seems quite good at first but there are some things to which i havent found solution yet. It may be that i just don’t know how to use it properly. But its very easy and intuitive to use when using it in basic monitoring.
honnsmannen
very interesting! i have always wanted to make lingon wine, but never gotten my thumb out to actually go and pick enough berries to make a solid batch. i hope the final produkt will taste good, its hard to think what lingon tastes like without the tart taste.
Peaty Jones
Thanks Honnsmannen!
We will see what the outcome will be. ATM its at 1.004 and still going. I think the pH adjustment makes it a bet softer in taste. The ”tartness” seems to drop down a bit when the pH is raised. I think its the sapponification which does it. I hope it wont make too much effect on the end product!
honnsmannen wrote: ↑Fri Oct 16, 2026 12:15 am very interesting! i have always wanted to make lingon wine, but never gotten my thumb out to actually go and pick enough berries to make a solid batch. i hope the final produkt will taste good, its hard to think what lingon tastes like without the tart taste.
Peaty Jones
Update:
The fermentation stopped at sunday and i decided to let it sit to check if the gravity changes. Next day it hadn’t changed so i believe its done. The final gravity was 1.006. So lingonberry seems to be very fermentable!
Yesterday i bringed it to the garage to clarify. Temperature is low (varies from -5 to +5C) so today i racked it to another bucket. Now its just waiting there for me to have time to strip it. I’m quite busy for next few weeks so we have to see if i need to place it in the kegerator so it wont freeze.
- PalCabral
The color is awesome. So the fermented lingonberry juice landed on approx 4% ABV?
Peaty Jones
I agree about the color! I always like to take a picture of it at the first few
liters on a white bucket so it can be seen clearly. At bigger volume it starts to turn much darker.
The OG of the lingonberry Juice was 1.050 before any raisin additions so it should be about 6% ABV if i calculated right. It was 20l of it and thats why i decided to make that raisin addition to it so it bumps the total ethanol content. In total i added 3kg of raisins and about 10l water.
Its hard to keep up with the math because of those additions but if the 20l of Juice fermented to about 6% ABV and i added those 3kg of raisins which seem to be also fermented almost fully according the FG. Raisins have about 71% sugar in weight so that should correspond 2,13kg of sugar and that should correspond about half of its weight in alcohol which is about a
liter.
So in total it should be around 20L x 0,06 + 1L = 2,2 l of pure alcohol in that 30l of wine.
But if you are looking the ABV content of the lingonberry Juice alone then that will be a around 6% (OG: 1.050, FG: 1.006).
Honnsmannen! I’m sorry to disappoint you but the tartness is pretty clear in this wine even after fermentation. It had rounded a large bit but still its present. If i would make wine from it i think i would blend something like raisins or such in a higher ratio to it. But for distilling purposes i am happy that its still there. I hope the aromas and notes are still present atleast a
little after distillation.
liter.
honnsmannen
i was thinking about how to lingon flavor will be after distillation, i am guessing that the tartnes would not carry over. glad to hear it still be there after fermentation! exited to hear about how the final product turns out!
Peaty Jones
Short update:
Have had my hands full with diapers and baby powder and not a lot of sleep lately so i have not had much time for this lately. But i managed to get the wine stripped. Didn’t measure the volume and proof but the taste still got some of the lingonberry taste in it!
Going to age this in same kind of 1,5l french oak barrel as Triple B. I also started four New 6,4l american white oak barrels. I just dont know the toast level for them yet since the person who i am crafting them didn’t know how he wanted them yet.
- PalCabral
Then I think congratulations are in order, Peaty! Very happy for you and Mrs Jones!
I still think you should keep st least some of ghe Lingonberry brandy white, unaged. If the flavor is delicate, the wood could easily take over. But you do you!
- Yonder
One of my favorite meads was a mix of blueberry and boysenberry. I don’t have your access to lingonberry or i would surely rush out and work up a batch (the frau loves them in jam). D47 is my go to for fruit meads while i use a 71b for bouchet and plain honey.
- Username
I had noted you're absence Peaty, seems like congrats are in order, that explains a lot
Nice work on the barrels, as a matter of interest have you found a European source for the bain marie pots?
I've been buying mine from the states and it's making them more expensive than they should be, adding on the shipping and duty
Peaty Jones
Thanks Pal and UN! First it was a long wait and now that shes here with her siblings, the days go so quick
. I thought i know the drill since she aint the first one but it seems the situation is totally different in each case
. Also I feel like i am starting to age since i recently got precription for glasses
. It was a bit of a shock since i have always felt my vision is good.
I will take a small sample as white dog on the side from this one also!
I feel you UN! I have also ordered them from ebay and if i remember correct they were from the states! I just ordered about 30 of them so i dont have to order them again in a while. Also the shipping cost/pot was a bit less. If you happen to find somewhere cheaper, notify me also! Thats why i sell some of my barrels. To cut the costs.
Peaty Jones
Lingonberry Jam is great with all sorts of meat food!
For mead on it own atleast the wine i had it is quite tart in taste. It could work as an small addition with something sweet! I am interested if the tart taste still follows with it after spirit run.
Boysenberry and Blueberry sounds fantastic! I would give it a try if we had boysenberries here! I like to eat quark as a
quick meal and my favorite is to add this boysen berry soup which they sell at the market!
Triple B was quite good when it was as wine. I could imagine if you tweak the recipe you could make an excellent mead out of it!
Yonder wrote: ↑Tue Nov 17, 2026 10:43 pm One of my favorite meads was a mix of blueberry and boysenberry. I don’t have your access to lingonberry or i would surely rush out and work up a batch (the frau loves them in jam). D47 is my go to for fruit meads while i use a 71b for bouchet and plain honey.
