My First....."Major Problem"
La_Swampfox
I know this forum topic is supposed to be for "First" ferments, distillation, equipment builds, etc.; .....but I do not see a topic related to problems or trouble shooting them. (And it is a "first" of sorts. LOL) If I posted this in the wrong place I sincerely apologize!! As a novice distiller I have only made seven runs now, 6 Stripping and 1 Spirit; and experienced ZERO problems. I was able to get my fire set to hold my desired vapor temperature at my condenser inlet, and my collection rate to hold steady for hours without any further fire/heat adjustment until nearly the very end; ......even though I was informed my first run was too fast for a "1.5 run and done", .....it had done exactly "as I had wanted it to do". I have now tried to run my 2nd Spirit Run with the low wines from my last 3 Stripping Runs 3 times with ZERO success.
In my earlier runs I had basically got my fire 95% adjusted while collecting my 6 ounces of foreshots, and 100% adjusted to hold a steady temp and desired flow while into my 1st collection jar. This time I can not get it to even remotely hold steady; and if I had only heard this, and not seen it myself; .....I would have never believed it was possible. I will have the vapor temperature holding at around 174/175 with a collection rate of about 12 ml/minute and then suddenly it just stops flowing, and the vapor temperature falls from the low/mid 170's down to the low 150's degrees in 15 to 20 seconds. A few times it even fell into the low/mid 140's and once to 139 degrees F. It will sit there at that temp for a few seconds then climb back up to the original temp, or maybe even a degree or two higher, nearly as fast as it fell; ......then sit steady there for maybe 10-15 seconds and suddenly fall again. The first time it happened my ears being long trained for subconsciously listening for any change or different sound in the normal sounds of an operating oil refinery, or any running equipment, instantly alerted me that the Thumper had quit "thumping" or bubbling. A quick glance at the thermometer on my Thumper vapor outlet confirmed this, and I immediately thought the fire had gone out for some reason. Nope; fire was burning a clean blue steady flame just as it had been, but all boiler/kettle sounds had also stopped completely. My next thought was maybe a flooded Thumper blocking the vapor outlet to the condenser; but this had never even remotely happened before as I usually charge it at about 1/3 capacity, and when finished it is maybe at 55% capacity; and has been for all 7 previous runs. I shut down and checked it anyway; and sure enough the level was unchanged as far as I could visually tell. My next thought was maybe a collapsed gasket or some other obstruction when assembling the still was causing it. Broke all this down and again nothing; all lines condenser and worm perfectly clear. Then suspected a shift in my worm's downward spiral causing "pooling" of the distillate, so checked this; and again nothing as all was well. Then realized any of these first thoughts/ideas on the problem would have been causing back pressure; and that the vapor from the boiler would have still been flowing, the Thumper "thumping"; but pressure building; .....so knew it was none of these reason. It had to be originating in the boiler/kettle. There was just a little over 3 gallons of pure, clean, clear low wines in my 5 gallon boiler; so not problem there with flooding of the outlet or "puking".
I worked in the Gulf of America building and operating the oil production platforms; and the local refineries and chemical plants building, maintaining, repairing, and operating the furnaces and heaters heating the crude oil for 48 years. The 220 feet tall distillation/fractionation columns or towers, as well as the air/water/or product cooled condensers or heat exchangers involved in the distillation or crude oil. The distillation/fractionation towers are just a huge model of the column still some of you use; complete with trays/plates, bubble caps, packing, etc. In all my years around this distillation process I never saw or heard of ANYTHING like this before. I know the BTU's per cubic foot of Natural Gas van vary a good bit from one region of the country to another, and even within a region as the gas from different wells can vary; .....but not enough to cause this. I also know you can have various gases or even inert gases or air encapsulated or entrained within Natural gas at times while under well pressure or even high pressure pipeline transmission pressure, that will escape and form low BTU pockets when dropped to household distribution pressures. This will cause temperature drops and a discoloration of you pretty dark blue flame to a light blue with orange tips. None of this was evident, and besides the pockets of these entrained gases don't "come and go" that quickly.
After shutting down and inspecting, and trying a second time with the same problem, I shut down for the day due to time constraints and to think about it. A couple days later I hooked everything up and tried to run for the 3rd time. At first it seemed to be doing better, but not as good as the first 7 runs. But by the time I got a little over half way into my 1st collection jar the erratic/oscillating temps and flow started again. So I shut down again to consult with you guys for any ideas on this. I know it sounds totally crazy; and to me right here looking at it, it totally is!! The only other info I can provide is the ABV of the low wines I am trying to run is 35% as I obviously miscounted the measuring cups of water I had added when reducing it down from 56% to 40% to rerun. As I said earlier; if I had not seen this happening with my own eyes; I would have a hard time believing that it can and is happening!!
- PalCabral
Re: My First....."Major Problem"
There's only one thing that creates heat in still and that's the heat source. That would be my first port of call. When on elecrtric you share the electric capacity with whatever else is on the circuit. If you're sharing the circuit with a washing machine or something else that needs a bit of power, you'll see a drop of power in your element too. With gas I am not so experienced, but gas flickers when it is running low, right? If gas bottle is full, maybe something wonky with the regulator.
Not sure what you means by temps falling. I measure by the flow at the spout, it is the only "meter" you need in a still. Thermometers are prone to giving false information and in a still they are pretty much useless. I can't help you there and honestly it is a source for misinformation on your part. A reduction of flow, however, with a heat source that is functioning and stable, is a sign of leakage. The alcohol vapors are finding their way out somewhere in your set up. Typical places for leaks are the seals between boiler and boiler lid, between any joints, and where you have your thermometer(s).
Peaty Jones
Only thing that comes in my mind when talking about a sudden drop in the vapor path temperature is puke.
PS: you cannot set vapor path temperature by adjusting the heat input. The temperature rises on its own starting from the most ”volatile” components which have lower boiling point and gradually rise depending where you are at on the run. Maybe you overshot your heat input while chasing that temperature you tried to achieve?
Best of luck!
Best of luck!
La_Swampfox
PalCabral wrote: ↑Sat Oct 10, 2026 10:56 am There's only one thing that creates heat in still and that's the heat source. That would be my first port of call.
I agree 110%!! That's why I said in my original post that "it has to be originating in/with the Boiler/kettle" and therefore with the heat source. That's the only way it and everything else downstream in the process could all be effected.
While I do not use the thermometer alone, but in combination with flow rate and any other indicators; I do not feel they are useless. I have a highly accurate digital thermometer that reads and displays instantly to 1/10 of a degree with the probe right in the flow showing what the vapor temperature entering at my Liebig condenser. It is another indicator of not only what temp, but somewhat where in my product fractions I am currently running. It helps me to try and keep the temps steadier and also in the lower end of the Hearts range longer with as slow a rise through the Hearts temperature range as I possibly can. "By temps falling" I meant just that; the boiler/kettle had suddenly stopped making any normal heating or hot sounds; ....the Thumper had quit "thumping"/bubbling; ....no more hot vapor at around the !75 degree F point was leaving the Thumper and entering the condenser, and the temperature at that point was actually falling 25-35 degrees in mere seconds; ....and my distillate flow would completely stop. All are signs/indicators working together and all showing the same thing; .....a loss of heat or vapor. Believe me; as a 48 year industrial pipe welder and pipefitter who has been in, and narrowly avoided a good many other explosions and fires over the years; and worked on rebuilding or repairing the aftermath of several others (some had been deadly). A leak of flammable and explosive vapor is ALWAYS ON MY MIND!! I constantly check for leaks on ALL connections, even when my other runs were running smoothly. I also checked closely for leakswhen this craziness started as that would indeed cause such a problem. I checked with a small mirror, I checked with my hands closely over and around the joints and connections, and I searched with my nose extensively. The sudden and frequent loss of that much hot Ethanol vapor would have been very obvious; .....and there was none. That's why I said this is so insanely crazy. There should be a very obvious and easily recognized cause; .....but I'm not finding or seeing it. LOLPalCabral wrote: ↑Sat Oct 10, 2026 10:56 am
Pour hot water on the propane tank and regulator to see if the problem goes away.La_Swampfox wrote: ↑Sat Oct 10, 2026 9:58 am
La_Swampfox
Many thanks for the reply Peaty. No puke involved here as there was nothing to foam up like a mash or even a wash might. Nothing in the boiler or the thumper but pure crystal clear low wines. The 5 gallon boiler only had 3 gallons in it, and the liquid level was 5" to 6" below the lid and the vapor outlet. Boiler was barely making "simmering" noises/sounds. Same low wines were in the thumper and it also was only about 1/3 full and way below the lid and and vapor outlet. Also I did not get any slugs of liquid through the condenser and/or worm as I would have if there had been a "puke" of the liquid boiling up and over. The thumper was only making a slow, steady, and very quiet bubbling sound the same as it always has. For sure I don't think I overshot my target flow and temperature, as I actually started to cut my initial fire back a little too low and a little too soon in an effort not to overshoot it. It took a little while to get from about 150 degrees F up to around 170 F when I got my first drips/flow of foreshots. My thumper is pretty small and when the boiler does start sending it hot vapor, it will heat up really quickly. if you are not on top of it, you will get a pencil lead or toothpick size stream to begin with, if you don't cut back on your heat early enough.Peaty Jones wrote: ↑Sat Oct 10, 2026 12:56 pm Only thing that comes in my mind when talking about a sudden drop in the vapor path temperature is puke.
It sounds like fluctuating gas burner to me too .
I used to run outdoors with gas and despite using shrouds , it would be constantly varying .
A low gas bottle will do it more . Especially on a cold day .
I agree also that you shouldn’t chase temps. Adjust burner for desired output flow rate and observe temp if you want too but don’t adjust the burner to achieve a particular temp .
La_Swampfox
Thanks for the reply Shady; appreciate your time and thoughts. There is no Propane/LPG bottle and regulator, or even Propane/LPG gas involved. I noted in my original post I am on a commercial/residential natural gas system. Our area is blessed with a high grade of natural gas at very reasonable prices. My home appliances are mostly natural gas; my Central Heat Furnace, hot water heater, kitchen stove, and even my standby emergency generator. We have reliable service, great pressure and full flow as needed/required. I can have the heater, stove, hot water heater and the generator all running at the same time; and none of them are being starved for gas/fuel. I am running my still in the kitchen on a 16.000 BTU stove burner. That was the only burner on, and was set below the "2" on the dial which is calibrated Lo, 2, 3, 4, 5, 6, and Hi. The hot water heater may have occasionally come on briefly for a few minutes to reheat; but the furnace is certainly not running this time of the year, nor the standby generator; ......so a fuel shortage/starvation is not the problem.
La_Swampfox
Many thanks for the reply Yummy; but please see my reply to Shady just a couple minutes ago that should be right above. There is no Propane/LPG gas, bottles, tanks, or regulators involved. I am on a commercial and residential natural gas system which has none of the problems associated with propane.
My bad, I read that but forgot before I could get around to forming an answer.La_Swampfox wrote: ↑Sat Oct 10, 2026 5:28 pm
But it still sounds like a variation in applied heat. Maybe try a different burner on the stove.
Peaty Jones
That sounds weird. Does the temperature drop ”Suddenly” so that the temp just ”knocks down” or does it stop the stream and then gradually lower the temperature?
I mean, even if you stop the heat source, it usually is the case that the temperature gradually drops but if its sudden then it sounds like something cools it.
Dare to share a picture of your gear? It could help figuring the issue.
La_Swampfox wrote: ↑Sat Oct 10, 2026 5:09 pmMany thanks for the reply Peaty. No puke involved here as there was nothing to foam up like a mash or even a wash might. Nothing in the boiler or the thumper but pure crystal clear low wines. The 5 gallon boiler only had 3 gallons in it, and the liquid level was 5" to 6" below the lid and the vapor outlet. Boiler was barely making "simmering" noises/sounds. Same low wines were in the thumper and it also was only about 1/3 full and way below the lid and and vapor outlet. Also I did not get any slugs of liquid through the condenser and/or worm as I would have if there had been a "puke" of the liquid boiling up and over. The thumper was only making a slow, steady, and very quiet bubbling sound the same as it always has. For sure I don't think I overshot my target flow and temperature, as I actually started to cut my initial fire back a little too low and a little too soon in an effort not to overshoot it. It took a little while to get from about 150 degrees F up to around 170 F when I got my first drips/flow of foreshots. My thumper is pretty small and when the boiler does start sending it hot vapor, it will heat up really quickly. if you are not on top of it, you will get a pencil lead or toothpick size stream to begin with, if you don't cut back on your heat early enough.Peaty Jones wrote: ↑Sat Oct 10, 2026 12:56 pm Only thing that comes in my mind when talking about a sudden drop in the vapor path temperature is puke.
- PalCabral
I suspect you have the culprit there, although you don't believe it. The flow is driven by the heat you put into the boiler. If your flow slows down without any manual interference on the energy input, it's either 1) the heat is not consistent (the energy is fluctuating), 2) a draft or something else external is cooling your boiler and still head such that the energy being put in is not strong enough to maintain the same flow, or 3) you have a leak in your system.La_Swampfox wrote: ↑Sat Oct 10, 2026 5:28 pmThe hot water heater may have occasionally come on briefly for a few minutes to reheat; but the furnace is certainly not running this time of the year, nor the standby generator; ......so a fuel shortage/starvation is not the problem.
The latter you say you have checked and checked off. The former, which is the most obvious reason, you are also sure it's not. If I remember, we discussed in a separate post that you had an AC or fan above your stove which pulses and thus cooled your still head, causing a disruptive flow. Could it be the same or something similar?
Worm surge due to huffing.La_Swampfox wrote: ↑Sat Oct 10, 2026 5:09 pm
- PalCabral
What is a worm surge, Shady?shadylane wrote: ↑Sat Oct 10, 2026 11:37 pmWorm surge due to huffing.La_Swampfox wrote: ↑Sat Oct 10, 2026 5:09 pm
Its what happens when Huffing starts.
Any condenser does it not just a worm.
Where are you distilling Inside or out in the open ?
Even a slight breeze can effect the out put of a still, make them surge and carry on if its strong enough and cool enough.
- Corn Cracker
12ml a minute seems like a really slow collection rate, that's roughly about 24oz an hour. Your temps the me off so I had to read it skipping those but, i once did a really slow run, it was about 8 or 9 hours on a 12gl charge instead of 5 or 6 hours. I did have my output stop and start twice during the run but after I thought about and checked my jars it turned out to be it was at the head/hearts and hearts/tails transitions. I have no thermometer but it seemed like I got the fores and it slowed, and picked back up, got through the heads and it stopped for a few seconds and picked back up them the same happened at the tails transition. It was really pretty cool. So I'm thinking in your case you maybe have the same thing happening?? Try a little more heat on your run
La_Swampfox
Don't think it's an applied heat or stove burner problem. As an old pipefitter welder who learned many years ago about the importance of keeping his cutting torch tips clean for good performance; I regularly use a set of torch tip cleaners to keep my stove burner jets cleaned out. All burners have an even pretty blue flame with no variance and no orange tips. Every gas appliance in my home, including my Central Heat Furnace, stove, hot water heater, and even my emergency standby generator can be on and there is no decrease in efficiency or performance of any of them. I made sure all my gas and water lines were sized large enough to prevent problems like this.
Sorry but I can't wrap my head around all the facts because the temps keep getting in the way.
Low-wines are in the boiler, what's in the thumper?
La_Swampfox
Peaty it drops suddenly. It will be dripping a good slow collection rate for a spirit run. Suddenly the thumper will just quit thumping, and within 4-5 seconds the temperature of the vapor stream from my thumper taken right at the Liebig condenser inlet will start falling rapidly. It will fall around one degree per second down to anywhere from the low 150's to even 139 or 140 occasionally. Then it will start rising again nearly as fast as it fell after a short pause at the bottom. Probably one of the reasons the fall is so fast is that the digital thermometer probe is only about 2" or so from the water return/outlet connection of the condenser.Peaty Jones wrote: ↑Sat Oct 10, 2026 7:26 pm That sounds weird. Does the temperature drop ”Suddenly” so that the temp just ”knocks down” or does it stop the stream and then gradually lower the temperature?
Don't have the still pics on my computer anymore to post here, but here is a link from an earlier post that shows the set-up when I first built the condenser, and made modifications to the still itself; plus changed out all the Chinese brass fittings with 304 stainless steel ones which had not yet been fully done when these pics were posted. Think there is even a close-up of part of an "expansion chamber" to hold some copper scrub pads to filter some of the sulfides out of the vapor from the boiler as there was no copper in that section except about a 6" long piece of 1/4" copper tubing which was way too small and would have caused a really high vapor velocity. All piping and fittings now are a minimum 7/16" ID with most being a full 1/2" except the worm tubing which is 5/16" ID, but should not cause a vapor velocity problem because it seems everything is being condensed before getting there as the Liebig condenser outlet piping stays body temp or lower to the touch.
viewtopic.php?p=7826223#p7826223
La_Swampfox
PalCabral you are correct in your memory, and I believe you were 100% correct in that it was my A/C vent by the stove that was causing a 1-2 degree drop in my operating temp for a few minutes about every half hour. It was warm that day and that is about the cycle rate for my A/c coming on and running for a few minutes, then staying of for about a half hour. I was ahead of the game this time (or thought I was. LOL) and had blocked that vent off. Turns out it wasn't necessary as we had a little cool spell that morning, and while I was fighting with this issue the A/C unit never came on. But I will remember to block that vent off for all future runs.
Maybe try running without the worm or "expansion chamber"
La_Swampfox
Thanks for the reply once again Shady. You have just mentioned something I have never even heard of; and hope you can elaborate on "Huffing"; what it is as well as the causes and remedies that a novice layman can understand. This might be the clue for this problem that I am looking for.
La_Swampfox
Many thanks for the reply CC. It is a slow rate I know; but had seen several posts by people to go that slow during foreshots and heads to compress them and help prevent smearing until you were sure you were into your hearts; then to increase your collection rate somewhat until you thought you were approaching your tails and/or seeing a noticeable drop in your ABV that you had been collecting in your hearts fraction, and then once again cutting the rate to compress the tails and lower the smearing. I also noticed on the one spirit run I have done just what you mentioned, a slowing (no stop) between my heads and hearts, and again between the hearts and tails. My record log proved this was at those points by ABV reading, taste, and smell.Corn Cracker wrote: ↑Sun Oct 11, 2026 3:22 am 12ml a minute seems like a really slow collection rate, that's roughly about 24oz an hour. Your temps the me off so I had to read it skipping those but, i once did a really slow run, it was about 8 or 9 hours on a 12gl charge instead of 5 or 6 hours. I did have my output stop and start twice during the run but after I thought about and checked my jars it turned out to be it was at the head/hearts and hearts/tails transitions. I have no thermometer but it seemed like I got the fores and it slowed, and picked back up, got through the heads and it stopped for a few seconds and picked back up them the same happened at the tails transition. It was really pretty cool. So I'm thinking in your case you maybe have the same thing happening?? Try a little more heat on your run
The most common reason for huffing is the sudden collapse of vapor due to the condenser water being too cold or having too much flow.La_Swampfox wrote: ↑Sun Oct 11, 2026 4:25 pmThanks for the reply once again Shady. You have just mentioned something I have never even heard of; and hope you can elaborate on "Huffing"; what it is as well as the causes and remedies that a novice layman can understand. This might be the clue for this problem that I am looking for.
The output will start and stop.
La_Swampfox
That makes two of us Shady. Same thing in the boiler and the thumper;'...... low wines at 35% ABV, crystal clear and clean.
La_Swampfox
I may resort to that before long. I ran 7 runs through it and things went as smooth as silk and ZERO problems so don;t think they are the cause; but if all else fails i will be looking to try about anything. LOL
Will be tied up all day tomorrow, and I knew the "little lady of the House" would not appreciate me tieing up her kitchen all day on the weekend; so will probably attack this again Tuesday morning. Interesting info on the huffing. Using tap water in the sink that is just recirculated. It had not even began to get warm when all this started both times and I shut down. When it does start to warm I will partially drain and add some more cool fresh. Just guessing but would think it is probably around 70-75 degrees out of the tap. Later in my runs when the vapor and still temps are in the high 190's or low 200's I will throw a frozen bottle of water into the sink every once it a while. That never gets it cold, but will hold it down probably in the 80's in temperature. I fI feel it getting warm to the touch at all, I change that frozen bottle out for another or swap out some water. Works pretty darn well and has used very little water considering.
Peaty Jones
…but should not cause a vapor velocity problem because it seems everything is being condensed before getting there as the Liebig condenser outlet piping stays body temp or lower to the touch.
If thats the case then maybe you should try without the worm? You should be able to condense the product via the Liebig by itself if its that cool. Extra cooling isn’t wrong but i mean you could try without it and maybe cancel one variable out of the picture.
Peaty Jones
Thats a nice video Yummy!
Do i get this straight: the vapor condenses too quickly and because vapor takes about 1000-1700 times more volume (depending on the ethanol/water mixture) than liquid, it kind of makes vaccuum via ”shrinking” to liquid?
Which then balances back via more vapor coming in and then starts the cycle again and that makes you this pulsating huffing?
I have not had this kind of problem but i could imagine this kind of effect could be happening much easier in a system in which the PC is looong and narrow such as this one.
Yummyrum wrote: ↑Mon Oct 12, 2026 4:35 pmLa_Swampfox wrote: ↑Sun Oct 11, 2026 4:25 pmThanks for the reply once again Shady. You have just mentioned something I have never even heard of; and hope you can elaborate on "Huffing"; what it is as well as the causes and remedies that a novice layman can understand. This might be the clue for this problem that I am looking for.
Yes that description sounds about right Peaty .
It is worse toward the end of the stripping run for reasons I have never thought about .
It also happens on Shotgun condensers . It is not confined to just long Liebigs and worms .
