I have had these slow changes in flow but nothing like this with my 2” shotgun condenser. This is something new to me. Learn something everyday!
My First....."Major Problem"
Peaty Jones
Re: My First....."Major Problem"
Thats very interesting. Maybe the ratio leaning more to water at the end of the run, and the vapor volume is greater with water compared to its liquid form? So that the vaccuum it creates is greater. Meaning ethanol expands less in vapor than water and vice versa. Also the temperature is higher at the end.
La_Swampfox
Well guys; I finally got it done; and want to thank all of you again for all of your ideas and suggestions trying to help me solve this weird problem. I have to honestly say from what I saw on the way my 4th attempt on this Spirit Run (plus the earlier 3 aborted attempts) that I honestly do believe it was a fluctuation in the BTU content of my Natural Gas coming in. The flame is so low on my burner holding my flow and temp at the proper rate that even when I do nudge the fire up or down just a hair to adjust it you visually can see no change in the flame. The flame is barely coming out of the burner and not even coming up over the top edge of the center flame spreader plate; so I guess with a flame that small and changes you can't even visually detect changing things; that a change in the BTU content of the gas could and would do the same thing.
Even though I had pulled off 6 ounces of Foreshots on the 1st and 2nd attempts, and 4 ounces on the 3rd; I pulled off another 4 ounces again and started my first collection jar. (Don't know if that is necessary, and maybe some of you seasoned veterans can elaborate, but seems to me that all of the Foreshots and some of the early Heads should have all been eliminated from this batch of Low Wines) Temp and Flow held good and steady through the Foreshots and halfway through the first collection jar; then flow slowed by half and temp dropped about 10 degrees for a few seconds and returned quickly to as it was. About 5 minutes later it did it again, and the same 10 degree drop/flow slowdown; ....nothing like the 35-40 degree sudden drop and flow stoppage I was getting on the first 3 attempts. I took Corn Cracker's advice; kicked my fire up and powered through it; but getting a much faster flow than what I wanted. It was running from a very fast drip, to an intermittent/broken stream, to a full toothpick/pencil lead size stream at times. I finished the 1st jar like this and nearly all of the second jar and noticed it had steadied somewhat into mostly the intermittent/broken stream and a tiny full stream occasionally; so started cutting back on it. Continued to very slowly cut back in minute adjustment of the stove burner, and half way through my 3rd jar I had a good steady rate; ......but a little slower than I wanted. Not wanting to mess up a finally good thing, and figuring "slower" is better than "faster"..... I decided to not press my luck and left things alone. It made for a long run and a long day; but I ended up collecting the first 2 jars/14 ounces at 70% ABV; then 11 jars/77 ounces at 69%; 3 jars/21 ounces at 68%; 1 jar/7 ounces at 67%; then they fell about 5% and collected 2 jars/14 ounces at 62%; next jar dropped to 55% and final one to 45% and I quit. Left a fair amount of alcohol, but I am not planning to run anything else for a while so did not want to go into the tails, or save any feints for future runs; .....and I could smell the change in this last jar, so called it good, .....and I was tired!! LOL!! (Hoping those first 3 jars caught at that fast collection rate are at least partially usable.)
Have one batch of UJSSM from my first 3 Strips and 1st Spirit Run on charred oak right now; and want to get my fractions/cuts made on this run and get it on charred oak to see if I have made a product that is worthy of drinking and enjoying; or if I need to do something different. No use making more stuff that is untried/proven and maybe not fit to drink and enjoy. This Spirit Run I did Tuesday was made on the 4th, 5th, and 6th Sour mash generations of my UJSSM; but I added 1.5 pounds of malted soft red winter wheat, and 1 pound of malted 6 row barley I had steeped and added into each of the ferments. I prefer wheated Bourbons and thought I would play with this idea and see what it would produce. I know it darn sure smelled good!! The wife even commented on how good the escaping CO2 and aroma smelled in comparison to the straight/original UJSSM. Smelled good enough to drink right out of the fermenter; so sure hope and pray the distilled version is palatable. LOL
PS: Yummy; thanks again for the explanation and the video on "Huffing". Very interesting; and makes total sense; .....but also nothing like what I was experiencing. Kind of wish it was because it would be an easy fix.
- PalCabral
Good you got through your run, Swampfox!
And finding your way to control the flow just “right” on your still is one of the hardest things when you’re new and new to your equipment. I am still fiddling what flow is best through heads, hearts and tails.
- Copperhead road
Every still is different in finding the sweet spot. I found my plated flute was the hardest to get running stable, a needle valve on the RC was the best way to find the sweet spot and keep all 5 plates loaded and happy.
Good job Swampfox.
Good job Swampfox.
WVtired
New to it and I run a very small copper pot still outside over propane, so I have learned that temp fluctuations (I just glance at it for reference on occasion, learned early on to forget that and watch the flow and listen to the pot) are pretty common, especially outside where wind and temp are factors. I just barely tweak my regulator knob when I need to bump the heat or cut it back at all. It takes almost nothing (and I also run a very small flame on my burner due to my small pot) to make the slight increase or decrease needed and I get almost instant feedback from my worm when I tweak it. Very small adjustments for me work well.
Flow slows too much for too long, I give it a nudge up... starts huffing, nudge it the other way. Wind not a factor that day, I can pretty much walk away and not worry other than swapping jars on occasion.
eta - I will also add that this group here have been most helpful to me on my start of the journey. Thanks to all for your input and guidance!
