Clouding and darkening, no change in taste
- Username
So I have an issue that I'm finding hard to explain
I've a 10L barrel that I've recently put sugarhead whiskey into, it's preformed up to and beyond expectations, producing a young whiskey, that you could almost sip on it's own but that absolutely works with a mixer. I pulled 2L off the barrel and topped up with a mix of other jar experiments I have on the go.
The whiskey I pulled off was 62%, so my 1st possible error was proofing down to 45% in one go.
I then filled a bottle for inside and added a small piece of oak (2nd use) to the remainder, error no.2, the abv may be on the low side for oaking
The following day on my daily distillery checks I noted the "whiskey in the jar" (pun intended, credit Thin Lizzy) had got very dark and a bit cloudy, so I took the oak out. The whiskey had picked u some extra oak aroma/flavour, so I decided to blend the bottle I had taken off back in. I then proofed everything down to 40% and re-bottled just one bottle, leaving the rest of the jar on a shelf out of the sun in the shed.
So today, a little over a week from bottling we had an occasion and made our way through the bottle, which was a little cloudy but acceptable.
There was then a need for more whiskey, so I went back to the jar.
The whiskey still tastes exactly the same, but is now very murky, dark and opaque. This transition has happened with nothing but the original liquid in the jar.
I'm confused as to whats going on here, the initial darkening and clouding was much more than I would have expected from a single days contact with a small piece of oak.
The oak had been taken out of a jar, remember it was previously used and it hadn't had this affect on the spirit in the original jar
The darkening and clouding seems to have continued, even after the oak has been removed
The taste doesn't seem to have been affected, and is still the same as the clear liquid
Anyone have an explanation for whats going on here, I'm a bit confused
- Username
Re: Clouding and darkening, no change in taste
Also not sure I posted this in the right section
greggn
How is the jar sealed ?
________________
- Username
It's a cheaper version of a "Kilner" jar, I have it pictured above.
There's a lever closure on a silicone seal, which I have wrapped in ptfe tape.
There's a possibility that it's not 100% airtight because of the tape, I'm guessing is the root of the question.
Oxidation of some chemical in there is one of my theory's
Edit: I see most of the thread has been lost and I must have missed this post earlier, sorry greggn. Pic added again
greggn
Username wrote: ↑Tue Aug 25, 2026 10:31 pmIt's a cheaper version of a "Kilner" jar, I have it pictured above.
No, not oxidation but contamination was the concern. Things like agglomerated (i.e. glued) corks aren't meant for high proof alcohol.
... nor parchment paper as I learned the hard way.
viewtopic.php?t=90283
________________
- Username
I should have updated this a while ago as I figured out the problem
I didn't want to proof down with my tap water, it tastes fine but is chlorinated, so I bought some bottled water from the supermarket.
So the particular bottle I bought (cheap 5L bottle) is quite high in minerals.
I figured it out when I proofed down a clear spirit, which turned cloudy straight away. I was pissed off and left it sitting for a few weeks in a dark corner, when I came back there was a thin layer of sediment after settling out on the bottom of the demijohn and a crystal clear spirit above it again
- PalCabral
My tap water is good, no bad tastes at all, but I almost always get cloudy when I use it to dilute spirits. I only use RO water to dilute these days. Seems to work better.
- Username
I don't have an RO system, so I've been buying distilled water, I appreciate the irony
It's another reason to pull the trigger on a little vevor water distiller(air still) and actually distil some water amongst other things
- PalCabral
Interesting. I've always used distilled water, purchased at the chemist. However, it's impossible to find it anymore but what is now on offer is RO water, although called filtered water here. It works for me.
is the weather colder than it was?
Cloudy spirits will often clear when warmer or go more cloudy when cold.
- Copperhead road
I have found that as well Salty, i had some whiskey once that came out cloudy in the winter. I know it was not a puke... i revisited a couple of Demijohns in the hot humid QLD summers 35 degrees and it was clear as a bell...Saltbush Bill wrote: ↑Sun Oct 18, 2026 11:43 am is the weather colder than it was?
I didn't even think of temperature until i read your post now... mystery solved.
- Username
This was mid summer fella's. Don't know how that whiskey turned out as it didn't live long enoughCopperhead road wrote: ↑Sun Oct 18, 2026 3:27 pmI have found that as well Salty, i had some whiskey once that came out cloudy in the winter. I know it was not a puke... i revisited a couple of Demijohns in the hot humid QLD summers 35 degrees and it was clear as a bell...Saltbush Bill wrote: ↑Sun Oct 18, 2026 11:43 am is the weather colder than it was?
I didn't even think of temperature until i read your post now... mystery solved.![]()
The next spirit I proofed down with the same water clouded and dropped bright over a few weeks leaving a mineral sediment on the bottom of the jar, changed my proofing water and been good since
Mystery solved
It’s not far fetched Username .
Calcium Chloride for example, will form a precipitate in an acidic environment . Distilled alcohol is acidic .
So it is quite possible that your mineral rich water caused what you saw .
EDIT : nah , just tried it wasn’t that
But still doesn’t mean there weren’t other precipiation reqctions going on
