Need a better fermenting vessel
BigSwede
Re: Need a better fermenting vessel
Post by BigSwede »
Appreciate the kind words guys. It'll beat hell out of slopping around with big HDPE buckets like I used to, with yeast dregs everywhere, spills, and my back will thank me.
The fermenter is 3X the volume of my boiler, which is about 10 gallons. After 2 or 3 fast stripping runs, I should have a full low-wine boiler charge. That was one of my issues in the past. Multiple ferments stripped, combined, and there was no consistency.
I have yeast and nutrients arriving for some Shady's Sugar Shine. I'm looking forward to trying this recipe. The approaching local fall weather should provide for a mid 80 f. / 30 C overall temp, good for baker's yeast. Goal is 8% - 10% ABV. We'll see!
Come winter, the heating coil will see some action for sure. :thumbup:
BigSwede
Post by BigSwede »
Final update on this - couldn't be happier, and may give some ideas. I do have a simple question as well.
Background - in the past, I've used multiple small HDPE pails, which was a total pain in the ass. And my climate prohibited fermentation during much of the year as it is done in an unheated building.
I put it all up on a pair of roll carts, one for the fermenter, and the second for a heater. The heating system consists of a plastic cooler, 8 gallons of water, a 1KW immersion heater, controller, and a small water pump. The controller probe is in the fermenter.
The pump routes warm water through a stainless coil in the ferment:
The controller is a cheap ($50) temp controller + SSR:
I mixed up a 22 gallon batch of Shady's famous sugar wash (Thanks Shady!), set 85f/29C degrees, went to bed, and this morning, after a 48f/9C night, the wash was spot on at 86 degrees, and I could see the immersion heater cycling to maintain. Perfect.
But... the wash was huffing CO2 like a drunk leaf blower, puking the airlock water out the top. All I have is a standard cheap plastic job designed for 3 gallons of beer. Too small for 22 gallons. Any recommendations for a proper airlock? Do guys even use them? I guess I could bend some stainless tube into a downward "U" shape and just drop the end into a water container.
I do like seeing bubbles... lets me know if the ferment is active and healthy.
WVtired
Post by WVtired »
If the ferment is taking off like that, I don't close the lid tight or even consider an airlock until it settles down a bit. A towel over the container is enough, or I just loosely place my lid (I use plastic buckets cos my wash is not over 6gals) until the volcanic activity slows to a normal ferment (like when you add DAP to UJSSM, I found out... lol).
Deplorable
Post by Deplorable »
If you must have an airlock in that ferrule on the top, what I would suggest would be to just stretch a balloon or a rubber glove over it with a pin hole. It will stand erect when the ferment is active, and when it's done, the balloon will deflate and fall over. The pinhole will be enough of a vent to keep the glove or balloon from popping.
Salt Must Flow
Post by Salt Must Flow »
I ferment two 45-50 gal of Shady's Sugar Shine in 55 gal poly drums at a time and do not use an airlock at all. I do place the lid on the drums, but leave the 3/4" hole in the lid wide open. I do keep my drums in a temperature controlled box though.
If you're concerned about keeping your fermenter out in an open room (not inside of any chamber) with an open port, I'd install two 90 degree elbows together into the exit port so that the opening is facing straight down. Nothing is going to enter that port unless it's a bug. If you're scared of bugs entering, you could always stuff some polyfill into the fitting or some sort of filter/screen.
BigSwede wrote: ↑Sat Oct 17, 2026 4:20 am
I'm too lazy to bend SS, maybe use a silicon hose stuck into a bucket. :lol:
Personally, I'd just wait, the bubble trap has done its job and kept air out until there's a massive amount of Co2 being made.
In a day or two everything will settle down and you can refill the airlock with water if you want to.
30xs
Post by 30xs »
As much as Swede likes to tinker, I remember seeing a thread on here some years back where they built an airlock out of pvc pipe that used a ping pong ball to seal the vent. I’d just run a hose into a bucket and call it a day.
Yonder
Post by Yonder »
My airlock is a length of silicone hose that ends in a quart jar of water. Nothing complex. If you have one a them store bought airlocks just leave off the cap and hook the hose right to it. Don’t over think it.
BigSwede
Post by BigSwede »
Yonder wrote: ↑Sun Oct 18, 2026 9:37 pm My airlock is a length of silicone hose that ends in a quart jar of water. Nothing complex. If you have one a them store bought airlocks just leave off the cap and hook the hose right to it. Don’t over think it.
I was talked out of my usual over-engineering, and this is exactly what I did. No bent stainless, a flexible tube into some water. Thanks.
The heating system works surprisingly well. Fermenting is the one case where heat CONTROL is good in this hobby. The only time the heater comes on is at night when the surrounding temp drops to 47f/8C, and the cycling of the heater is maybe 10% on, 90% off... just sends "pulses" of energy into the system. Day time, with a set value of 85f/29C, it ranges 85 to 88 degrees.
If anyone wants to make similar, I recommend the pre-built wort chiller coils with the up tubes already in place. Just cut them off and add plumbing through the lid. Trying to make one from a raw coil of 304 SS would be a nightmare - the stuff is not pleasant to work with. Far worse than soft copper tubing.
BigSwede wrote: ↑Mon Oct 19, 2026 3:43 am
Been watching this with interest Big Swede .
Got a SS coil in shed , been wondering that the F to do with it .
I’m liking what I am seeing . :ebiggrin:
Can’t copy , but can adapt .
Thank-you Sir .
BigSwede
Post by BigSwede »
Yummyrum wrote: ↑Mon Oct 19, 2026 3:50 am
Thank-you Sir .
:thumbup: Coil doesn't have to be pretty, just leak-proof in the fermenter portion. We don't want heater/coolant water draining in there.
The heater element is easy. These things are cheap. $19 on Amazon here in the U.S.
Most seem to be 1.5 to 2KW, far more than needed, but so long as the controller can handle that, and SSRs will, the on/off cycling will be very low.
Copperhead road
Post by Copperhead road »
I love your heater so much more robust than aquarium fish tank heater. :thumbup:
Deplorable
30xs wrote: ↑Sat Oct 17, 2026 10:00 pm As much as Swede likes to tinker, I remember seeing a thread on here some years back where they built an airlock out of pvc pipe that used a ping pong ball to seal the vent. I’d just run a hose into a bucket and call it a day.
I remember that. It just made me realize all he has to do with that lid is place a marble on that hole in the ferrule
Roo
Post by Roo »
BigSwede wrote: ↑Mon Oct 19, 2026 4:20 am :thumbup: Coil doesn't have to be pretty, just leak-proof in the fermenter portion. We don't want heater/coolant water draining in there.
This seems $$$ compared to Aus, but the idea is a low power heater to do what you are doing if you have a 1.5" or 2" tc port
https://morebeer.com/products/kegland-w ... 9TNT9Wmvs4
BigSwede
Post by BigSwede »
Some math might figure out the wattage needed for immersion heat. And one's climate as well. Got to combine ferment volume, ambient temps, assume some heat transfer losses, etc. This is one case where use of (that which shall not be named) would be useful... not many of us are thermodynamicists.
Two good things - you can use all the plastic you want, because none of the ferment will contact anything in a heater box. Second, if a heat controller (like one from Auber) drives a SSR, you can run a too-large heater no problem, since the whole PID thing just flicks juice into the heater as needed, in little bursts.
My guess would be 300 to 600 watts would be more than enough for a beefy ferment anywhere outside the Arctic.
zach
Post by zach »
I use a sous vide heater to maintain a reservoir of water that I recirculate through the stainless coil in my fermenter.
It's rated at 1200 watts , was $60 US with built in controller and it's great for cooking meat as well.
