Structured Packing Quest
Re: Structured Packing Quest
Post by Novice »
shadylane wrote: ↑Tue Oct 27, 2026 10:29 am Great project making the structured packing.
I've used scrubbies that look just like that and they worked measurably better after being teased out and repacked.
I agree with that Shady . Those ringlet coils in scrubbies are much better when stretched out and squished back in .
BigSwede
Post by BigSwede »
Oh definitely, those are brand new, just unwrapped them to clean and passivate. The test scrubbie column will be a mix of copper and stainless.
This helped me a bit.
https://www.shd-pub.org.rs/index.php/JS ... w/6233?utm
Thank you, almost tailor made for this experiment. Bit of light reading. :thumbup:
30xs
Post by 30xs »
Are you located in the U.S. Swede? I think I have an outside sweat ferrule in 3” I can send you to make them drop in from the top. I think they are machined a little oversize so a shim may be needed to solder.
BigSwede wrote: ↑Tue Oct 27, 2026 9:30 am
Finally, I'm trying to mentally create a test plan, using VM... how to compare scrubbies with structured packing. Perhaps charting throughput and ABV over a gradually increasing power setting without changing the VM valve setting. Any test suggestions?
would be interesting to test both at say 25cm ,50cm,75cm and 100cm and plot ABV at different power settings .
I think you are on the money doing it with a VM at a set position .A VM will maintain the same Reflux ratio as you vary the power where as all other still heads would be a nightmare to compare as you adjust , would be almost impossible to maintain a constant RR for comparisons .
BigSwede
Post by BigSwede »
30xs wrote: ↑Tue Oct 27, 2026 3:20 pm Are you located in the U.S. Swede? I think I have an outside sweat ferrule in 3” I can send you to make them drop in from the top. I think they are machined a little oversize so a shim may be needed to solder.
Much appreciate the offer... I think I know what you are talking about. The 3" column has one of those at the bottom. The top has a soldered and riveted home made 3" to 2" TC adapter that is permanent, so as to feed all my 2" reflux stuff.
So the biscuits will go in from the bottom, through the outside ferrule and into the pipe, and are a decent tight fit. I'm not worried about wall channeling.
Good ideas Yummy. I'll figure something out. I want to generate hard data, actual numbers, definitely not "Works good! Better than scrubbies."
Salt Must Flow
Post by Salt Must Flow »
BigSwede, how's it coming along? Anxious to hear how the packing works.
BigSwede
Post by BigSwede »
Salt Must Flow wrote: ↑Sat Nov 14, 2026 8:48 am BigSwede, how's it coming along? Anxious to hear how the packing works.
I have one more wash ready to strip, it's done fermenting. All the low wines will be combined and diluted for two identical spirit runs, besides the packing type.
It's a short column which should be challenging in terms of getting a high ABV with any sort of realistic output. Still trying to figure out the best way to compare the two, but I'll come up with something. I'm also interested to see what kind of reading the manometer gives.
If I were to guess, 2 weeks? It's getting closer!
Windy City
Post by Windy City »
Watching with anticipation
Hope this works out great for you
BigSwede
Post by BigSwede »
Windy City wrote: ↑Tue Nov 17, 2026 6:52 am Watching with anticipation
Thanks Windy!
Guys, I’m finally about to try the new packing with VM. I want to compare it to a typical hobby packing, scrubbies. I’m trying to come up with a meaningful test process. My theoretical knowledge of columns and reflux is not great. More like “fiddle, fuss, here comes high ABV, yay!”
The two runs – identical everything except packing. A 1 meter, 3” dia column. The oddball part is my VM topper. It’s kind of unique in that it’s a slide valve that I can adjust through 40 turns from 100% reflux to 100% product vapor flow.
As someone here said long ago, “enough height and correct power and a column of paper clips will make azeo.” Given that, I’m thinking the way to compare is output, liters per hour, at peak ABV, between two different column packings. Run scrubbies first, then StP.
Here’s one thought for testing. 8-10 gal 25% ABV low wine charge for both.
1) Obtain equilibrium at “X” KW for 20 minutes
2) Bleed foreshots very slowly, identical volumes, say 400ml
3) Open valve further until ABV starts to drop from its peak. Note this ABV for 2nd run.
4) Measure output in ml/hour
5) Stop when tails appear and temp spikes
If structured packing is superior, output at the noted ABV should also be higher. The packing is doing a better job separating the vapor stream. Likewise, if it sucks, I’ll have to restrict output to maintain the target ABV.
Thoughts?
Salt Must Flow
I suppose the "best" way to determine how well a packing works is to determine its HETP. Haggy may be helpful with this.
What I did to figure out how to operate my still using different packings was to test it during hearts within a single spirit run. I chose a relatively low power input, tried different take-off rates (should be 95%+ ABV) and sample the ABV for each take-off rate. Once the % ABV started to drop (or flooded), I would stop that test. I then bumped up the power input, tried different take-off rates and sampled the ABV for each take-off rate. Once the % ABV started to drop (or flooded), I would stop that test. I repeated this test many times until I reached the limit of the packing being tested. After all tests were completed I knew which power input and the highest take-off rate that produced 95%+ ABV during hearts.
After taking samples for each test I closed the gate valve, turned the power off, I put a funnel over the top of the reflux condenser and poured the samples back down the column. I turned the power back on and equalized the column again. I was able to test many times over and over again wile safely returning product back to the boiler. I kept track of all results in Excel.
When I run my VM I set the power input and leave it for the entirety of the run. The only thing I adjust is the gate valve from foreshots, maybe a couple times during heads and once for hearts (the rest of the run). I do adjust the water flow to my condensers as needed.
