100% Rye Whisky
All styles of whiskey. This is for all-grain mashes.
Warthaug
100% Rye Whisky
Post by Warthaug »
So I have a bunch of rye malt that needs to be used before it goes bad. Has anyone here tried making a 100% rye whisky? I was thinking of doing a no-sparge brew-in-a-bag style mash (as the rye would be impossible to lauter otherwise), maybe with some additional enzymes to help with conversion, and then double pot-stilling that.
Good idea? Bad idea? Any suggestions/advice?
B
Brewer for decades, dabbler in distilling who is trying to get better at the craft.
PalCabral
Re: 100% Rye Whisky
Post by PalCabral »
Unless you are already familiar with rye, I suggest you read a lot about before you start. Rye is full of beta glucans and could if you’re not handy with step mashing and enzymes become a total nightmare to mash, ferment and distill.
greggn
Re: 100% Rye Whisky
Post by greggn »
Warthaug wrote: ↑Wed Oct 28, 2026 8:44 am
Rye whiskey is always a good idea. Making it is another matter.
How are you heating your boiler ? Scorching is a very real concern and most folks who *successfully* do high-rye tend to use jacketed boilers.
________________
Warthaug
Re: 100% Rye Whisky
Post by Warthaug »
PalCabral wrote: ↑Wed Oct 28, 2026 10:43 am Unless you are already familiar with rye, I suggest you read a lot about before you start. Rye is full of beta glucans and could if you’re not handy with step mashing and enzymes become a total nightmare to mash, ferment and distill.
I brew beer frequently using 10-20% rye, so I'm familiar with what a PITA it is, and have equipment/techniques appropriate for it. Its my love of rye beer that has led to my over-abundance of rye malt.
I can see how the viscosity could be an issue for puking - any suggestions on how to prevent that? I usually use simethicone to prevent puking, would that be sufficient?
greggn wrote: ↑Wed Oct 28, 2026 11:11 am Rye whiskey is always a good idea. Making it is another matter.
I have a brew-in-a-basket (BIAB) system that keeps the grain above the element in a metal mesh canister, so there isn't much of a scorching issue during malting. I use the same system for distillation; the element is below the liquid (the bottom of the vessel is heated), but there can be scorching if there are solids. I've not had issues with upto 20% rye, but 100% may be a very different beast.
Powder Monkey
Re: 100% Rye Whisky
Post by Powder Monkey »
I’ve made a good amount of 100% rye, but I have a steam set up. It appears you’re going for 100% malted rye, which has a high dp and you shouldn’t need extra enzymes for conversion. It won’t need as high cook temp/time and will be less gummy than raw, but still a concern especially if you have direct element.
I would do a step mash with pH adjustment and hot water additions for glucan and protein rests before increasing to mid 140sF conversion temps. I’d keep your target OG below 1.05 or even lower if scorching is an issue. If you run it on direct elements keep stirring right up until just before boiling point, then run it low power for strip and that helps prevent scorching on the element.
Warthaug
Re: 100% Rye Whisky
Post by Warthaug »
Powder Monkey wrote: ↑Wed Oct 28, 2026 12:21 pm I’ve made a good amount of 100% rye, but I have a steam set up. It appears you’re going for 100% malted rye, which has a high dp and you shouldn’t need extra enzymes for conversion. It won’t need as high cook temp/time and will be less gummy than raw, but still a concern especially if you have direct element.
That's all great advice; it's very similar to what I was thinking. In terms of enzymes, I was thinking of adding beta glucanase which breaks down the glucans, which should reduce the viscosity (similar to doing a glucan rest) and potentially provide some additional sugars for fermentation.
PalCabral
Re: 100% Rye Whisky
Post by PalCabral »
Warthaug wrote: ↑Wed Oct 28, 2026 12:15 pm
I would be more worried about the mash being so sticky your yeast can't get to all of it. Use a lot of beta-gluacanase enzymes, along with xylanase and perhaps protease. A beta glucan rest is definitely in order too.
As for running it, scorching is not only an issue with solids. Proteins can also stick to your elements and scorch. I'll try to add a picture from my elements after this weekend's high rye Bourbon stripping run. The white bits is from the run, using two elements running on half power.
Corn Cracker
Re: 100% Rye Whisky
Post by Corn Cracker »
Warthaug wrote: ↑Wed Oct 28, 2026 8:44 am So I have a bunch of rye malt that needs to be used before it goes bad. Has anyone here tried making a 100% rye whisky? I was thinking of doing a no-sparge brew-in-a-bag style mash (as the rye would be impossible to lauter otherwise), maybe with some additional enzymes to help with conversion, and then double pot-stilling that.
B
How big of a mash are you doing?
I do 30gl mashes. I have 2, 8 gallon pots i add 5 gallons of water in one bring to a boil and
Add ⅓ of my higher gel temp grains with alpha and put that pot with lid in the oven and hold it for 45 minutes to an hour, pull it out, add more alpha, stir and sit to the side, my oven will only hold 1 pot at a time and i know it takes about 20 minutes to get the next pot ready so I take a break before starting the next pot and repeat for the 3rd. Dump em in the barrel, add gluco at 160, stir and let that sit.
Dr Griz
Location: Stowed away aboard the flagship of a pirate zeppelin armada
Re: 100% Rye Whisky
Post by Dr Griz »
Having gone down the 100% rye rabbit hole quite a few times, I'd add a few suggestions to those you've already received:
Even with enzymes to break down the glucans, it's gonna be THICK. Stuck sparges are a serious risk, as is scorching and puking during your stripping runs. And your gravity readings are gonna be pretty useless.
Moderation is key. Don't go too high on your mash temps, and don't chase after high wash ABV. A thinner (lower ABV) wash is your friend. And the lower you run your strips, the less you have to worry about scorching and puking.
Use a defoamer in your strips.
If you ferment on grain, you'll get a thicker cap that usual -- leave twice as much headspace as usual in your fermenter, or get ready for a mess. Just in case, I leave my fermenter lid unsealed for the first few days, so I don't end up with a geyser from my airlock...
Unfortunately, equipment matters. You can moderate the impact of thick wash, but I was only really satisfied with my 100% rye runs when I started steam stripping my wash. With that (or possibly, as greggn says, a jacketed boiler), you won't be constantly running up against scorching and puking.
Finally, when you get your spirit, I find rye (more than other spirits) benefits from a nice long aging.
Good luck!
qui bene bibit est beatus
Warthaug
Re: 100% Rye Whisky
Post by Warthaug »
Corn Cracker wrote: ↑Wed Oct 28, 2026 4:43 pm How big of a mash are you doing?
Relatively small - 25L (~7 or 8 gal) + badmo barrel for aging. My setup is mostly for beer brewing, so I'm limited in the volume I can process. Technically my still can run about 20L of wash at a time, but experience tells me that's a no-go for stripping runs. My plan here is to max out my mash (~25L at 5-6% ABV), ferment off the grain, and run two stripping runs of ~12 L each.
Dr Griz wrote: ↑Thu Oct 29, 2026 8:00 am Having gone down the 100% rye rabbit hole quite a few times, I'd add a few suggestions to those you've already received:
Good luck!
My plan is to use a no-sparge technique to avoid sparges (stuck or otherwise) all together. You loose a bit of potential gravity, but you also don't have to sparge. My equipment doesn't lend itself to fermenting on grain, so I'll be fermenting a "clean" wash. Simethicone anti-foam in the ferment and during stripping to (hopefully) prevent puking.
I am concerned about scorching - my element heats the bottom of the boiler (its not in the boiler itself), but even then I have had scorching issues in the past. I do have a stirrer that can run while the element is on, which may help a bit.
PalCabral
Re: 100% Rye Whisky
Post by PalCabral »
NZChris used to advocate for buttering or oiling the bottom of the boiler with fat, butter or vegetable oil, as a scorching prevention. I remember him mentioning it when scorching was the topic.
Edit: I found it, or one of them, he mentioned it more than once.
NZChris wrote: ↑Sun Jun 22, 2025 10:37 pm I've done berries with the fruit in the boiler and not had a problem with burn on until I ran the pot dry. I always butter the bottom of the pot before filling and don't put the still head on until it's nearly boiling. As long as the boiling action keeps the fruit in suspension, it won't burn. If you are worried about scorching, swap the receiver frequently near the end of the run when it is most likely to happen.
Copperhead road
Re: 100% Rye Whisky
Post by Copperhead road »
I have not seen NZChris in a long while, hope everything is OK.
Re: 100% Rye Whisky
For about the 5th time that someone has asked , NZChris was given a time out for continuing to break the rules . He seems to have chosen not to come back .
Copperhead road
Re: 100% Rye Whisky
Yummyrum wrote: ↑Fri Oct 30, 2026 10:08 pm For about the 5th time that someone has asked , NZChris was given a time out for continuing to break the rules . He seems to have chosen not to come back .
No worries yummy, thanks for the update.
i remember some sh#t in regards to AI and was not sure if he had been banned indefinitely. Its a shame because he contributed a lot to the forum overall.
