Will the barrel have anything left
- subbrew
Looking for opinion here. I have a badmo clone which held a bourbon for 4 years, a mead for the last year (still full) and am thinking of putting a rum in it next. The rum will be made from a combination of baking molasses and brown sugar, so medium strong flavor. What are your thoughts, will the barrel have anything left or should I make a new, uncharred one?
- PalCabral
Re: Will the barrel have anything left
I've got no personal experience but my understanding is that Badmos usually have a few more years to offer than 4 years, but perhaps in a slowly decreasing capacity. Which is why I think Rum is a perfect next choice. Leave it in there for years and allow it mellow while the wood imparts less and less. If you think the color is too pale when it's time to bottle, you can either finish it with a charred oak stick or with E150. I think the oxidation value of a barrel should never be underestimated.
- bilgriss
Aging in a barrel serves a number of functions, and the only one that changes significantly from reuse is the contribution of the wood and prior batches. In other words, you'll still age the spirit at about the same rate, but the "new oak barrel" quality required for bourbon is muted. This is consistent with style of Scotches and Rums usually aged in barrels which have been used before. I like the idea of the mead contribution as something that might make the next batch unique.
Totally up to you and what you are looking for. If you want a Rum that ages like a bourbon, you should start with a new barrel head. If not, give it a go!
- Username
I'm too early into the game to have real world experience, but i sure hope so. So many good spirits I enjoy are dependent on second use oak , at least commercial examples. I'm hoping to get at least 2 uses from each of my badmo clones.
I do see some guys adding oak sticks into used barrels as well.
As a matter of interest how is the mead doing, it's something I'm planning for down the line whenever I have an empty used barrel
- subbrew
Have not tried it yet. I will leave it in until I have the rum ready to put in. This is my first attempt at barrel aging mead. I will try and remember to update here when I dump the barrel.
- Deplorable
My first Badmo barrel held a bourbon for about 3.5 years, then I drained it and put in a single malt. Its been in there now for about 18 months. So far, I think the barrel is still contributing plenty of oak influence.
The next barrel to drain, is my barrel of CROW Bourbon, I tasted it this afternoon, and I think I'm happy with it and ready to drain it. Ive got a few gallons of SBB Rum Ive been aging on Mead barrel staves that Ive been less than impressed with, so I plan to refill the CROW barrel with rum and hide it for a few years.
I will add that the Mead barrel wood was from a 53G bourbon barrel used 4 additional times for mead before I got it. The lion's share of that barrel became an Adirondak chair.
- jonnys_spirit
If your badmo is neutral’ish, and yiu have an excess of product (like eg; three extra liters), you could oak finger the extra and cycle it through jug > badmo > jug > badmo every three months or so…
The mead badmo sounds interesting. I have one with a long-term port solera going now that i’ll eventually use for something else. Maybe a bourbon finish or a single malt if I’m patient enough.
-j
-j
Reefer1
Is it possible to remove the wooden lid from the badmo's i never had one if so you could plane off a millimetres bake and rechar the lid and bang it back on.
Is that possible ??
Is that possible ??
- Username
It can be done quite easily. First remove any nails pinning it in place. Fill with water, make up a bung with a hole that can take an air compressor gun.
Use a towel to cover the lid to stop it from flying when you give a blast of compressed air. It can pop out pretty violently, be prepared for a some water as well
Reefer1
I did wander username i think before ditching it i would give it a go.
- subbrew
Perhaps reworking a head would be OK. I would worry about reusing a barrel with a new head though. The barrel stretches a bit as the head swells. I can definitely feel the "hump" where the head starts. If seated snug I worry the barrel will split as the new head swells. To me it not worth the chance of losing a batch when it is under $20 to buy a new bain marie.
Reefer1
Aye fare point subrew
When you say mead, was it distilled? I'm assuming it was.subbrew wrote: ↑Fri Nov 06, 2026 8:11 am Looking for opinion here. I have a badmo clone which held a bourbon for 4 years, a mead for the last year (still full) and am thinking of putting a rum in it next. The rum will be made from a combination of baking molasses and brown sugar, so medium strong flavor. What are your thoughts, will the barrel have anything left or should I make a new, uncharred one?
I'd keep reusing the badmo barrel, there would be very little to gain with new uncharred barrel.
That and a new barrel might have drama due to leaks.
Edited: Is the badmoe charred or uncharred?
- subbrew
The mead is not distilled. I did a taste last night and it is nice. It has not changed as much as I thought it might.
The badmo was charred. It had whiskey in it for 4 years before the mead.
I have decided to age the mead another year in that barrel. Since I have to other whiskey barrels that are 4 years old and I will be emptying them I am going to put the rum into one of those. Probably put a new mead into the other.
