First Steam Run! Looking for some Tips--lbs/gal and Headspace?
Johnnywhiskey
Post by Johnnywhiskey »
This build has been going a bit slowly, but I'm finally getting ready to start my first mash for steam distillation. I'm confronting a couple of variables that I have not dealt with in the steam distillation context.
First, how much headspace should I plan on needing? I have a 22-gallon milk can. I'm thinking of starting with ~15 gallons of mash—7 gallons of headroom—and scaling up from there. How much frothing does steam distillation on mash create?
Second, what are people using as far as lbs/gallon of grain? For a first run, I'm looking at ~2.5 lbs/gallon of total mash. For steam distillation, is there any reason I should not go higher? Maybe dial back to 2 lbs/gallon for flowability and keep ABV around 10%?
I'm planning on a high-rye bourbon mash—60% corn, 30% rye, 10% malt. I'll mill everything myself with a roller mill, finer than cracked corn but not quite cornmeal. And I'll use a full complement of enzymes: alpha-amylase, glucoamylase, and beta-glucanase.
Anything else I should think about as I embark on this adventure?
Best,
JW
PalCabral
Re: First Steam Run! Looking for some Tips--lbs/gal and Headspace?
Post by PalCabral »
I am following this! All good questions. Very interesting.
Johnnywhiskey wrote: ↑Sun Nov 08, 2026 9:31 am
On the first run, I'd only half fill the milk can. Then measure the level after the run is done.
This way you will know how much fuller it got due to steam condensing in the mash.
I'd recommend 2 Lb/gal because the higher the abv, the more drama during fermentation. :wink:
You can mash at a higher rate, then use cold water to chill the mash and lower the SG to 1.060 before pitching.
Johnnywhiskey
Awsome, thanks for the feedback.
On a related note, do you blend the yeast into the mash, or let is sit on top? I'm not sure if I'm going to use a dry yeast or some left over beer yeast slurry, but I guess it applies to either.
Best, JW
Salt Must Flow
Post by Salt Must Flow »
Johnnywhiskey wrote: ↑Sun Nov 08, 2026 4:32 pm Awsome, thanks for the feedback.
Best, JW
Dry yeast should first be hydrated for 15-20 min or so. Search online what temp your yeast like to be rehydrated at (water temp). Bread yeast likes 105F-115F so I generally start at 110F. You can just pour the yeast in or mix it it.
If you have a fermentation that's actively working, scoop some off the top and pour it into the next batch.
Be careful reusing the slurry off the bottom of a finished fermentation, it's very acidic and most of the yeast is dead or almost starved to death.
Like SMF said, the best option when using dry yeast, is to rehydrate it in pure warm water (110'f) (44'c) for 15 minutes and stir it in.
Having said that, I often just sprinkle on a big dose of dry yeast and don't stir it in.
In a short time, it will form rafts of yeast on top the mash that grow and spread.
A couple hours later, the yeast rafts have sunk and it's gone to work.
It's not long after that, the cap starts growing like crazy.
zach
Post by zach »
I like 2.5 lbs per gallon for whiskey mash. This results in roughly 6.5% abv depending on your efficiency. The finer the grind the better the efficiency. I like flour if possible. I would avoid higher abv ferments to keep the abv of the low wines down and to avoid stressing the yeast.
Haggy's tool for a pot still with a thumper is accurate for steam stripping. It has 13% heat losses built into the simulator.
https://homedistiller.org/wiki/index.ph ... Calculator
I have a 23 gallon thumper with a 15 gallon keg boiler. This calculator is pretty accurate of what is see with 16 gallons in the thumper and water in the boiler. I have a sight glass on the riser above the thumper before the condenser and can see if I have a puke or solids carrying over to the condenser. I usually end with 20 gallons in the thumper. I have no problems with frothing, but I am careful at the end of a run not to push solids into my condenser by running too long by watching the sight glass.
I now only use the steam stripping when trying to strip solids like grape pomace, or a YLAY ferment that was closer to solid than liquid.
For whiskey, I drain the clear beer from fermenter and use beer in the boiler instead of water. Then add the slop to the thumper. The big advantage is I can strip 29 gallons per load instead of only 16 gallons. I fire my keg boiler with propane and have not had a scorch.
Using a thumper for stripping with beer in the boiler provides low wines with a higher abv than a traditional strip. My last whiskey I had low wines at 35%. I saved beer for the spirit run to dilute the low wines to 24% abv. This is a critical step for more flavor in that it avoids diluting your hearts cut with water prior to the barrel.
Post by Novice »
Vacuum breaker,0-5 psi gauge,5lb prv.
Here's how I would plumb a steam rig.
Powder Monkey
Post by Powder Monkey »
I don’t really pay attention to lbs/gallon, but instead just target the final OG as follows. The water amounts will vary depending on your corn percentage compared to small grains. This isn’t a unique method but gets you a larger batch per cook.
Steam cook the corn. Boil water and then add it to your kettle then add the steam to fully cook the corn. I’ve used between 3-4lbs/gallon and have even pushed it a little higher, but this depends on how the drain size is on your kettle plus grain grind and if it’s too thick to drain out.
I ferment in brute trash cans so transfer the cooked corn to those, then add small grains (specific grain varies but typically have lower gel temp. I can add cooling water if needed to get to conversion temps, but usually let it get there naturally, keeping it thick. This allows more volume of cooling water for quicker cool down post conversion. I keep adding water until I reach my target OG (usually 1.075). This ferments and usually results in two stripping runs from one cook session.
Johnnywhiskey
Novice wrote: ↑Mon Nov 09, 2026 7:13 am Vacuum breaker,0-5 psi gauge,5lb prv.
Check, check and check. 8psi was the lowest PRV that I could find at a reasonable price.
Johnnywhiskey
Thanks again to everyone for all of the information.
On the topic of fill volume / headspace, is puking / frothing much of a problem with steam distilling on mash?
Best, JW
Not that I've noticed, once the thumper is up to temp everything settles down to a boil.
Search for "steam injector" the one I use is made from woven SS that originally stretched over a clothes washer hose.
Here's a pic of it.
Post by Novice »
Johnnywhiskey wrote: ↑Mon Nov 09, 2026 4:15 pm
If you can when you get some time put a drain valve on the bottom of the loop for your pressure gauge.
Novice wrote: ↑Tue Nov 10, 2026 9:22 am
I've never seen a drain valve on a pigtail siphon that's used on a gauge.
If the water is drained; the gage isn't protected until more has condensed.
As you already figured out, 15psi is dirt cheap but 8psi and under is rare and expensive. :roll:
On a side note, the PRV is steam rated. If anything other than water is boiled, the PRV will tend to gum up and not open properly.
Keep that in mind if the boiler is filled with wash, beer, mash or anything with left over sugar or starch.
After use don't leave it dirty to dry out, and jam.
Take it to the kitchen sink and run hot water through it while the release handle is pulled open. :wink:
Post by Novice »
shadylane wrote: ↑Tue Nov 10, 2026 8:26 pm
Shady,
So you don't feel the pressure isn't enough to put moisture in the guage and pushing that water up the tube is how it regesters
pressure.
I don't know the theory about plumbing a steam gauge, all I know is the common practices used.
For use on a steam rig, I think a gauge is almost useless. A manometer works much better.
Post by Novice »
I have both, having constant moisture in the system I thought would deteriorate the accuracy of the pressure gauge. Well I learned something this morning.
I'm guessing the loop is used to keep liquid or any debris from the boiler from getting into the gauge.
Johnnywhiskey
shadylane wrote: ↑Wed Nov 11, 2026 12:52 pm I'm guessing the loop is used to keep liquid or any debris from the boiler from getting into the gauge.
It's my understanding that the loop is to keep the steam off of the guague, create a thermal barrier between the hot steam and the gauge. Some steam will condense in the loop and a pocket of air will transmit the pressure to the gauge. When I disassemble the system, I'll probably empty the loop.
Johnnywhiskey
Mash for first steam strip in progress. It also gave me the opportunity to use my recently motorized Monster Mill 2. It's not the fastest mill by cranked through the corn no problem--slow and steady. It's only 60rpm, but a lot of torque. I went this route over a hammer mill so I could use it for brewing also, and I already had the mill.
For mashing, I just boiled the water and added the corn after removing the heating element (13g to 20lbs corn). After through mixing it was at 183F, so it should hopefully gelitinze fine. I though about steam mashing, but it seems like an extra step, and I've had pretty good luck in the past just adding the corn to boiling water.
Full grain bill will be 20 lbs Corn, 10 lbs Rye and 3 lbs Malt, plus all the necessary exzymes.
Johnnywhiskey
Holy spontanious fermention Batman!
I let the mash cool off overnight before pitching and this morning the mash is going crazy! Not sure if that is a wild yeast, lacto or some mix of the two. Threw in EC-1118 (left over from another project) at 90F, probably a little hot but I hoping it will catch up with whatever is growing in the mash now. I have not done an on grain fermention before, so I'm not sure if this is normal. But I have never seen wort spontaniously take off like this, even when it was not boiled.
