Plus 2. plan out the biggest press you can then double it. I press somewhere between 150 and 300 lbs per pressing and it's still the slowest part of the process.Bushman wrote: ↑Wed Nov 04, 2026 6:40 amPlus 1, i have an electric scratter and it is fast and my press is a 29 ton Harbor Frieght press with a turkey basket and a cloth cover. The hand press is our bottle neck and I am thinking about converting it to electric..MooseMan wrote: ↑Wed Nov 04, 2026 5:14 amI hope you don't mind if I give you a bit of advice on the press Beerswimmer, go as big on the basket diameter as you possibly can, you will be glad of it.Beerswimmer wrote: ↑Sat Oct 24, 2026 9:04 am Thanks! I put in about 17-18 gallons. This winter/spring I'll be making a press to use next season. Pulp is a pain in the butt to work with.
Even after rebuilding my setup with a really big basket, the bottleneck on pressing day was always the press speed. The first setup I made, I would have to press 75% of the pulp the next day as it was so slow with a 5g bucket sized press basket. The rebuild with a much larger basket is way better, but still can't get near keeping up with the scratter even with someone dedicated to the press all day.
An electric scratter will go through apples as fast as you can feed it, but the press takes so much time to setup the cheeses, actual press time and empty again, it becomes frustrating.
What's your build plan?
Edit: maybe a press build thread?![]()
By my math your running somewhere between 150-180 lbs of pulp per run for around 3,600-4,000 #s of apples total. My chopper can easily handle that in a day but even at 300#s per pressing it would take me 12-16hrs to press them all...provided I want the most I can get. If I was willing to lose 1/2 to 1 gallon per pressing I could do it in under 8 hrs but I hate losing that much per pressing. The way I press I regularly get as much as a gallon per 13#s of apples but for arguments sake lets call it 14 Vs say 15 or 16, the total difference being 285 gallons of juice Vs 250 or roughly 18 gallons of finished brandy Vs 16 ish.
2 gallons may not sound like much but to me it's a lot of hard work to give up that much.
